View Full Version : Honda Accord (1990 - 2002)
- brake caliper upgrade
- burning fuel and low idling
- understeer, oversteer, terminology, etc...
- Info for jweller, or those in need of a 6th Gen cylinder head...
- Searched, cannot find the answer on brake coversion - anyone know?
- 91 accord missing 3rd gear..
- 88 Accord tranny problems
- Stock Head Unit Swap Instructions?
- Cold AC vs. Header question
- another h22 ?
- Problems with my locks (1999 Accord LX), battery problem?
- Honda MTF on other cars?
- FYI - Free Carfax for those used Accords
- F22A/ex into a 93/F22A1/lx accord!
- *****How to install Autometer*****
- H22A -> 4th Gen Accord
- Need help to find link
- Major problem with accord....need some help fellas!!
- Rear brake upgrade on prelude
- project idea have a couple of questions
- F23 possibilities
- the switch on engine bay to throttle
- center console 5th gen gap???around shifter where center console meets console around radio
- 92 Accord, Checking codes?
- Question on Brake Pads And Rotors?????
- Suspension Tuning for 6th gen Accord 4 cyl
- calibrating torque wrench
- pcv
- Is This Possible???
- Intermediate Shaft questions
- Lowering 5th gen
- High Flow CAT
- Control Box control, EGR, vaccum tank, inatke soleniod questions !! (4th gen accord)
- installed vafc but how to hook up vtec
- REar Seats replacement for 5th Gen Accord Coupe
- Auto Tranny, Transmission Fluid? 98 Accord LX? How much?
- i lowered it, now what?
- Removing gauge cluster from 95 Accord?
- Accord Seat Question
- 94 accord brake upgrade?
- 5th Genners with F-Max Kit..what DIY's were made to make it fit??
- Who has VAFC on f22/f23???
- largest dimensions for wheels on '00 accord coupe?
- Fmax turbo kit. T3/T4 hybrid
- MSD SCI-L Install HELP!
- H22a in 95 Accord problems
- what tools should I get when working in tight spaces?
- Is this accord worth buying?
- wheel bearing problem
- 4th gen accord center console/armrest !!??!!
- RPM cut off
- Which Year Accord?
- my new wheels
- trading 00 si for 01 accord ex?
- Any 6th genners using buddy club spec III exhaust?
- Studdering At Low RPM
- 90 Accord: Car Vibrates in Reverse?
- Power Loss
- 93 Accord Going Boosted
- feilds vtec controler
- Speedometer problem..
- Rear Sway
- Bolt on Headers...
- f23a drinking oil
- Tranny Questions
- high idle
- Calling all boosted Accords..
- bumper help
- exhaust help
- Where do you buy OEM honda parts from?
- Wheel Locks
- 92 accord foglight wiring and bulb?
- 92-93 accord emblem.
- New clutch time... questions
- Need paint code or name of the black paint for 93 accord ex 4 door?
- As of today, I'm a 4th generation Accord owner!
- turbo setup. . . need help.
- Need help with Shift Lock?
- Hood
- Transmission starting to go bad???
- quick transmission question!
- Tein Full coilovers on 5th gen..who runs them?
- '90 accord cam
- need help with 99 accord
- ECU question
- my first dyno numberS and i hate them...
- psi
- 03 Accord Navi system
- Are all bolts and nuts on an accord in metric?
- how much does stuff cost?
- Is there a right and a wrong way to put on a crank pulley?
- Any meets near long beach, ca?
- '95 accord h22a swap but sticking with the auto tranny
- need to know does sedan side mirrors fit coupe side mirrors?
- how do I replace the cabin a/c filters?
- 87 Accord looking for speed.... is it even worth it?
- Is there aftermarket gauge panel for accord
- Head unit installation '94 accord HELP
- h22a, h22a1, or h22a4?
- Gauge lights problem
- 03 accords?
- grounding kits??
- help with 98 accord ex v6. anyone had this going on with their accord before?
- Getting ready to hit 100k
- ATF Fluid Flow Pattern, to Radiator? Please!
- Intercooler
- d16b v-tech enigine swap in an 88 accord LX
- Rear disc brake upgrade for 4th gen accord...
- 6th gen rpm window switch
- integra type R euro R??
- Wanting to make a better 4th gen accord
- pics of turbo accord, on volks
- Stock Grounding points for 94' Accord
- f22a6, Anyone Have a Picture?
- MY CAR GET ANOTHER OR INSTALL SOME BOLT ONS
- Hey one of you dreamer clowns should seriously buy this:
- bottoming out, help!!!
- Looking for advice for new tires
- in tank fuel pumps
- car won't start help PLZ
- Whats the most creative thing you Accord guys have done to...
- How much additional HP and TQ will an AEM CAI give to a 6th gen Accord 4 cyl?
- can i fix my camber ???
