View Full Version : Honda Accord (1990 - 2002)
- 1991 Accord Engine Question??? HELP !!!
- Stuck rear seatbelt
- Turn signals don't blink
- Changing out the dashboard/clusters/
- 3 Questions regarding 96 accord: TSX engine, paint, and leather interior
- 2 questions re '03 ex v6 4door?
- what honda/acura steering wheels fit 98 accord?
- Repair Time
- center console
- Apexi WS2 sound & Pspec short shifter
- HeADUNIT POCKET?
- Hondata for TUning on Accord 01
- Why is the 95 EX heavier than the 94 version?
- Light Weight FlyWheel, High Performance Clutch System.....
- bumper and light trouble
- Maint Req Light
- 86-89 Frame Dimensions
- Spark problem 89 accord DX
- Turbo F22 kit!!! Sorry
- rubbing, scraping.. ahhhh
- 96 accord check engine light questions
- 89 Accord LXI 2.0 CEL
- 97 accord ex sohc vtec
- accord 2003 headlamp HELP!!!!
- Amber removal from taillight removal link????
- Problem with my 94 accord
- 2004 accord coolant drain plug on block
- 95 Accord SRS Light not turning off?
- Gen 7 Low Beam bulb replacement
- intake
- EGR problem... HELP!
- Swapping in Vtec F22 in a lx accord...what transmission?
- Shifting an Auto tranny
- Exhaust question
- VSS speed sensor gone bad? need expert help
- Will a 4 door mirror fit a 2 door car?
- 89 honda accordlxi speed issue
- K motor in 5th gen
- (honda torneo)2.0VTS is like accord and it open the (eps) Electric Power Steering lamp
- newbie help
- Need help deciding H22?...
- sportin black
- Need SRS codes and description for a 2004 Accord
- fog lighties
- Turbo Fuel Mangement System Recommendation!
- 94-97 Accord Questions
- Halo Projector Lights
- PSI VS LBS ot Boost
- 5 Lug Conversion on accord
- Accord sidemarkers
- h22a SWAP and auto tranny?
- Help on my Honda?
- Frozen front upper ball-joint, replace it or use a camber kit?
- rattle in driver's door-2004 accord 4-door EX 6 w/leather
- Hytech header fitment?
- h22a: can to much oil effect vtec pressure switch?
- A bit weird question
- camber kit
- quick response needed about rims
- Pic of Sun Roof Visor clamps Help !
- 2000 H23a DOHC VTEC from an Accord Sport Wagon
- 2001 Accord Coupe EX V6 Tires
- Auto Shifting?
- 97 ACCORD WANTED
- Best year/motor to boost
- which amber corner?
- How do I get to it?
- Shift boot install
- distributor question
- Best bang for 500.00?
- ima win the powerball n turbo my accord out
- help with troble codes
- Gap is off between front bumper and hood
- how does the o2 sensor come out?
- Accord Tire Decision Thread
- Need some help ASAP!
- 6th Gen: That compartment under the cruise button, what do you use it for?
- gear shifts
- hard to shift gears....plz help
- Turning off Maintenance Indicator Light on '03 Accord
- i want to do a 5lug
- difference between h22 and h23 trannies
- Start won't start!
- tranny swap
- lip Q
- Looking for a RCA cable adapter for the 03+ radio
- help oil leak
- what do you gusy shift at?
- Chipped Accord ECU...
- heres a good story for all of you (and a store not to shop at)...
- obd-ii emission code reset 96 accord lx 4cyl question
- different sized pipe
- Its back......
- Help replacing front rotors on 90 Accord?
- Corrosion???
- Crooked installation shop?
- my brake lights dont work on my 92 accord lx checked fuses bulbs and replaced my brake light switch
- What can I do to get the most power???
- seamfoam or induction flush?
- Ride on the new 06 accord sedans
- 01 accord starting problem
- 4 or 6 speakers 2001 accord 4dr
- Short Shifter adapter for 94 accord?
- How to hook up vtec
- Balljoint camber kit
- taking off the cluster
- nybody know where the vtec pressure switch is on a f22b1
- Here's a nice juicy problem from a noob
- 6th gen maintenance
- diff. gas ratings
- my car wont start!!!!! i need help desperately!!!!!!
- CEL for low EGR flow: 98 Accord V6 (Service Bulletin 99-085)
- Tranny fluid change....
- 99 Accord LX 4Cyl, 2Dr Throttle Lagg....
- Rough transmission shifting 2000 Accord need advice
- swap motor from 98 accord to 96
- EXAUST BOLTS
- Auto Trans & Transaxle Ratios
- 1999 Accord LX, Rear Disc Brake Upgrade...
- where to find a slide hammer??
- My car shakes like a banshi!!!
- Car wont start in the Morning when its cold. NEED HELP!!!!
- need help finding wheels?
