View Full Version : Honda Accord (1990 - 2002)
- need help on F22A1 and F22A4.
- idling/reving question
- new problem after the accident...
- H&R springs
- will this work?
- accord blower motor makes funny sound
- accord antenna making a loud sound
- advice on some rotors and pads
- New Spark Plugs reduce mpg ... any advice?
- average price for a new clutch+ install
- problem with the radio !!
- will civic coilovers fit on a honda accord
- ACCORD'91 ignition coil problem
- BLINKING "D4" LIGHT! ......HELP!!!!
- How hard is it for a novice to pull the cylinder head off 91 Honda Accord
- wtf, 2000 ex sedan with *no* srs light?
- What seats fit?!?!? *need help quick*
- will this motor fit....
- accord engin swap ?
- Headlight upgrades
- 95' f22b1 swap into 92
- 2005 honda accord integrated hands free cell phone
- 94 Accord LX Braking issues
- Need Advise on engine work
- 91 accord ex just died - help
- Where does this piece go?
- How to remove A/C in 97 accord of TURBO
- Suspension options 4th gen accord?
- DIY Blackhousings
- compression on F22A4
- will a 2002 fit in a 97
- oil light
- Accord trans problems vs Camry oil sludging
- Who likes their stock radio
- Pin striping removal
- HELP ME PLZ!! Headers on 88 Accord
- pics of bronze/sports bronze slips? (searched)
- f22 cams???
- California Front Plate Petition
- 94-97 accord axle back
- Need help please
- White smoke and water coming out exhast with no water in oil
- so i got my wheel alignment redone today...
- speedometer
- anyone try Brembo slotted rotors?
- What Mod first?
- will a f23 header fit a f22b2 ?
- Cooling fan motor, bumper, and headlight removal
- what the differents between F22A1 and F22A4
- problem with brakes.
- Turbo my F22 NON V accord
- Stuck in D4
- Removing door panel in order to take off door trim to paint.
- 1998 Honda Accord Service Manual
- Poor idle after fuel pressure regulator replacement
- Transmission won't shift into overdrive
- ROYAL PURPLE FUEL INJECTOR CLEANER. Is it any good?
- Intermittent hesitation on 90 Accord EX 5 speed
- i need a f22
- H22 With F22 tranny?
- who was selling a f22b2 turbo manifold that was cracking ?
- RS*R VS. APEXi exhaust
- camber
- not shifting
- vasaline on the car!!!! bad
- will no speedo cable cause
- Front speaker removal in 2004 Accord?????
- How to strip my 94 accord
- exhaust 2 engine question?
- injectors
- Turbo'ing an f22
- Tapping noise from alternator
- clear coating a accord
- K20 engine drop for accords under 7th gen.
- Probs with New Slave Cylinder
- Stock f23a4 turbocharged? good idea??
- wheres the clutch adjustment on a 95 accord lx
- built h22a
- Engine Swap?
- VSS out of a Z6 in a F22
- So my girlfriend crashed my accord...
- 2001 Accord Transmission - Yes It's Been Covered - Read Anyway
- Looking for a non V-Tec camshaft.
- Fuel injector cleaner, gas treatement...etc..serve a useful purpose?
- Please help, this is driving me crazy!
- cut off rusted part in rear quarter and weld in used 'piece'
- 2000 Accord Transmission
- timing belts seals question
- Head Bolts
- Temperature guage quit working (Pegs out at high Temperature)
- Sport Mode!!??
- How to take off Intake Manifold
- Accord check engine light
- Changing Brake Pads
- Check engine light on pulled codes have ?'s
- http://www.turbodrift.com
- Need V6 Help
- Car hesitates...idle problem or something else ??
- Picture request
- Opinion on Projectors
- f22 build help!
- 5TH GEN DOOR HANDLE
- Apexi N1 and custom piping from Kteller?
- Navigation System in the New 03+ Honda Accords...
- Pistons!
- ABS
- Handbrake light & ABS light - 5th gen
- installing driver side mirror
- day time running lights
- f22b2 head cc?
- 1994 Accord EX Ideas and Suggestions.
- Check Engine Light.... Code P1457
- Installed CD player - Tails and dash lights went out. $5 paypal to anyone with the answer
- is this a good clutch??
- Accord Handling
- F22B DOHC non-vtec or F22B1 SOHC VTEC?
- interior door handles
- WRECKED!!!!!!!!!!! My POOR POOR ACCORD....... pics inside
- average price for h22 swap
- Easy performance upgrades for a 92 accord sedan lx
- 419 miles!!
- Replacing Rear Brakes on 2003 Accord
- Torque Specs for a few front brake assembly
- 1992 Accord fuel relay
- 99 Accord LX Errors!?
