View Full Version : Honda Accord (1990 - 2002)
- tranny fluid change
- maf in the way?
- Check Engine Light???
- Just finished tranny swap in 97 Accord LX but no speedometer...
- wiring harness question...
- 1999 Accord lx auto to manny swap......HELP!!
- 94 Transmission Swap???
- Frozen Caliper Pin
- 90-93 Blower Motor Removal
- look for head setup and turbo kit for f23a1 motor
- 2000 Accord lugs I4 vs v6?
- 1998 Accord Alternator Problems
- condensor fan question
- Are civic tranny's the same as Accords(manual)?
- Anybody ever go to canada for a motor?
- Help with Rota wheels and Neuspeed suspension...
- Is there anyone knows the man who works in honda bodyshop in ottawa?
- engine reving up and down on its own
- Is the accords engine bay big enough...
- wiper issue
- NEED SOME HELP!!!
- 4th and 5th gen knuckles interchangable?
- just purchased a 94 accord
- Can I use these projector with an HID bulb
- need help in buying in a new LX
- v6 and i4 same suspenison?
- Can I run without a muffler?
- Anyone here no about codes and distributors for Acura Legend 1990
- cali ppl post ur sale items
- Starter - 96 Accord LX Manual Trans - DIY?
- 2001 Accord V-6 Auto to Manual Swap...
- Was the Bumper Pole an option on 5th Gen's in Japan???
- taillight help
- What are the requirements to sell items here?
- Oil pan...HELP!!! QUICK!!!
- Opinions Please!!(which cat-back w/ aftermarket turbo?)
- 2003 engine vibration
- Yet another hard start - stall thread
- Auto to Manual swap
- Honda Accord TPS (Help!)
- Omni power coil-overs
- Pissed: What can cause premature Throwout Bearing wear?
- DSM mani bolt up to a 92 Accord EX?
- Lightened Flywheel?
- f22 or h22??
- F22B1 and F22B2 Engine Info + H22 Head...?
- spun bearing?
- gas tank capacity for 1983 Accord
- HELP! How do I take out the headlight housing???
- Coolant temp sensor SNAPPED OFF
- 1995 Honda Accord Rims/Stud measurements
- NEed INfo about F22b1 internals.
- Radiator fan noise
- Problems with Sports mode (yes i did a search already)
- Camber kits for my my wife's lowered Accord on Volks?
- Problems with Axle's
- How much horse power can i get
- 97 Accord Wagon EX - Airbag SRS light is on - WTF?
- 87 Honda Accord Alternator
- 1994 EX/LX exhaust manifold swap, o2 sensors different?
- Bench Bleeding
- can't start car
- used 6th gen coupe questions
- I AM DOCKING POINTS!
- engine swap
- F22b1 booost???
- N1 Question
- Bad Axle?
- Accord VTEC head swap
- accord/civic dizzys
- Starter Problem
- closest gear ratio accord transmission
- 1988Honda Accord-keeps stalling when not in motion
- V6 or 4 Cycl.
- dumb question, right here
- Finished 6th gen Accord swap the other day......Just wanted to do a rundown
- Grounding in the cab instead of the engine compartment?
- h22 accord 1/4 mile time
- Honda Accord Service Schedule
- main starter relay on 92 accord
- Motor swap question
- 96 accord wagon coming soon | questions about swap ....
- will bumper fit????
- Bolt Pattern for a 1994 accord (looking at a set of rims\tires, need quick advice)
- Finding Machine Shops
- Oil on spark plugs
- Still getting crappy MPG :( -- 92 Accord DX 5spd
- Exhaust ? 92 accord.
- door stuck shut
- DIY site?
- how much to fix
- 01 2door V6 questions
- eibach on 95 accord question.
- 94-97 Accord mirror question
- Knock Sensor?!
- Power steering on my 2000 accord v6 is making a grinding sound.
- Wet sanding...
- 2003 LX V6 or EX V6?
- h22a problem
- help ME!!!!!!!!!!!
- Wrecked Honda???
- changed radio- intrument lights dont work
- 2004 ACCORD STARTUP IDLE
- people with h22 4 door accord
- Upgrades
- IM issue
- Need confirmation! Alpine 6 disc will work with factory head unit in 92 Accord EX-R?
- Resetting the SRS
- 1991 accord Auto to a 5-speed H22
- 1995 Accord lug pattern
- Does anyone know about transmissions?
- motor mount for a 98 accord coupe
- f22 dsm turbo engine management
- How can I reliably increase power in my 03 V6 Accord?
- accord squeeels making right turns
- ECU?
- worth $5k? check this car out
- blown head gasket info please...
- motor swap question
- carbon fiber lip
- V6 tranny problems
- need a p28 ecu!!!!!!!!!!!!
- free tuneup
- Can this happen
- Automatic Transmission problem in 90 accord EX
- wiring diagram for speakers
- 95 accord ex automatic won't shift gears?????
