View Full Version : Honda Accord (1990 - 2002)
- accord gauge
- needing new axles
- 205 55 16
- want new tires, will they fit???
- 89 Accord exi - Need Tranny advice
- I Need Accord 89' parts!
- 94-97 Accord Anti-Roll Bar
- What can be done to an 83 Accord?!?
- wheel and tire size help
- Steering wheel?
- speedometer stopped working...
- .. camber kit for 2000 accord
- good shocks for sportlines?..
- Initial Startup
- shelf life of oil
- Door Lock ACTUATOR -- Someone please help???
- 97 Acura CL 3.0 v6 Auto battery indicator light@4k rpm
- Any available intakes for the Accord 2003 V6 coupes?
- 96 Accord LX Exhaust - what brand?
- Odyssey motor -vs- Accord motor.
- Couple of questions...
- offset/camber question
- 96' ex swap
- 88 LXi clutch cable problems
- Door Lock Actuator Help
- springs
- bad squeaking noise.....help!!!!
- Seeking advice from the experts here on '95 EX with 5sp
- odb2 h22a4 into an odb1 accord
- climate control prob.
- 195/55/15
- turbo f22b1
- Q for people using DSM manifold.
- Help on Muffler
- Air Filter?
- What the EGR valve does to your intake manifold.
- Can i chnage to synthetic from regular oil
- 94 Ex
- 91 ex
- Fmax vs DRAG
- Need hands here, pls
- h22 tranny on f22 motor
- sunroof
- Transmission types
- Tune Up Time
- 2002 v6 dual exhaust on a 4cylinder?
- stuck tach needle
- HP gains from removing Cat?
- A couple 4th gen questions...
- front brakes
- Water + Turbomanifold= ?
- 97 Accord fuse panel
- SLICK 50
- gude camshaft and nitrous
- accord and prelude tranny(auto)
- Had my accord dropped and want to know what the noise is :X
- Help on H22 swap into 6th Gen LX Auto
- 3rd GEN Accord Owners Need answers
- Code 6-87 accord
- 5w30 vs 10w30
- New car purchase
- 1990 Accord Start-up/Idle problems Help needed.
- First time install of accord starter...
- oil link, can't find where it's coming from...
- does the sohc f20 use the same timing, and water pump as f22
- Best route to a faster accord.
- OT how do I become a member?
- turbo
- Auto to Manual Swap
- 94 accord LX question
- Is this a good package deal?
- Anyone that has a ST rear sway bar please help
- MSD Blaster Coil install question
- How much does your accord weigh?
- DIY: Removal of Press on Rotors!!!
- stock exhaust diameter
- Where can i buy a new stock muffler for a cheap price for my 94 accord ex?
- 97 Accord Blinker Replacement/Removal
- Play in the drivetrain
- F22 Turbo guys, still got your A/C??
- AEM CAI Installation Help! 97 Accord!
- where in socal for h22 swap
- Engine Replacement on 98 Accord 4cyl...(what parts to keep from old engine?).
- friend needs help! car just died
- 2003 Accord v6
- Best way to take off the back emblems?
- 98 Honda Accord LEV model Cataylic Converter rattling
- 92 Accord Window Regulator Fix
- weird hesitation
- Stuck in 2nd gear, sports mode light wil not go out.
- Header swap on 93 accord
- Car keeps turning off??
- Carbon Fiber Retailers or Custom Work...
- need help
- I am about to h22 install. Give me some help!!!!!!!!!
- Steering Wheel Spacer
- Maintainence Required Light comes on Accord 98 v6
- JRSC in a 94-97 Accord with H22 (Has it been done)
- 1999 Accord throwing a DTC 0420, new converter?
- accord 96 swap or turbo
- what is better coil over or lowering springs
- Uneven Ride
- 95 accord want to swap a 5 spd
- occasional stuttering while idling
- Heater/Air Conditioning Temp Control Problems....knobs not working? (kinda long)
- can anyone get an 03 accord haynes/helms manual on pdf?
- wanted to know if the injectors from a prelude would fit 90 accord 5spd
- Coolant loss, but don't know where
- 5th gen accord lx vibration
- AXLES
- syspention help
- Can Grouding your car be bad
- poor idle and running rich
- Clicking noise while turning?
- 4TH GEN FRONT ROTORS?
- Shogun Power Tuner
- Can i spray degreaser in the timing belt area safely?
- intro
- who's running KYB?? worth it???
- Any problems to watch for when installing aftermarket headers on 93 accord?
