View Full Version : Honda Accord (1990 - 2002)
- new accord owner help!
- Camber Kits for my accord
- *** Urgent: Help with Progress rear swaybar install ***
- 89 Accord oil leak
- had no choice but to post here
- how far will sportline go?
- Str fuel rail, AEM fuel pressure riser
- got wheel hop?
- 02 sensor
- torque specs on clutch
- best camber kit
- sportline spring installation
- 99 ACCORD EURO DASH
- idle problem!!!!! help!!!!
- 6th gen accord - 220-240 miles and the empty light comes on...
- 99 accord v6 Gas Gauge problem.
- Aem pulley belt size...
- Stalling Probelm on a '94 Accord
- Parting out my 94 White 4 door Honda ACCORD EX
- NEW does anyone have any suggestions on what to do to a 99 accord?
- Front Rotors and Pads Suggestions?
- 89 Accord high Idle!
- Key stuck in ignition
- Hyperground wires....suggestions
- Electrical problem
- How to remove 90 Accord trunk?
- F22 Performance Capabilites - experienced techs only please.
- oil pump cover
- f22 powered accord 1/4 times and hp numbers
- Please help me new, with Accord EX 1999 V4 coup. Please reply
- Air Intake.
- F22 turbo
- Anyone with regrind cam?
- starter
- IS BG44K what Honda uses in its "BG fuel injection and induction" service??
- CEL Code 90....what should i do?
- ::OT:: Minnesota honda owners!!
- 90K service, am I missing anything
- How to get drum off?
- Asking price of car Q
- 93 accord ex h22a swap
- clutch
- Clutch question
- RSX Steering Wheel
- Fans not working
- question
- 60k service, what is needed? 2002 Accord
- Help guys...oil is leaking...
- My 94. Maybe on the road again soon....need info
- Tire / Wheel Bearing Noise
- stupid question....
- I NEED HELP LOUD CLICKING NOISE FROM ENGINE WHEN DRIVING
- Were do I get these bulbs?
- Rods and pistons for the F
- HP and TQ curve drop
- My parking lights won't turn off!!!!
- Just popped my cherry! (mileage cherry)
- Dash lightbulb burnout
- Will a 1990 Accord EX fit in a 1990 Accord LX w/ auto tranny?
- window question
- stock coner light
- 1k turbo kit???
- help with transmisson
- Emergency Brake Problems in the Cold?
- car display on dash board
- H23 5spd Tranny Pkg.
- 1988 Accord questions
- Has anyone had this kind of luck?
- accord suspension question
- Need help removing dash trim...
- H22 or H23 tranny?
- accord trannies
- 90-03 accord seats all have same fitting?
- 5g abs removal
- quick dumbass question
- what is this ???
- 2000 Accord SE throwing CEL w/ 71k miles --- how to check the code?
- p72
- Idle on h22
- Acura Legend Injectors
- Vtec Head questions
- ODOMETER
- Turbo Accord owners
- 94 accord EX VTEC lost power.
- Buying an Accord, need some basic info plz
- Castrol oil question
- 1988 wheel studs
- How hard is it to replace outer CV boot?
- 2 Noob questions
- No idle when warm
- H22a into 6th gen accord
- 90-93 auto tranny?
- Camber Kits?
- light problem, need help
- Wheel offset for 6 gen accord coupe ex v6
- do pre 04 TL brakes fit accords?
- pspec tuning shifter
- A Question
- Post Pics of your Turbo Manifolds plz
- Question on shift lock
- Annoying Steering metal qeak noise
- Proportioning Valve or Brake Lines?
- port polished head install questions
- weird noise coming from the rear
- Need Help Installing...
- 5th gen Accord: Suspension people.. I got more questions.. =P, Help if possible.
- turbo h23 yes or no?
- Intercooler
- Anyone have 95-97 v6 oem springs??
- H22a 1995 accord
- I need to know what size injectors i need to match my turbo.
- 2003 headlight adjustment
- i don't know which accord to buy help
- Can you die(rethread) wheel studs?
- 2004 ex busted moon roof
- Specs?
- OEM Painted LIP
- Please post your personal experience with 16'' rims and a 1'' drop (6th gen)...want to prove the guy
- lose of powwer/compression
- Oil on spark plugs??
- sway bars... I need some opinions
- cruise control vacuum lines - HELP
- 4th gen brake swap
- replacing master cylinder
- advices please
- 94 accord timing belt problem
- does any one know how to fix Error code 12
- alarm problem...
- Check engine light on my 91 accord se when it gets really cold
- 99 Accord Short Shifter How does it install?
