View Full Version : Honda Accord (1990 - 2002)
- h22 swap
- 1st gen
- Help with front corner lights
- Sway Bar Bushing Size
- coilover help!
- Side view mirror
- taking out cruise control quick ?
- Seats from a 2000 bolt into a 94
- 2003 accord window rattle
- 1998 honda accord hood
- LX Z1 performance module ( garantees +22hp!!!) is this shit real?
- 91' accord engine wiring harness ??
- scratched
- CAN KYB gr2 handle H&R RACE SPRINGS?
- looking for best setup motor wise
- auto tranny on m accord is acttin up with mu turbo on
- 98 V6 options
- Accord Maintenance Required Light Flashing
- Which car?
- Getting ready to drop my obdI h23 into my OBDII accord.
- what to use h or f series tranny
- Short Shifter
- Help need instruction for replacing timming belt for 94 accord
- A/C Blows hot air
- Help w/ 94-97 shift linkage!!
- water leak
- Engine turns off while driving
- what kind of tires ? if i upgrade to 17''
- whats better the 01 2dr v6 or 4
- newbie here quick question
- Gear Shift lock
- Brake Lights out-wiring?
- APC intake recharger kit
- Tire psi question
- CAT-BACK EXHAUST?
- f22b
- 6th gen accord, auto to manual conversion
- Accord clutch dynamic?
- f23b1
- 99accord...Turbo/nos/f23 or h22s swap
- port and polished head install help
- Apex'i V-AFC Vtec Engagement Point
- How many Horsepower does an H22a4 have??
- h22 swap into 94 accord ex
- Body kits
- 94 accord, looking for a plastic piece for door.
- h22 accord swap--stuck. mount and wiring help please!
- 95 accord power window electrical schematic
- h22 accord need help
- Bolt Pattern for 2003 LX Accord Coupe
- New to the site
- power steering
- vtec
- Probelm with drop...It's uneven.
- 1999 Accord Coupe Ex (Manual) Keeps stalling.
- Stereo problem...
- WHAT SHOCKS R BEST WITH H&R RACE
- Blown Fuse (parking lights)?
- shaving door handles, and door trim?
- what else to change besides waterpump and belts?
- do these seats come from a 2003 accord??
- need help with doors
- Pulley Bolt
- PoA ecu... is this a accord ecu
- F20A DOHC INFO?
- Can the EGR ports still get clogged even after dealer kit is installed?
- rear disc brake conversion? (5th gen accord)
- CAMBER KIT INSTALLATION
- 83 Accord B-series Swap
- Accord automatic Reverse to park/neutral grinding?? plzz help
- accord brake conversion
- What vtec engine came in a 4cyl 95 Accord?
- 2000 Accord Code P1486
- after after market performance module???
- uni 4 lug accord 18 rims and tires
- terrible bouncing when releasing the clutch!?!?!?!
- Engine Stalling - 1991 Accord
- 98 Accord Transmission
- Accord abs
- sri question
- Easy job to clean EGR ports on 6th gen?
- Indiglo type gauges?
- how to swap 96 vtec to a 91 accord
- how to wire a 96 vtech to a 91 accord
- Noob here
- ACCOR EURO SPEC
- 5th ex wheel weight
- What to put in my 94' Accord EX?
- Check engine light on, mechanic said its not giving any codes...
- '99 Accord EX identifiers ?
- stock intake question
- Car throwing all sorts of "soft codes"?
- 99 Accord V6 supercharged or turbo??
- 91 Accord will start or turnover, why?
- "92 accord ex front bumper removal
- How to ID my 91 Accord Engine
- Who Makes Chips For Accord?
- Accord Chasis codes
- Is my axle bad??
- Seats?
- Directions to remove driver side mirror on a 2003
- wtb stock springs for 90-93 accord
- f22 manifold
- Where is "intake manifold" to clean out EGR port?
- Direct Engine Swap..
- CEL code 12 on a 99 v6??
- Rims??
- Car is hesitating...
- Need advice
- Euro R Intake manifold on an H22
- 94-95 accord w/ integra JDM conversion.
- H22 head on an F22?
- Road racing
- MSD ignition
- Chip upgrade
- OT: h22 in a beretta? haha.
- Header for 03 EX V6 M/T needed!
- help me build a custom turbo exhaust :D
- Intake filter part number?
- 92 accord xenon kit
- accord swaps
- Stock 2001 2dr accord front&rear bumper
- 89 and 92 accord top speeds?
- 99 3.0 v6, engine name?
- Inputting Stereo Code...
- Help with Mugen coilover?
- Help with Springs
- need help how to change front rotor honda accord 97 se?