- i think my lug nuts are loose
- Accord 03/04 Radio Install Kit
- Truck Broke/Getting New Muffler.
- 1986 - 1989 Honda Accord Main Fuel Pump Relay - LOW PRICE
- modded digtal instrument cluster legal?
- MSD?
- B18 in a 4th Gen?
- 93 h22a whinning when startup? VTEC cut off??
- Fixing my accord...
- displacement
- Header and O2 sensor ?
- How to install Boost Guage, Oil Pressure Gauge, Air/Fuel Gauge??????
- advice about.....
- chassis code question
- k&n cold air intake
- 96 lx: ANyone replace their CAT CONVERTER with ARVIN- Questions
- Valve Adjustment Part 2
- Lost all power on my 91 Accord Ex
- Where can I find a bomex body kit?
- 97 Accord H22 5SPD
- 7gen Coupe - Stock Stereo to OEM Navi
- car failed emission test.. please help!!! :(
- Rough Idle After Cleaning Throttle & EGR
- 2001 accord jumper for codes?
- Japanese 2003 Accord TL type S. Navigation DVD needed.
- Accord Dyno Question....
- Tire question !
- stock 6 disc changer
- check engine light on
- Best way to find exhaust leak
- What is the best Brake Rotors
- 99 Accord starter circuit
- accord short shifter????????????
- Seat moves
- Break in engine
- 6th gen h22 swap, ECU / immobilizer concern..
- New Purchase
- So im buying a new car soon..
- v6 accord firing order? need to do valve adjustment
- Strut Bars..
- how do u know a poa ecu is automatic or manual
- what do i need to do to swap an f22b1 sohc vtec into a 91 accord 2 door coupe lx
- F20B Motor swap
- Prelude engine
- Should i mod my car??
- Driveablity ? to throw at you all........
- 94 95 honda accord tranny help
- suspention
- Blown Fuse
- 91 accord front suspension work
- 5th gen guage cluster lights
- Having trouble re-setting "maintenance required" light
- installing dual dins in my 97 accord
- 6th Gen Clock Light
- Will a 3.5 ton jack work to replace my Front Engine Mount ?
- Speed sensor part number on 1997 Accord SE.
- 92 Accord fans not working
- 88 ACCORD SERVICE BULLETIN HUNT..
- 98 Cat Replacement Questions
- v6 6th gen swap need help!!!!!!!!!
- 5 lug conversion on a 94 accord
- Bad grounding for Horn
- New clutch squealing
- Guage needles not lit
- instrument lights on only when headlights are off
- squealing on start up and when hitting the gas
- Coolant Reservoir
- Grill question
- No Second Gear (Automatic)
- 98-02 Right Hand Drive Conversion ?? where to find?
- how to change oil pressure swith on h motor
- going BTS, need help/tips getting parts
- 91 honda accord bezel(?) removal
- PCV WTF?
- 98 Accord Radio question - Help needed
- Heat Shield From Header Pipe to Exhuast Pipe..Need Help...
- Accord fuel filter line question???
- 99' EX power locks
- Anyone know the 2000 Euro R rev limit?
- Accord with h22
- info on possible carbon fiber trunks for 1990-1993 accords (cb1-cb4, cb6 & cb7)
- Engine wont start. not good
- k20 or k24 swap
- F22A4 Rebuild?
- 91 accord tranny
- 97 accord ex engine into a 94 honda accord ex whats needed?
- 3rd gen swap
- 6th Gen ABS
- 1979 accord
- Help! 4,000rpm redline!
- Struts...
- 99 Accord TinT
- Some 03 accord questions..
- New to Accord: Did the V6 come in a 5 speed? looking for a car
- How to clean EGR on a 98 accord
- '00 Accord Double DIN CD player Swap
- Ok This is getting old...cold engine...car shakes blah blah read it lol
- 2006 Accord Lock System Malfunction
- Looking for a H23a throttle body...
- 99 accord camber question
- HELP!!! What transmissions will fit on an f23 accord lx NEED a Quaife diff in my CAR
- 14" alluminum honda wheels
- Lighting Size?
- Ac compressor/serpentine belt
- Carbon Fiber Hood?
- 91 accord idle problem
- f-series motors noisy valvetrain
- F22a1 EGR Port Cleaning
- 2002 Accord 75k mile schedueled maintenance
- How Much Could I Get For My Car?? Honestly??
- Compression Ratio
- WHAT ELSE CAN I DO
- DASH LIGHTS OUT
- camber kits?
- are tune-up's worth it?
- help with engine and maintenance
- Most affordable place to get Magnaflow for 5th Gen?
- swapping rotors
- 1997 Honda Accord SRS Module
- technical-timing issue-
- DARK CLOCK AND TEMPERATURE CONTROL LIGHTS, '98.
- help gas
- help
- Cat-Back Confusion
- What is the interval to change a timing belt on a 98 v6 accord
- suspension problem after installation
