PDA
View Full Version : Honda Accord (1990 - 2002)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 [333] 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372
  1. Misc. Accord 4gen questions...
  2. whats the engine code?
  3. FS: Unorthodox Pulley
  4. '94 Accord ECU, what does it control (for switching to standalone)
  5. Links or sites for 96 V6 Accord don't know anything about them
  6. 95 Accord Tranny Swap
  7. 1997 honda accord Problems?????
  8. 90 Accord, Transmission Problem?
  9. 97 Accord LX wanting to do a 4 wheel disc conversion
  10. Weird Start
  11. measurements for stock sway bar?
  12. Help on deciding 1997 Accord suspension set-up...
  13. which exhaust system is better?
  14. Turbo 6G F23
  15. does the 90' accord ex sedan come with nissin or akebono calipers
  16. Help - Engine compartment connector pinouts?
  17. 98-02 accord with Kosie K1's?
  18. 03 accord coupe i-4 exhaust tip
  19. Engine sounds like it revs really hard!?
  20. Where to get a Turbo cheap
  21. Lets discuss the most usefull stuff for accord
  22. Installing Supension Technique F/R Sways lx/ex owners read please
  23. 93 accord trouble starting
  24. can motor mount cause this problem?
  25. H22 Knock Sensor relocation question...
  26. question about wheels for accord?
  27. dropped motor
  28. Which 5 speed to swap in for use with nitrous?
  29. Cant get back rotord off!!!!!!!
  30. 5 lug conversion
  31. Loss of Power and Backfiring
  32. Dual Overhead Cams on H22
  33. brake light problem....please help
  34. What's better than an Apexi V-AFC?
  35. 94 Accord leather seat wiring...
  36. 93 accord DX... will alarm work?
  37. 94 LX change to 94 EX questions...
  38. F20A VS F22B
  39. A/C problems...
  40. camber kit install problem
  41. engine change (your moderator says to read this)
  42. Suspension / Spring Rate Question?
  43. Whcih swap would be best for me?
  44. fixing a 1993 accord power mirror
  45. 03 strut bar question
  46. 93' Accord vibration
  47. Whats the deal with bumpstops?
  48. vacuum diagram
  49. How do I remove the Clock (00 accord)?
  50. What best mod's for my honda???
  51. EVO vs. World Sport
  52. Transmission in accord help please....
  53. Check Engine Light
  54. I need help now!!!
  55. axles
  56. Suspension/camber kit question
  57. h22a
  58. Brakes
  59. 96 Accord SRS light
  60. Problem starting when cold
  61. Strut Rod nut torque? 90 accord
  62. How to install white guages?
  63. Zeal front bumper questions
  64. Anyone done a level10 upgrade?
  65. How to check if A/C is leaking?
  66. 1999 Accord EX Idle
  67. How to get the ABS codes?
  68. Intake Manifold; Cant get t seal!
  69. motor mount h22a
  70. I would like some advice as to engine mods
  71. On the road again.....
  72. About HID
  73. Honda electircal problem...help pleeease!!!
  74. Auto to manual swap on 97 Accord LX
  75. do the 96-97 tail lights fit 94-95 accords?
  76. 6 Gen Accord h23a dohc vtec swap info ~tried search~
  77. 1993 Honda Accord EX
  78. Springs
  79. Front Exhaust Pipe on 90 Accord
  80. Instrument CLuster
  81. AEM pulley vs. Unorthodox pulley
  82. fuel pump
  83. anyone here damage their koni by lowering too low? or cause by bad road?
  84. 2003 V6 6spd. Upgrades??
  85. swap ?
  86. cam help
  87. steering wheel question!!!
  88. 90 accord motor
  89. Accord pullie
  90. Hesitation
  91. 97 accord throttle body onto a skunk2 intake manifold for b16a?
  92. 2003 accord suspension componenets
  93. I got rid of my Accord and got an..
  94. finished h22 car swap but?
  95. speedometer light and SRS light problem
  96. Please Help With Idle Problem
  97. engine backfire??
  98. 99 accord check engine light
  99. air conditioner
  100. Quick intake manifold question
  101. Y does the rear 1/4 panel rust out b4 others do?! Plz explain?!
  102. My '91 accord ex coupe weighs 2130lbs......
  103. driving problem
  104. car wont start
  105. another accord to join the darkside...
  106. black smoke coming out exhaust
  107. Turbo Charge a 93 Honda Accord LX 2.2L
  108. 2001 Accord Camber/Caster issues?
  109. 2000 Accord EX automatic trans troubles
  110. JDM H22A Gas requirements?
  111. boosted sohc auto results... decent..?
  112. D4 light blinks...
  113. h22 swap in accord
  114. Shocks maybe the problem
  115. h-22 from 2000 prelude type SH swap questions
  116. Shifting from Park on 90 accord
  117. Valve Adjustment specs on a f22b2 (94accord lx)
  118. Rear Lower Control Arm - Help?
  119. camber kits for 02 ACCORDS?
  120. maint. light...