- error code 17
- Lx Rims?
- definition of VTEC
- which bulbs are the brightest , 7500k ??/? NEED ANSWER REAL SOON!!
- Almost done
- check engine light?
- 96 Accord - 5 lug swap?
- single over head H22a4
- 94-95 Sedan Accord & Coupe Accords Front & Rear Bumpers - SAME??
- Has anyone had the gude head package?
- o2 Problems again
- 4th gen
- Starter for 1994 Accord V-tec?
- Lowest price RS-R exhaust for 94EX
- blown coil??
- I NEED SOME MODS for my car
- B series?
- Turbo Accords, did you have to cut the power steering line??
- My accord was OWNED by a curb; I would like advice
- where do i buy
- Junk Yard Intercooler
- what is the purpose of a key?
- 94-95 Accord Rear Bumper & 96-97 Accord Rear Bumper
- NEEWBIE NEED HELP
- just switched to synthetic.. have a few ?'s
- 98 seats in 94 accord
- VTEC WIRING
- Parting out 1994 Honda Accord EX
- h22a.org web board is down, so I have a few ?s about the swap into 4th gen Accord!
- Found a weird wire connected to fuse
- How to check trans. fluid on 98 accord ex v6. 2 different ways?
- After installing the v-tec head.......
- changed rotors and found cv boot loose
- coolant problem with 5th generation accord
- Proper Torque for 16" 5 Lug Alloys
- Thinking of a 1998-2000 accord v6 coupe..Comments!?
- Problem with 97 Door locks!
- 6th gen V6 exahsut??
- i want to know what are the best spark plugs for a 1998 accord 2.3 VTEC
- HELP! Check light!
- advice wanted
- Intake filter selection
- Need Help on finding Part on 93 accord
- 91 Accord EX
- Front door speakers in a 90 accord 4 dr
- parting out 91 accord dx coupe...
- How to replace temp sending unit on '92
- Engine coolant drain plug
- eibach spring question
- T25BB Turbo
- turn signal problem, no blown fuse.
- quick question about headlights...
- Easy brake upgrade for the 03 Accord...
- Misc. 96 Accord LX Coupe Accessories 4sale
- F22a4 to F22a6.... which ecu
- h22a in a 93 accord
- website help
- Flywheel?
- Someone convince me that OBD2 is soooo much cooler than OBD1
- exhaust system upgrade?
- Calibrate Speedometer
- tsx 6speed in accord?
- 3.0 V6 auto tranny where do i put the fluid in at????
- pulley torquing
- Pics of my suspension and S/T rear sway install ... beware 56k
- Model years and trim lines
- FYI - 97 Accord EX & 97 Accord SE parting out - Los Angeles Area
- F23 into 96 Accord question.
- Wifes '92 won't start! HELP
- Ingalls Camber Kit...
- Wheel width?
- Skunk2 coilovers & struts
- Any of you with coilovers take your car for suspension balancing ?
- SPRINGS
- 2000 Accord DX making a humming noise when driving
- Let's help my cousin out! Accord related.
- Good All Season tires
- sort of a newb question..
- mandrel piping/exhaust vs. stock
- coolant replacement q?
- bolt ons for 6th gen
- O2 Sensor
- washer camber kit 6th gen
- what type of motor
- 90 w hot cabin--won't start
- Jdm accord steering wheels?
- 98 Accord...no air out of center vent
- Turbo for f22a 4sale
- Manual transmission for a 97' LX
- underdrive pulleys...
- warning light
- should i get nitrous?
- Where U guys find your H22 engine ?
- Console Wiring
- Pulley Questions?
- Where is the plug on the 98 accord for checking the ecu codes?
- Buying an '03 Accord LX
- 98 accord ex v6.. can I put 215/60/vr15's on stock rims or 225/60/vr15's ??????
- Rough idle, shudder before lock up
- Accord parts fs, mods is this o.k.
- 94 Accord Paint Color Question...
- Anyone interested in a SOHC VTEC head? f22b?
- need: oxygen sensor '96 accord
- Easy suspension upgrade for 2003 Accord Coupes...
- will h4 fit in my accord?
- does higher octane really make a difference....
- Wierd sound when engaging clutch
- Help....P/N
- HID questions...
- broken headlight switch
- New Accord owner and site member
- f22 to build or NOT!
- weird squeak at driver side wheel when turning right, opinions please
- Planning to buy an accord and need advice...
- How bad is "limp mode"
- Sports Light Flashing... trans runs fine...
- semi-urgent: h22 questions
- 5th gen ex wheels on 4th gen accord
- OBD 2-1 engine/chasis harness compatibility question
- Brake lamp light
- Installed a new contol and cv questions
- reving idle at start up
- Need help with buying springs...
- front lip?
- how much power will a header give over stock exhaust manifold?
- Brake Pads
- RESTORE engine additive
