View Full Version : Honda Accord (1990 - 2002)
- Aftermarket Brakes for 94 Accord
- Having problems with left rear window
- Wheel hop...
- Eibach Pro Control Strut bar
- Stock Rims????????????????
- Never had this happen before...
- Rear brake pads
- Exhaust question
- just got hosed
- Keep Turn Signals on as Driving Lights?
- Projector Cutoff and Light Output
- 1995 Accord V6 Manual Conversion
- 97 accord obd ii communication problem
- Where can i get strut Mount Kit
- H22A firing order
- 4/S 91 Accord 5Spd
- 2002 honda accord engine and trans swap
- V-tec-ing My Accord
- H22A swap problems
- why are my rpms jumping
- Lovely, lovely gearshift...problems....
- Vtec head question
- vtec specs on f20b
- 1990 accord.. loud noise in head! heres the comp test results............
- question about the removal of stock intake.
- wiring diagram
- Few random questions I could use some assistance with
- Spoon throttle
- SRS Light
- my engine pics
- Will this cluster work????
- sway bar
- car make grinding feel
- Car makes crank sound when i back up......?
- 1995 Accord odometer and trip-meter get stuck
- What is my radio telling me?
- k motors
- Searched and couldnt find Horn diagram.....
- 96' Accord auto tranny fluid, where to buy?
- is an f22 engine better to turbo ?
- 92 accord EX retains accesory power
- ((((((Pic request))))) Accord 94 fuse box
- help..i need a rear driver side caliper braket with caliper bolts for 97 honda accord sedan
- 1997 accord LX 3rd brakelight wires
- Throttle Body Spacer
- stupid brake ??????
- 1997 Accord 2.2 Whine
- 94-97 are v6 suspension parts compatible with 2.2s?
- Transmission
- Help with Compusatr!!!
- Offset
- 1989 Honda Accord EX problem
- This just suxxors....2nd trans dead after 4K miles
- Apexi WS2 Exhaust.. Need opinion..
- Cheap mods (New to this forum)
- LED headlight? Possible?
- map sensor
- New member here, question about my accord...
- RIMS
- Bypass Valve
- is this a real sway bar?
- h22 crank and rods w/ custom pistons in f22b1 block.
- Radio Code Issue
- Glass grime
- 95' accord cutting out??????????please help me
- P39 piston
- 93 Accord.EX Intake Backfire / Fuel Starvation, HELP!!!
- 98 accord tranny problems, I need help
- 2001 Honda Accord.... Getting the CD player out.
- 02 accord exhaust and suspension
- Service Manual for 98
- Haynes or Chilton?
- Intake FOr 95 Accord Ex v6
- need help on accord rotors
- Honda interior q's
- Brake lights/Tail lights stay on
- Found a blue wire and plug in Fuse Panel??
- Searched HT and Soln worked!!!
- TIming belt service..car does not feel the same
- how much does an F22b weigh
- 02 accord exhaust and springs
- spark plugs
- 1998 Honda Accord Upgrades?
- 1990 Auto EX tranny question
- Mugen style lip ASAP
- h22 mount question
- 2003 Accord lost radio code...
- what will fit?
- Radiator fan timer location
- 4th gen bolt pattern
- Projector Bulb Questions
- just wondering
- some can gives a solution?
- CEL code: can't find 2442
- will f20b fit in 4th gen accords
- anyone know what could be wrong w/my car??????
- When to change the timing belts?
- Changed Plugs, Where is all this oil coming from?
- 98 Accord swap info...
- help IDing a front bumper kit
- Trunk panel removal?
- 87 vs 93 Octane
- Best mod for the money?
- Clear dist cap.
- help on starting engine
- ep3 seat question
- Need to replace ECU 98 Accord. What's with the key thing?
- Cold Galvanize Zinc Treatments on external exhaust
- I though all honda V6's were C series........
- Rear quarter panel 4th gen accord
- WANT TO BUY RIMS FOR '95 ACCORD... NEED INFO!!!
- Speaker Removal 92 Accord LX Help
- 93 accord brake issues......
- penetrating oil this stuff works great
- Irratic idle, bogging, slight over heat (swap)
- CD6 JDM Spoiler?
- 5th Gen Magnaflow Cat-back owners, Question
- Pioneer AVIC-D2 nav unit...anyone have it?
- X Factor turbo kits from xculsive customs??..has anyone used or heard things bout kits????
- Seat problems
- im not an accord guy but i need something from you guys...
- f22 help
- difference between coupe and sedan clusters?
- 94 coupe door panels
- oil above spark plugs
- My O2 Sensor disappeared?? o.o
- steering wheels ligting
- Sway bars, strut tower brace on 95 accord
- Help with 2001 Accord LX check engine P0135
- f23a1 iacv?