- going turbo soon need some adivce/ help
- steering wheel
- 18inch rims and suspension in a 92 acc sedan
- question about parking on a hill?
- Oil leak
- horror $$ story... any advise?!
- I have a accordperformance head package and now i want to add nitrous
- How much can I lower my 5th gen?
- I wrecked my accord- headlight question
- Remove rear seat, 2001 Accord
- 92 LX EGR valve cleaning problem.
- STRUT BAR ??????
- engine code 1992 accord ex
- engine knocking/clicking
- can no speedo cable cause
- HKS bomb muffler
- idling
- is it hard to bleed the clutch?
- 2003 accord brakes shudder when slowing down
- Muffler issues
- ignitor heat sink?
- audio related Q.
- 2000 accord power window main switch...need help
- conflict within h-22 ot f-222 turbo
- Accord Hesitates while accelerating - Help!
- suspension for 02 accord 4 cyl
- climate control for V6 or 4 cyl 98 acoord?
- Accord REAR LIP 94-95
- H22 Head
- Lowering the accord????
- F22A4 into 91 Accord LX
- F22B1 Swap Question
- Specs on F22A
- F20B vs H22a
- need help with front brake rotors on 1995 accord
- rear brake rotor/pad change, '96
- F23 people enter here:
- ICING ON THE INSIDE OF THE WINDOWS
- '94 Accord w/ 150k, preventative maintenance?
- Honda Tranny Re-call??? PROBLEM
- Auto Tranny
- basic cb7 ?'s
- cai + inner fender liner
- Advice on car trade Accord for SI Hatch
- 2000 Accord Engine Code
- clutch decision...
- ok
- Engines!
- bilstein + neuspeed ??
- Springs are tight
- Coolent leeking
- turbos
- what is this
- I need help! Engine/Transmission help!!
- Help, searching for full exhaust system!!!
- witch is better for a turbo
- Help!!!!!!!
- Spring Rate question
- how much does OEM slave/master cylinder (clutch) cost?
- nashville people and surrounding area
- headlight swap
- Engine is acting funny. what is the problem?
- h22 head vs. f22 block
- front end alignment
- Question about Torque
- Gas Mileage
- Pics
- Anyone hardwire a Valetine 1 on a 2005 Accord EX Coupe V6 6 speed....
- my beast
- 99 Accord power door locks
- combination switch prob very weird....
- When putting gas in my tank..........
- mY PEDAL STICKS
- H22 header fit F22?
- Need help hooking up my vtec controller
- Combination Switch going bad
- Trying to Figure out this system Header, Cat Exhaust??? someone help.
- Cd7 jdm h22a swap question
- Auto -> Manual Conversion
- front bumper
- head gasket maybe??????????
- Disabling EGR Valve on 2.2 Liter
- Suspension Questions
- Questions Lots of Problems No Answers
- 96 Accord EGR Ports Plugged??
- how hard is it to do a automatic to manual swap in a 92 accord
- Tanabe USA looking for new contact
- PLEASE HELP ME TO FIND MANUAL FOR "ECLIPSE CD3403" HEAD UNIT ! ! !
- Blanks rotors vs. slottled vs. drilled....much of a difference?
- Camber kit Q?
- I never post here but have question on 98 Accord's speakers
- check eng. light?
- diy itb's?
- Tourque specification...
- clutch slave cylinder install
- Drove 92 Accord into water, auto-tranny shifter won't budge
- 4th Gen jumps forward when shifting from Neutral
- 97 check engine light
- RPM GOING NUTS
- rim size choice
- I have this problem but don't know what's causes it.
- eibach sportlines w/ tokico whites on a 6th gen coupe... Thumping?
- I have a problem with the belts i think!!!!!!!
- Alternator question
- 94 Accord EX
- SCREAMING BELTS
- Times for H22a's in a 5th Gen (94-97)
- This should be an Easy Question
- Back Lights on Dash and Guages. . . L.E.D.S.
- door handles
- Ok quick Q?
- 1996 Honda accord Harness...compatible??
- 2000 Accord V6 Transmission Rebuild
- chassis code for 6th gen?
- Cluster Gone Bad and rev limiter in a 90 accord dx 5 speed
- 96 Accord LX Fuel System Trouble??
- HEADER HELP
- No idea where to post this
- My stick keeps getting stuck!!!!!
- Putting a stereo in an 88 accord
- - Gauge Cluster Gone Bad - 1990 Honda Accord EX
- my ignition key is stuck help
- AIT Sensor tricks
- Turbo H project finished...for now. Pics and setup details
- another use for pillar guages