- what muffler/piping for my custom turbo exhaust?
- rough running and no idle from accord
- jdm headlights
- 2000 accord rotors
- New brake pistons if brakes are heating up?
- 97 accord driverside power window
- Cheap/easy mods for 00 EX
- 92 Accord Wagon - Rear hatch wont unlatch
- Emergency Brake Question?
- 99 Accord Valves
- what are common problems with 91 accords?
- 92 Honda Accord Manual Question?
- 90-93 ex hp. question
- JDM Wire Harness?
- Strut Braces?
- i cant find transmission codes help
- When does the vtec initiate for a f23A4 engine?
- ECU HELP!!!!!!!!!!!!!!!!!!
- got a question
- DROP ???
- Check Engine - Emission Control???
- 91 accord dx Power steering problem HELP!
- f series
- will my 1994 accord lx tranny fit on a 1988 or 1989 accord?
- Bigg Engine Questions
- Delay in start....?help?
- spark plugs?
- f20b1
- h22 accord lx
- troubleshooting codes
- Installing aftermarket tach??(cant get a straight answere)!
- does a quiet exhaust necessarily = more backpressure
- Jdm engine swaps
- exhaust manifold heat shield.
- evap control system leak in 98 accord
- Removing the Upper Timing belt cover.
- Throwing Vtec head on a DX
- 4th Gen short shifter
- 4th Generation Accord Engine Swap
- Braking system
- DIY: Reupholstering my car
- Tein SS for track days
- What is wrong with this Honda oil seal?
- No Spark, or ECU codes 93' Accord
- suspension bushing question.
- 91 EX Blower motor test?
- hm i was thinking?
- New here, with question
- 7th gen wheels on a 6th gen?
- f29
- Speedometer adjustment
- drag vs fmax, the war is on
- apexi ws VS tanabe hyperM (exhaust)
- 90 Honda Accord Baffeling Problem!
- front bumper 01
- Redoing all body work tomarow, what primer is your favorite??/
- need help on mah brothers car
- Is it the clutch & flywheel not mating properly???
- automatic short shifter
- Need electrial repair recommendation LA/OC area?
- Strut Bar worth it? What kind?
- i need help with some questions about an '85 Accord LX
- Lightweight Power-Steering Pulley HELP!?!?!?
- Apexi WS coilovers......
- Stock shocks that fit a 94 accord
- Does the timing belt really need to be replaced?
- throttle body spacer?
- timing issue
- Help! Going to take a batt to my H22-a4!
- Does 01 front bumper fit on 98 accord
- Crank pulley?
- climate control, directional buttons not working?
- wat lowering springs 4* 97 accord V6*
- What to do first on a 99 accord?
- 93 accord 2.2 to a 97accord VTEch ??
- CODE E on stereo, 99 accord ???
- K&N cleaning kit for APC intake cone?
- opinion on a accord?
- 4th gen corner lights: replacing the bulbs
- Bosch ignitor????? 1993 Accord no spark
- Accord manual Transmission
- Programming a 04 key remote to my 97 accord
- how do i replace a Heater valve cable?
- 89 accord head unit
- -wrecked-
- HONDA ACCORD 94-97 HELM SERVICE MANUAL ON CD - Are these ok?
- Need a wiring diagram
- head on 91 accord EX
- Replace thermostat and now it's knocking
- 5th gen ex rear motor mount question
- belt pully removal on accord v tech
- no spark no fuel
- BAD GAS MILEAGE
- Engine Swap
- need cargo cover
- any 6th gens you know of that have been stolen?
- h22 swap
- Tires for 45+ Offset Wheels?
- 1980 Honda Accord
- i have a ? about the Vtech H22A
- Location of cabin filter in Accord 98
- getting the nut off of top of strut????? on 91 lx
- What turbo?
- f22b2 head on sohc f23 vtec block
- help my 95 ex
- Trouble adjusting Apex'i coilovers
- code 16 honda accord 90
- Apex'i VAFC for H22a
- What is the vtec engagement point for an H22a engine??
- How do I safely and correctly remove all five sprockets to replace the oil seals? ...
- Suggestions for good Swaybars for 1996 Accord
- Suspension tips/advice needed on ‘04 Accord Coupe 6 speed
- should I go with an Accord? pls help guys . .
- weird intake humming noise
- o2 Sensor out
- 98 Accord: Should I turbo?
- 93 accord - error 41
- Starting Problems '89 Accord
- fitment????
- Anyone know how to change the carpet?
- Power Down on 91 Accord LX
- need some help trying to put a a mazda motor in a honda accord 1990 Plz Help!
