View Full Version : Honda Accord (1990 - 2002)
- 1990 accord don't have spark or fuel????help
- 1992 honda accord lx failed smog test
- Wont start on a hill
- Need help identifying a part
- cg3 Tranny Failure, 5 Speed swap or Full F20B swap?
- Fast Idle Thermo Valve 101
- Keyless entry installation for 99 accord V6 coupe
- New guy w/ 6th gen
- 1996 Accord- Help with Transmission Shavings
- drive axles? tranny problems? or misfiring???????//
- Engine swap with mixed parts
- 96 accord f22b2
- 1994 Accord LX 5-speed speedo issues?
- h22a turbo headgasket need help
- F22B2 Head Swap?
- 92 Accord EXR Broken Timing Belt
- 1998 Honda Accord EX Stereo Options?
- 95 Accord EX with H22 turbo - Car won't start
- Anybody with 300+ whp J30A1?
- 6th gen. accord blueprints
- ev motor
- Squeakng noise!
- question with blackening tailightstail
- can i used saturated injectors in my 95 honda accord ex?
- 92 Accord headlight problems
- Transmission Swap (Auto to Auto)
- h22 accord idle problems and power los
- Help with Brake Suggestions
- Need help with FITV issues
- Accord heater knob cable broken.
- Tires on different wheels. I might be dumb
- heater problems
- 94 accord ex auto tranny probs?HELP!
- 95 honda accord
- Trying to burp coolant, am I doing it wrong?
- RPM'S fluctuating at idle and at cruise
- I need a diy for an LED gauge cluster!
- 96 Accord idle problem
- Wiring harness/oem stereo question.
- HElp Plz!! civic fogs on 99 accord
- VTEC T-stat part # change
- 95 with 2.3
- 98 accord vacuum diagram.
- Swapping my '96 OBDII F22B1 for a JDM F22B1...what needs to be removed from old motor
- front seal leak
- 97 F22b1 have a knock sensor?
- HELP!! 98 lx, intermitent power loss
- 1995 Accord LX Failing Emissions
- VTEC Solenoid
- 95 accord trip and odometer not working
- 95AccordEX, Dashlights, cornerlights & taillights not working.
- 1991 Accord Auto Tranny Question!
- adding a few cc's
- 97 Accord Lx timing belt?
- Bigger TB, can i expect much if anything at all?
- side skirts
- 2001 Honda Accord converted from automatic to 5 speed.
- odyssey steering wheel on 5th gen accord?
- Turns over but gives up, lights "check engine". Help? ;p
- exhaust
- h23 pistons in f23
- auto tranny prob, 95 accord ex
- consequences of over inflating tire than recommended PSI
- Intermittent overheating
- 95 accord water leak
- 93 honda accord revs up and down
- 01 Accord Clock Light and Driver side Door lock not working
- Shock Installation Question
- need info J series
- auto tranny prob.
- Question about 94 EX hubs (Aftermarket Steering Wheel)
- accord tranny problems? P ADAMS?
- Wanted...
- One cylinder running lean, advice please?
- Leaking injector
- My car has an oil leak. Can I go synthetic if I remove it?
- torque converter or tranny itself?
- Intermittent starting problem on 96 EX Auto
- SRS Unit part no.
- HELP swap h22a8 99' to f20b5 accord coupe 99'
- Swap H22A8 99' to accord coupe F20B5 99'
- rough idle accel then smooths out. why?
- how much pressure to put in when recharging your AC?
- Used ECU from Junkyard: Will it work?
- Is this a tranny issue?
- my honda accord starts but won't rev past 3,000rpm!!!help me out someone
- f22 tranny swap
- code 505 idle air control 98 accord v6
- 1999 Honda Accord knock sensor
- Difference Between 94-97 Honda Accord EX VS Accord LX
- broken odometer
- A car wont start thread. Please help.
- actuators and powerlock knowledge needed
- ECU? for F22B swap
- 92' clutch?
- jdm/honda access window deflectors, cd5
- Need Help.. shifter,windows,clock,guages on 94 accord
- What's the Thread Pitch for an Accord Axle Nut?
- obd2 plug in
- Need some help! Found gas in engine oil
- HID on 97 accord.
- 1998 Honda Accord Brake Problem
- Radiator head of my honda accord 1992 is leaking
- F22 power off the line with an automagic
- 93, erratic blower operation, What do you think?
- 6th gen 4cyl, strange sound on shutdown
- 1990 Accord Vaccuum Leak
- 99Accord - Occasionally stall problem
- Pistons for Accord
- HOW TO: Adjust the valves on your F22
- Left Turn Signal stays on after Handle is turned to off
- 94 lx jolt
- 92 Prelude Seats in a 94 Accord??? HELP!
- i put new main relay on my 1990 accord and still no starting???please help
- 96 Accord LX Oil Drain Plug Torque Setting?
- Why is 90-02 grouped together?
- question for those guys that are boosted.
- Question swap for av6 to manual....
- New to the 1990 accord got a issue with it.
- rear alignment!!!