- 89 honda accord
- Shop for Auto-2-Manual Swap
- help me if you can
- A/C Questions
- DIY - Red Out Taillights
- Tanabe's reputability...
- Good deal?
- Power Locks Actinmg weird
- EGR Valve
- wondering what is wrong
- H22A COMPUTER
- auto tranny fluid
- Headgasket
- 94exvtec dizzy help...PLEASE!
- 1993 Accord EX auto tranny problem
- smoked jdm headlights and jdm lip
- roll cage?
- Straight Pipe for my 97 2.2CL
- Side Restraint System
- Front window trim on '91 EX
- shifting help please!
- Failed Coolant test?
- 85 Accord Engine Swap HELP!!!!!!
- If 19" x 8.5" wheels Fit>>>
- converting a 5th gen to rotor over hub front brakes?
- need help with CB headlights!
- 98+ Helms scan...please.
- Electric Impact wrenche question
- Vibration at idle on '95 Accord
- h22 head
- bore h23
- nitrous...
- Automatic ECU?
- b16 engines.
- Looking for 5th Gen Dash Peices
- non abs to abs?
- fuel filter on 92 accord?
- Condenser relay
- 4th gen accord tranny
- cigarette burn
- Transmission Problems!~!
- Accord newbie, auto climate control LCD light question
- 4th gen drivers seat
- does the 06 accord coupe navi/non navi have an ipod input?
- mods needed for my accord
- Sorry have to ask about a drop kit 2000 accord
- 2000 Accord Speaker Fit
- idle rpm problem
- 5 speed F20 -> Auto DX-----what do I need?
- lowering problem, help!!!!!
- Rods
- Tenzo R rims 4 sale
- 1990 exr drinking the gas like crazy!! maintenance makes it worse!!
- Solving Code 65
- H22A 91acc.EX.Using a P.28 with spoon program supposably... good or bad?
- READ THIS AND HELP LOWER GAS PRICES!!!!1
- 91ACC.EXH22ASWAP MAJOR BRAKING PROBLEMS ? HELP
- 91 ACC.EX H-22A.SWAP/TIMING QUESTIONS !!
- "95 Accord maintenance required light... turn off!!!
- Rota gt3s on a 94 cd5
- Oil Presure Sending Unit
- CHECK ENGINE LIGHT KEEPS COMING ON (2000 EX)
- 97 CL time slip..
- Differential Noise
- 2.2l V-tech conversion
- 235/40R17s on a 5th gen w/ coilovers?
- Radiator Question
- non-honda starting/running problem...
- Help with 1991 Accord Ex check engine code 43 "Fuel supply system" ?
- So I welded a cherry bomb as a resonator and........
- Give me some opinions on my 94 accord...suggestions? thanks!
- generations?
- Searched: failed emissions....hydrocarbons and NOx
- Okay Accord guys i need some help, car start but die right away......
- request
- Accord Radio- Code won't reset cd player, just radio
- What are the different ECU's for 5th Gens?
- 6th Gen Interior Trims
- Cd5 squad
- Quick Gas Question - 1991 Accord EX coupe
- transmission oil cooler?
- 1999 honda accord check engine light on
- check engine light
- 87 Accord DX Carb Stalls at idle
- K20A2 in cord
- cheap mod
- Accord Lease Deals....any hidden catches?
- Vibration under load
- 97 Accord LX reliable?
- HELP! Top Dead Center Sensor Throwing Code
- Tranny swap...brake lines?
- Question about shift linkage for 5th gen!
- Anyone know how to tell if my timing belt skiped some teeth?
- 91 accord ex CD PLAYER LOCKED!!! NEED HELP!!!
- dsm injectors
- I need help with the ABS Light.
- Burning smell....
- wat would be the easiest swap
- 19x8.5 on a accord coupe not lowered???? work yes or no??
- improve your gas mileage
- Anyone Have A Picture of 1993-1997 Accord With Rota's?
- REAR END RATTLES WHEN IN REVERSE >> WTF ??
- Accelerator gave up, almost got in an accident, please help
- Power Antenna Replacement How To Link
- pic request
- 1995 honda accord clicking sound
- Need electrical help.
- a question about my accord
- Honda Accord 1994
- Checking codes
- fuel filter questions
- PSS9's on a 90 accord?
- did the accord coupes with the VTEC v6 come in a 5 speed?
- CYL sensor
- '95 accord LX hubcaps question
- SEAFOAM on 240K F22......... yayh or nahah ???
- 98' V6 Timing belt
- 1998 accord 3.0 Oxygen sensor
- Fuel Evap CEL
- fron lip on accord..
