remove rear "H" emblem
as far as i can remeber, if your taking about the one located just below the upper edge of the trunk lid, then yes, i do believe there are 2 holes behind it, it would be best to take off the stock and maybe replace it with a carbon fiber or white honda symbol perhaps, something that matches basically, uhm, i could be wrong about the holes but im sure im not, just for the reason that i wanted mine to be clean, and it isnt so thinking this could be the only reason it isnt...! good luck with it, and i'll ask around some more for ya...!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KTeller8 »</TD></TR><TR><TD CLASS="quote">id only do it if i had some bondo and fiberglass to seal them holes up: Make it look clean not just like a vampire got a hold of your trunk</TD></TR></TABLE>
right...the holes dont magically disappear when you remove the H emblem..it's call shaving
well on the back of the emblem it has like 2 nipples which slide into the holes... so unless you take a sharp knife and cut the nipples off there will be holes left in the trunk lid. a good place to practice is the scrap yard...tried a few different things there and mine went over smoothly...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jagged4698 »</TD></TR><TR><TD CLASS="quote">well on the back of the emblem it has like 2 nipples which slide into the holes... so unless you take a sharp knife and cut the nipples off there will be holes left in the trunk lid. a good place to practice is the scrap yard...tried a few different things there and mine went over smoothly...</TD></TR></TABLE>
nope....the holes remain like the two holes that connect the forbidden ground some of us call the taint and/or chode....either replace them with the hated aftomarket emblems or bondo them, cause there not going away.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwogen1 »</TD></TR><TR><TD CLASS="quote">
maybe you should take off the emblem. leave the 2 holes there and put a 2 circles there so it'll look like b0obs
jk lol.
find ur oem color paint ##. and paint it over.. might be a good idea, might not. =\
jk lol.find ur oem color paint ##. and paint it over.. might be a good idea, might not. =\
greenCRV
May 17, 2006 10:00 AM