  121. My car is beginning to break down finally?!
  122. A'PEX Super AFC Digital Fuel Controller
  123. HELP!!! Rubbing sound after ST sway bar install
  124. Battery Relocation Kit?
  125. Installing new seats
  126. Skunk2 H22 Dyno PICs and INFO
  127. motor swap
  128. SRS light
  129. auto clicks like a manual when shifting
  130. well the headers are installed! but a garbage can tipped from the wind :(
  131. Accord is having some SERIOUS issues starting.
  132. How many wires on a 5th gen o2 sensor?
  133. Who has the most miles?
  134. How to turn off ABS?
  135. Door panel removal 91 accord
  136. Anyone have a camber kit? Do they smooth out the ride?
  137. Need info on how much this car is worth. Need replys quickly
  138. oil in coolant
  139. Something weird when I check engine code*NEED HELP*
  140. 94 accord Lock Mechanism
  141. Radiator fan compatibility
  142. Help!! Brake Piston!
  143. Is it even REMOTELY possible for a stock '90 DX sedan 5-speed to run a 16.5?
  144. Vtec this
  145. Very strange problem - PLEASE HELP!
  146. someone help me outz!!!
  147. Need Reset Directions for Chk Engine Light for 2000 Accord
  148. Chaning Tranny Fluid
  149. Ground Control & KYB AGX Install
  150. 3rd gen 86 accord
  151. Blown head gasket???
  152. v-tec has stopped.
  153. 91 Accord front brake job
  154. Idle fluctuates at standstill/ IAC valve help?
  155. will they fit?
  156. KYB-AGX for 6th gen accord???
  157. Torque converter question?
  158. VAFC on h22, just a quick question.
  159. how to replace oil in the A/C compressor?
  160. h22 swap question
  161. 4g 90' Sedan speaker size
  162. car lags around 5k rpm help!
  163. Accord wheel bearing HELP!!!
  164. h22 intake manifold
  165. OEM Wheels, What will fit a 92LX?
  166. friend's 98 accord engine blew, H22 sitting here, need some help on installation. thanks.
  167. factory radio retrofit
  168. Bright Headlights?
  169. balance shaft mark for 95 accord
  170. looking for ANY place to buy an f series engine in the future WHERE?
  171. TEIN Basic Coilover System
  172. How to fix those annoying squeaky seats!
  173. Another wierd idle problem...
  174. H22 into 98 Accord
  175. 3.2 cl type s ???
  176. F22 into 92 4-dr automatic
  177. Tokico HP Strut Kits
  178. Crankshaft pulley
  179. RS*R Down/Race springs
  180. H22 from a prelude sh
  181. KONI VS. KYB GR-2 (yeap did search for 20 min)
  182. pics of my crashed up accord :-(
  183. Venom Performace Control Module
  184. Gay tegg wants to race.
  185. Suspension !Help!
  186. 91 Accord Starting Problem
  187. H22 Injector question/problem
  188. where can i buy mini temp reader?
  189. Sprint Sports with a 2" drop in Front and 1.75" Rear/H&R Sport Springs
  190. rim question on 5th gen
  191. Help a noob out please! -= Heater circuit malfunction=-
  192. Kyokugen lug nuts
  193. Fireball Cat Back Exhaust
  194. KYB AGX not available
  195. anybody using a neuspeed n2 header?
  196. will b16 or b18 engines fit or make fit in my 89 accord
  197. Megan Exhaust?
  198. Dual Muffler?
  199. DSM turbo completed?
  200. Just got back from curry's
  201. Opinions on Mugen Twin Loop exhaust?
  202. f22a4 or f22a6 ecu in f22a1
  203. fast idle valve
  204. 6 th gen Bottom End
  205. help on port and polishing
  206. Tranny Issues
  207. Value of 2002 Accord?????
  208. Axxis Ultimates
  209. Turbo Choice Dilemma
  210. front wheel bearing
  211. What kind of exhaust?
  212. misc. question?
  213. dash problems
  214. serious problems.
  215. where can i get an h23 for a decent price.....
  216. Stock Radio Code?
  217. Which is a better header Ceramic or Stainless Steal??????
  218. will 92-96 prelude fr seat fit in 94-97 accords?
  219. coilovers
  220. Possibly installing H22, what parts will work off the f22b1?
  221. Expert transmission help?
  222. AC Knob Controls
  223. Shifting
  224. 94- 97 Accord stock muffler
  225. Weight reduction on 5gen accord?
  226. Getting a wrecked 93 for free
  227. ABS light on
  228. what lips will fit on my 4th gen?
  229. tokico performance
  230. Severe rust on 4th gen, beyond my ability to repair?
  231. wierd idle
  232. Tranny worries with big boost
  233. removing headlights?
  234. H22 Radiaotor on a F22A1....Just have a couple of questions
  235. What is a I/H/E and how much does it cost for a 2002 I-4 Accord Coupe?
  236. Exhaust Question
  237. oil on plugs seat
  238. still doesnt feel right
  239. For those of you whom missed the UK Honda Commercial
  240. shocks
  241. Little Engine help plz
  242. Accord/Prelude Compatibility
  243. What are the diff between a 91 accord auto tranny and 97 ex accord auto tranny
  244. put in a new speed sensor, now my cruise control doesn't work - do i need to reset ecu?
  245. vtec head on f22?
  246. head avail for f22?
  247. Apexi WS question?
  248. f22a1 engine swap for a h22
  249. Accord Turbo
  250. Comparable wheels to TE37s?