- im new to the site
- 2000 accord sputtering problems
- 94 Accord EGR removal PLEASE HELP
- Plastic fastener on '93 Accord door lock cylinder
- Annoying Noise while Driving!! 91 Accord
- Need quick help - do I need to flush the Throttle Body hoses seperately?
- stock rebuild an f22b2 94 accord ex
- Major tune-up & body question
- Torque Value front motor mount?
- 2000 Accord Coupe V-6 Start-->Die
- lug nut ?
- 90 Accord EX Vaccuum Hose Schematic
- 96 accord ex f22b engine swap need help
- HELP Lug nut and bolt spinning together.
- 96 lx idle
- Turbo 4 my f22b1?
- 215k on turbo 94 accord ex
- forbidden motorsports ss who has them?
- special edition 5th generation
- buyers order?
- external coil to internal conversion
- Help!!!
- Replacing heater Core??tip's please
- need 97 accord diagram pinout of ecu
- Is this the speed sensor.
- Slushy Coolant HELP
- Highest F23 Dynos and 1/4 Mile Times
- 92 accord block heater
- Does a B-series engine fit in an accord?
- cfk mod on automatic
- VTEC small coolant drain bolt at the left end of the block
- starter solenoid
- Alright, I can't find a similar thread on this...Car wont start...=/
- ACURA parts on ACCORD????
- Changing Motor Mounts
- Engine Readout? F23
- Oil spot on driveway should I be concerned?
- Hissing sound from passenger side of 1996 Honda Accord EX
- Another "heat" thread...
- Honda Accord Dash Instruments Electric Diagram
- Laosta479's 98 Honda Accord EX (no 56k)
- 1998 accord timing and balance shaft setting.
- 1988 Honda Accord LX issues
- OBX Short Shift Adapter for 90' Accord?
- door lock actuator
- 1999 Accord F23a1
- Accord Idle Surge
- 1989 accord
- stupid question
- my accord won't start i hear weird buzzing ..please help
- need valve adjust procedure for F22 non vtec one in faq dead
- 2001 Accord Problem - alarm won't stop
- help please 95 accord rear quarter panels
- 1996 Accord O2 sensor?
- 97*Accord .. Oil leak/&*Coolant Leak
- May 3,2009 Auto Show
- 1991 Accord Wagon - Same front end parts?
- 92 accord 4dr Auto to 5speed W/H22
- k20 pistons....yes or no?
- h22 build--need suggestions
- 93 accord runs smooth cold, run badly warm -also won't turn over sometimes
- Rack-n-pinion?
- looking for turbo suggestions
- Rear wing brake light
- still not running good
- 94-97 accord suspension ??'s uca hitting
- 1994 Gauge cluster mileage adj. after speed sensor change?
- is this overpriced or a good deal?
- Need opinion on transmission bent/pinched tubes.
- FS/98-00 z3 fenders
- 92 Accord EGR disable bypass?
- air ride suspension ?
- 1992 Accord low heater temp output?
- 94-97 accord JDM
- Reservoir Coolant
- How bad did I screw up? Advice please!
- 1990 Accord EX Electrical Problems
- 1990 accord ex very rough idle
- What do I check here? Starting Problem, Clicks, Buzzing from under Drivers Dash
- Horrible Gas Mileage 91 accord
- 1996 Accord Electrical Problem
- Help! Need good quality shock for dropped accord
- having problem's checking the check engine light
- 1991 Honda accord 4cyl. HOW?WHERE do we check fuel presure?
- F23 swap questions
- Removing Throtle Body F22B1
- 5th Gen accord rear window visor...
- h22 euro R?
- 93 heater core
- Holy Crap...CEL blinking and engine running rough..never seen before
- 2000 honda---gas smell through vent
- h22a1
- 1996 accord valve adjustment and voltage problem
- 1990 Accord Spark Plug Wires
- 1990 trans ecu problems
- removed OEM spoiler, holes left.
- Rocker arm assembly not lined up
- Vtec?
- 94 accord h22a cylinder 4 misfire
- 2002 Accord 2.3 VTEC, low/rough idle problem w/ random misfire code
- 97 Accord - Spark problem / Car won't turn over
- Installing "Cold Air Intake" Into My 1990 Honda Accord EX
- Who can figure this out?
- 96 accord press on accelerator
- need a f22a head for my 92 accord ex..!
- tHE hONDA aCCORDS!!!
- how do i open my car?
- 1990 Honda Accord Vibration
- Strong gas smell from the injector area.
- abs question
- Are there 2 types of CF hoods?
- So opinion time... even you MuffinMan.
- cargo net
- Vacuum lines
- 94 accord lx swap to 95 vtec engine.. Question
- H22a4
- H22 swap heat issues
- What's the difference...
- intermediate drive shaft bearings replacement
- Knocking from engine block...help!
- 2000 Accord V6 - Strange noise between 40-60mph
- How do you know if you have a bad radiator fan timer?
- f22a6 head on f22b sohc block
- Strut BAR??????
- 4x114 to 5x114 adapter
- 94 honda accord transmission fit up
- dizzy wiring question??
- Car won't start. Starting to piss me off.
- Bogging in 3rd and 4th gear
