View Full Version : Honda Accord (1990 - 2002)
- f22 oil pump on an f20b. possible?
- Wheel Hoping after 3000 RPM??
- will these fit?
- Need some help (teg engine into an accord)
- What kind of struts/shocks are good?
- how to change a 95 v6 accord radiator
- 4th Gen trunk lid swap
- How should I clean my exhaust manifold?
- valves
- Anyone upgrade thier engine mounts? Who makes them?
- 1992 accord
- 94-97 accord rear CAMBER
- where is the speed sensor on a 90' accord LX, auto trans...
- my windows lagggggggggg....
- Comfortable ride
- Quality Header
- tire wear
- Question on Coilovers
- anyone done a CV boot replacement on a 91 accord?
- if you were in my situation what would u do?
- 92 92 accord info and h22 estimates..
- OT: Any one done a swap like this before????
- No Heat after AC control relocation.
- Horrible Gas mileage? After an oil change
- question regarding timing...
- how to read ecu codes??
- Tech help pls.
- 99 side mirror same as which years?
- will 4th gen prelude struts fir a 4th gen accord?
- is it possilbe to change interior color in 90 accord?
- Questions about spark plug gap and torque?
- Stock Airbox on 94 Accord...
- f20b in a 97 accord ex
- installing spark plug the right way??
- How do i reset my Ecu??
- '89 Accord LXi - Hard Starting, Why????
- Axle, Rotors, Brake Pads, Brake Lines
- Accord service manual
- upper control arm and camber kit for accord for sale.90-93
- Need more power!!!???
- B18C ???? H22A ????
- how much horsepower?
- Failed smog :(
- trouble with pulling out a tranny
- factory injectors peak and hold or saturated?
- shifting?
- Engine Revs on it own
- 92 accord ex front and rear speakers
- Question for 99 Accords???
- Crankshaft timing alignment & piston TDC position question?
- sign of a bad radiator cap?
- Anyone interested??
- what causes wheel hop????
- fuel filter loc?
- need help with accord not idling
- vacume line question (problem?)
- 98+ suspension set up
- Car chokes when starting any suggestions?
- Can anyone help me find...?
- What next engine to replace dead F22B1?
- Figuring out the snapped rod on my F22B1 *long read*
- anyone with a 1991-1993 honda accord
- Main fuel relay life expectancy ?
- H22/H23 swap in a 92 Accord 5speed
- Electrical problem on 98 accord
- 4th gen accord spring install
- boggin and backfiring..
- Keep A/C or not to??
- denso spark plugs?
- Trouble code jumping
- how do I remove the ignition rotor? (yeah I know...)
- 90-97 Rotor Install Guide
- Putting bumpers on 94 accord
- how do you change the radiator fluid on 4th gens?
- dumb question but please help.
- IDiots Driverz??
- got an alignment.. but car moves a bit left then right then left then right??
- timing???
- Remote Start, but not security
- 03' Accord V6 6spd
- firing order
- Euro Accord-R H23A specs...
- energy suspension bushing help?
- 93 Accord ex makes weird noise when moving backwards.
- 91 accord armrest?????????
- 99 Accord lx having problems with digital clock
- NX 75 shot on F22
- 4th gen Door lock actuator
- 96 Accord Ingalls kit
- Camber Kits
- also posted in autox: VTEC SOH F22B1 a JDM only engine?
- my new lip.......
- when do you change P/S fluid
- tranny / speed sensor question
- Please Help
- h22 -> in 92 Accord EX
- OT: How low is your accord??
- need help on my 92 accord lx sedan automatic again
- how much am i lookin at?
- Anyone ever see this???
- 88' Accord
- Wheels
- spark plugs and wires
- 4th gen relay location
- Running on two or three cylinders at 2000-2600RPMs: WTH??
- Being careful... and the results if you dont.
- How much do i weigh?
- 4th gen accord model
- Is this possible in a 6th gen coupe?
- okay ive got a situation here is this too hard to believe?
- Short Ram vs. Cold Air
- lugnuts for a ca5?
- Which Honda Parts/Accessories website is best for value/price?
- Fender well trimming
- H22 Distributor Issues...
- 3rd gen questions?
- Info on buliding my 97 Accord SE!!!!!
- Greddy Evo Exhaust for Accord
- 2000 Accord Engine Swap...have Question.
- JDM parts
- light alignment
- cv boot?
- tokico vs kyb suspension
- h22a accord exhaust
- my new car
- Idle Air Control System or TPS Sensor?
- Rack and Pinion?
- Braking problems
- 18" 7.5 +43 on 6th gen?
- Problem with suspension....PLEASE HELP
- Anyone know if acura Tl/Cl rims would fit a 94 accord?
- My car is making a sqeeking noise.