- 99 Accord Air/Fuel Ratio Gauge Installation
- axle replacement from hell, seized bushing
- Good Seat Swaps in 5th Gen
- HELP!!! Head Gasket may be blown?
- 1/4 mile times on a h22 accord 4 dr auto/manual?
- kyb agx vs tokico blue
- SIR Conversion,is it logical?
- 4th GEN OEM LIGHTS
- Need input
- Auto to Manual Transmission Swap
- LED dash lights
- Problemo with steering on recently bought accord
- New Struts and New Sound Along with em
- 2001 Honda Accord possible transmission problem?
- Help
- SRS light throwing code 11, WTF is that??
- Instrument bulbs
- I NEED HELP WITH 93 ACCORD OIL LEAK!!!!
- can this be done-vafc question?
- 1990 LX HONDA ACCORD
- losing power
- Need Help/Advice!
- Need some advice....
- catalytic converter and more torque
- Wiring problem in 90 accord...
- Brake Light Out
- where did it go
- Tire Rotation
- instrument cluster
- A/C compressor bracket studs
- valve adj.. now problem, help appreciated..
- Urethane Bushings
- Brake Lamp?
- cleaning your headlights
- NOLOGY Wires
- Check this link out. Accord motors whats this f22b DOHC ?
- turn signal switch
- better braking power 95 accord ex v6
- question on a highflow cat.
- 1993 Accord headlight
- chicago accords check it....
- turbo manifold?
- weird grinding noise
- All of you JDM accord Fanatics.. The SPOILER to beat all
- 94 ex coilovers
- what might be wrong with my gas guage? always goes to E when i'm not empty
- weird problem, engine smoking
- tight gas pedal
- OBDII to OBDI distributor
- a wastegate
- 95 Accord electrical problem
- 03 Accord Injector rate
- 94 Accord Accident
- Is it code 01 or code 10?
- SOUND FROM ABS UNIT?? HONDA SAYS NORMAL, I SAY B.S.
- looking to buy '94-'96 accord..help??
- looking for 90-93 accord front end parts- texas
- need help, clutch gone?
- Timing
- Accord mini-me head swap ??
- Injector question
- My new 92????
- OEM shock alternatives on a 6th gen 4 cyl??
- Powder Coating 94-95 Accord 7 spokes Rims???
- shaved doors
- Fuel Burning right? FPR working right? Help on this please.
- problem with V-AFC II, anyone got one, got any experience with it?
- How to remove stuck cd?
- need help finding location of fuel pump wire(installing kill switch) 5th gen
- steerinig rack removal
- No power in first gear
- What is this and why isn't it hooked up?
- Clutch or Transmission problem?
- What is this ?
- In Need of 95 stock ex accord wheels or 96 prelude stock wheels or maybe even cl 4 lug
- Noise coming from the engine???
- Ngk Spark Plugs and Wires
- New Fidanza flywheel
- Need help with stalling 98 Accord
- Anyone bought a rebuilt tranny from honda?
- steer problem?
- accord stalls when the Alpine head unit is on for more than ten minutes--
- whats the stats on the 99' accord ex
- Accord Racing
- 92 accord auto to manual swap
- Accord died. No spark.
- Headlights?
- h22 swap or turbo?
- accord short shifter write up, anyone got the link??
- Need 94-97 Accord Help!
- accord 95 V6 engine swap?????
- Bad Axle Boot
- I need an opinion
- Need 96' Accord LX v6 specs!
- Good Struts to go with Neuspeed Race Sprigs?
- 94 Accord Front End Noise
- Coilover rates for GC?
- 4th gen trunk lid
- Yellow vs Illumina vs AGX
- 1995 Accord sedan... where's the ECU?
- Polyurethane Bushings Question
- what is the best lowering springs
- 92 accord ex valve spec???
- 2003 Accord Setup
- Timing Belt Change - cam gear mark alignment?
- timing belt problem HELP ASAP PLZ!
- head porting and/or camshaft gains....any dyno sheets or track results?
- 2000 4cyl Engine Swap
- Rim size question
- broke a few valve cover bolts...help?
- dsm headers?
- where can i find this?
- 96' accord LX Interference engine ?
- Main Relay problem? in the cold?
- Cheap Wheels
- i got my koyo radiator installed
- tire pressure
- 99 Accord EX Auto 50,000 having shifting problem. Any thoughts?!?
- Are 92-93 headlights the same as 90-91?
- 93 lude knuckle/hub/brakes into my 93 accord?