- Auto Trans stiff
- v-tec head swap onto f-series engine?(if possible do i need modifications)
- startup exhaust smoke
- sweakin noise from front wheels
- brake problem
- will prelude(90 and up) injectors fit a 90 accord
- h22 swap.....won't idol
- 4th gen header install? Cracked Exhaust manifold :(
- Ground Wire on Accord
- CAI=less power than short ram?
- Type R Intake Manifold.....?
- Removing 2002 Accord Front Bumper
- pics of f22b turbo!!!
- CAN WE COMPARE SUSPENSION PARTS ON '03/04 ACCORD VS 04 TL??
- hit n run in parking lot w/ no note = me fixing car :(
- Disconnecting Tranny from Motor
- Tranny about to blow!
- Stock and programed ECU'S p13/p72 a must have for swaps
- Fuel Injection Problem
- Rim Sizes?
- here's a dumb one
- Intake + water = :(
- !HELP- 1994 Accord (TEC DIST+ EX. COIL) wire locations for Mallory HyFire VIA install
- Throwing Codes 6,7, and 22. Know why?
- I need help
- lame
- Need help with window electrical system!!!
- wifes ACCORD (5th Gen)
- how much is my accord worth?
- Progress rear swaybar vs. ST bar Review
- H22A Envy
- Do u have a simple how to install fog light wiring ?
- 1990 honda accord clutch question?
- Stock Rim/Wheel weight?
- prob a noob question.. but (cd changer question)
- 92 ACCORD AUTOMATIC TO STANDARD
- prices
- Stock CD deck for a 96 Accord questions
- I bolted on my manifold
- help ?????????????????????????????
- Tein SS Coilover
- help!!!
- pics of OEM bodykit on 6 gen? and others questions
- plastic pipe in intake
- clutch squeels
- what should be done
- car shacking around 60mph+
- Installing front main seal
- Accord drives like a boat...
- 1990 accord EX tail lights out. help please.
- obd1 into obd2 car
- F22-series differences for rebuild?
- f22 non-vtec DOHC head one f22b1 block
- Trial User?
- H22a-T in 5th gen Questions
- Who has the quickest all motor f22/f23 Accord?
- Fuel Lines???
- People with XTSS
- 93 Accord EX Turbo Ques>?
- 86 Accord Transmission question.
- 100W Super White Bulbs For Headlight (9006 Low bean)
- fastest bolt on f22/f23??
- tires on factory rims
- Accord Engine Mounts
- help.. i need your 92 stock shock/spring for LX model
- Chassis code??
- Want to turbo your H22a Accord? then click this...
- 97+lude guage cluster fit 5th gen accords?
- Question on Suspension
- Wheel bearing change procedure in Haynes Manual?
- please help i broke something (steering arm???)
- o2 question
- Need new f22.
- is it tru?
- not starting
- Creaking suspension????? HELP!
- 4th Gen A Pillar
- gauge cluster lights?
- 98-02 Accord Headlights
- 98-02 Accord H22 conversion
- Best/cheapest place to order OEM Honda parts?
- Generational issues...
- Taking off the door panels
- F22 turbo faster then a h22a ??
- oil catch can?
- stock cambers
- master brake cylinder brace?
- ST Sway Bar Torqueing Specs
- Help
- Check Engine Light comes on; Cant Rev past 4k, wtf?
- Projector Headlights for a 99 Accord
- what should i get prokit or sportlines? (2000 accord coupe)
- what is the difference in trunk lids between a 94-95 and a 96-97 accord?
- Any shops in Wi or MI?
- 92 Accord Soft Ride
- New Pics but little progress. Turbo/IC pics
- 98 Accord EX 4 cyl - Valve Noise
- HID + H1 Projector
- Problem with JDM Mirrors, don't fold back out
- H22a swap into a 1992 honda accord
- rear brakes on a 93 accord lx
- so aftermarket cam gear off 2000lude fit my 95 accord?
- Lowering Springs and Camber Kits
- strut bars...which are the best?
- H22 swap vtec problem
- Need Help, I'm a newbie
- warning!!!!!!!
- 92 front brake upgrade!
- What kind of motor do I have?
- suspension question, anyone ever heard this?
- Probs with map sensor
- Accord Lip
- accord steering wheel
- looking for hybrids to feature in book
- Electrical system problems?
- HELP! 94 accord clutch problem
- Weight of A/C in '99 Accord i4?
- new mods
- questions on h22 swap
- f22 turbo manifold
- 15x7, 4x114.3 lightweight wheels
- Accord EX torque converter rebuild
- o2 sensor for honda accord
- clutch too stiff/firm?
- Does enyone have anything to say about kmwperformance???
- 94 Accord Halo Lights
- 97 EX Muffler question...
- What mileage for tune up, timing belt belt replacement, etc?
- anyone got pics of an h23a swapped accord??