- Axle spline/nut sizes anyone? ('88 Accord/'93 H22A swap)
- Are AEM Pulleys illegal?
- H&R spring Rate?
- Accord/Motegi Wheels
- h22 question!!!!!!!!
- can some one help me up, I need a accord 01 front factory bumper
- Looking for factory part
- door lock control!!!!hellppp
- Sorry Mods to do this but, Im lost
- h22
- Cnc Ported Head Dyno Graphs for H22a and F20B!!!
- Venom 400.. installation question..
- armrest
- Anyone in midwest area(MN) have a motor for my accord cheap??
- replacing spark plugs... whats the method again :P
- CV joint replacement.
- Lug pattern for '85 Accord Hatchback??
- zex acessories
- will a ex head fit?
- question on 90 Accord A/C
- help with h22a install wiring 94 ex help1!!!!
- H22A Torque Specs. WTF
- Coolradiator racing radiator fan
- Summer Time's Coming
- IAB vacuum line hook up please help
- 1990 accord
- h22 swap? or just go for the gusto
- Anyone remember the ABS post on how to fix it?
- I need your help guys!!!
- websites with after market stuff for late model accord
- Disable Fast Idle Thermo-valve?
- tranny problem
- Accord IS DAMAGED!!!
- 2 questions: Lubing wheel bearings, and mixing oil viscosities(sp?)
- 1988 accord how to
- Need Help on 5th Gen Accord Spring Rates ?
- help needed on wheel bearing
- can i still get the balancer shaft seal recall done on my 94 accord?
- Installing Skunk2's..help quick!
- Side Mirror for 00 accord
- sunroof/moonroof open half way?
- Tie Rod End Replacement
- tdc sensor ?? anyone have info???
- 94 Accord with 150k miles I am concerned.
- diagnostic codes on '88 lxi
- Help with installation of alternator install
- '03 accord v6 1/4 mile times?
- a20 crank
- ABS control?
- 97 Accord SE CD Player Error?
- Tanabe Hyper Medallion vs. Greddy SP
- Key is stuck (yes i did search)
- 4th gen mirrors
- How the hell do you remove the blower motor?
- max boost?
- coilover suggestions pls!
- Is this a good e/t?
- Urethane bushings for 5th gen Ground Control??
- bad reman alternator?89accord lxi
- Wheel Trouble
- what would u do to a stock EX 97 accord?
- Name this Vibration
- 4th Gen Swaybar help
- 6th gen H22 SWAP INFO.
- wire my h22a wire harness
- gas usage?
- Apexi safc II
- $230 shipped (pics inside)...mods please be nice
- Rims
- Anyone in NYC know a place for a h22 swap or rebuilding + P&P thanks
- What type of bolts should I use for my bumpers?
- Short Shifter Install
- Can we get a 7th Gen Accord section on here for just 7th gen stuff?
- What is the cheapest swap I can do?
- black widow for a buddy club
- My '99 Accord's side mirror is "floppy"
- A few Q's about replacing rear rotors on 00 Accord EX....
- Speedometer Cable
- AEM R&D looking for '03 Accord 4-cyl
- Need ALTERNATOR for '97 EX 2.2L ASAP! Why won't 5th gen DX/LX alts or 4th gen alts work? They look
- fastest accord
- Buying a used 5th gen
- putting in a new distributor help!
- Accelerator/Throttle Cable issues...H22A Swap
- wheel gap
- Need Help, Steering Wheels Shakes Rapidly
- question about an oil filter
- Why H23 over H22 ?
- My Sad Dyno Day : (
- I have 18's with a 40 offset...is this the ideal offset for a 2.25 drop on 01 Accord Coupe?
- 1991 Honda Accord - very high miles
- tail light question
- F20B fit in a 92 ex
- srs light on o1 accord
- Lamin-x vs Stoneguard
- ST rear sway bar onto a 91 Accord LX?
- Progress of my car
- 6th Gen Owners - Handling , Performance ?
- Anyone have any info on 2003 Accords?
- WTB 96-97 Accord door handles asap sorry mods
- Did search but nothing came up? Replacement tranny for the V6 Accord?
- How to take apart 98+ speedo gauge cluster
- How do i remove the TPS sensor?
- how much would you guys pay for a walbro fuel pump?
- accord compressor eliminator
- Accord tranny question...
- Tokico Illuminas
- head gasket, valve seals??? help
- 92-95 Prelude Cluster in 94-95 Accord
- Clutch Slave Cylinder Question ????
- What is the lug pattern on a 96 Accord?
- Car Concern...
- anyone have a 4th gen accord parts car?
- speed limiter removal
- transmission
- Accord Radio Master Code???? 94 accord
- Looking for a good place to buy an Axle..
- Changing a light on the top of the dash (the one that shines on gas guage & speedo)