- Electrical system question for '90 DX Accord
- CB7 headlight bulb removal?
- How to remove the rear door panel on a 96 accord EX 4 door
- tranny problem
- Transmission question (I THINK I NEED A TRANNY MOUNT)
- '99 lowering springs question
- VAFC PROBLEM ON ACURA CL SAME AS 94-97
- Front Brake Pad for 94 Accord LX
- 1998 Accord with 76Kmiles what maintenance should I do?
- Brake Pads?
- 1999 Accord Transmission Issue......
- Cruise Control Dead.
- Will 94-95 Accord tranny fit 91 Accord? 5-speed
- no cai for auto accord?
- H22a with tranny
- ringing.....bad water pump?
- cold air intake question?
- May Score A Free 1991 Honda Accord Ex - Need Your Advices...
- Engine build up question
- jdm f22b dual cam 2.2 . Lookin to purchase a turbo setup...could anyone tell me if this has been don
- can bad ball joints cause slight clicking when turning??
- exhaust from a 97 civic to a 5th gen accord??
- Ignition cylinder lock removal on '95 Accord please help !
- whats the difference between ulev and non ulev
- Exhaust system
- 99 Accord V6 with VAFC, bad gas mileage?
- Retarded Springs... Calling out for help!
- gas gage problem
- rear upper strut bar
- 90 built accord, needs to rev past 6500rpm with a PJ0 pleez heelp
- Signal Light
- 99 honda accord ex v6 transmission question\possible problem...
- F22b vtec supercharged
- changing axle shaft on my 88 DX ?'s
- Wuts the color of this car guys?
- 90 According leaking coolant
- transmission code/model number???
- 97 gas leak
- I need info where to buy 92 honda ex v-tech
- 92 honda accord lx Have a problem with shifting
- 05 2Door Accord V6 6 speed... potential
- FOR SALE 90-93 ACCORD STUFF
- Wheels
- brakes lose power...can feel no pressure
- taking apart 4 gen dash
- MTF Recommendations....
- 91 Accord Alternator/transmission problems
- '95 accord LX V6 (AT) won't start?
- Cruise Control Problem
- i4 honda accord
- Dropping transmission
- axle nut 1993 accord
- Tune-up and interior part replacement questions
- Rear brake shoes Accord 96
- ? about manuel converted accord<<<
- 7th Gen Accord Info
- 94 Acccord EX (VTEC F22B1) Oil Pressure Light HELP?!?!?!?!?!?!?
- top strut bolt came off
- Code P1457 EVAP Help
- Accord 03 engine/gearbox vibration?
- need a diagram of frotn driver susenpion
- Burning oil?!?!?
- Steering click
- Cruise control prob
- motor mount torn... the one on the subframe
- 3rd gear seems "sticky" or grindy??!?
- Brake light switch???
- Are there cetain spark plugs noticeably different than others?
- 92-96 prelude front strut bar fit 94-97 accord?
- Tein springs, 2"drop, do i really need a camber kit?
- problem with check engine light on and D4 blinking
- installing aftermarket radio
- rolling fenders
- Smell, and steam from engine
- dsm manifold on f22b2
- engine diagram.....
- Accord seats
- K&N Filter
- Back up Lights
- Newbie, need help
- Injectors for F23A4 Accord
- f20b head on f22b1??????????????????
- Charging system not working. All fuses good....
- The new swap in my accord -- F22B1 :)
- Speedo jumps from 40-50
- Anyone near Tennessee or Like to Visit for this event
- Commpresion ratio on 97 soch vtec f22b1
- lowering my car?
- vtec controller
- Newbie help with h22a
- 91 accord..needs exterior help!!?
- 99 Accord Problems...
- mugen lip
- IAC valve modification
- Gen5 Gauge lights/bulbs
- Fuses
- 01 Accord, Hydraulic lifters or not?!
- quick question
- F23 vtec into obd1 accord???
- Yet another post about gine swaps
- Some Help
- ? about signal lights on 96 ex
- MSD Ignition on VTEC
- Accord hybrid
- My 93 accord is overheating....NEED HELP!
- idle surge, and lower gas milage?
- 1994 honda accord wont start! replaced starter still no dice...please help
- 1980 Honda Accord
- 1997 Accord One piece headlights
- hood for 2dr or 4 dr
- 2000 accord - need timing belt?
- painting the accord
- BUILT TO LAST............
- COilover installtion Help
- is it true about the 2002 accords
- SRS light stays on, odometer and clock backlight problem
- '94 Accord LX auto- rpms at 70 mph??
- NEUSPEED Sport Springs???????
- BLINKERS ARE SCREWED UP, HELP
- matching numbers
- 91 accord here....NEEDS HELP!!! PLZ
- NorCal: Generation 7 Accord Meet Coming Up!
