F22A1 w/F22B1 head swap: complete.
Old Jun 8, 2003 | 06:23 PM
GimpyAccord's Avatar
Default F22A1 w/F22B1 head swap: complete.
I'll be doing a full write up, but:
ya.. f22a1
Old Jun 8, 2003 | 06:30 PM
sauceman's Avatar
Default Re: F22A1 w/F22B1 head swap: complete. (GimpyAccord)
Nice job!
Looks clean as hell. So you found that little hose you were desperately looking for eh?
How do you like it?
Old Jun 8, 2003 | 06:32 PM
fizzbob7's Avatar
Default Re: F22A1 w/F22B1 head swap: complete. (sauceman)
i've seen a ton of people asking about this on a bunch of forums, but have yet to see much about it...good job....looks good......a big difference?
Old Jun 8, 2003 | 06:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sauceman &raquo;</TD></TR><TR><TD CLASS="quote">Nice job!
How do you like it?</TD></TR></TABLE>
Yes, KCHybrid on AD hooked me up with the water pipe!
So far I really like it, it has a lot more ***** than it used to... HOWEVER let me be fair to the original head:
1.) the head had 380,000 miles on it (the bottom end has about 120,000... cracked a crank a couple years ago).
2.) I didnt hook up the balancer shafts... which are good for a couple ponies.
If anything its fun to hear the intake note change a little I spent like a week solid degreasing this thing. My car WAS leaking oil from like every possible place:
I have a feeling more and more people will be doing this... next stop for me = BOOST. The whole reason I plopped this head on was the abundance of turbo kits available for 94+ Accords.
Old Jun 8, 2003 | 06:48 PM
fizzbob7's Avatar
i haven't had my h22a swap long, but i kinda wish i had done that....just cuz it's different....and then a turbo woulda been nice.....
Old Jun 8, 2003 | 08:10 PM
accordfreak's Avatar
Default Re: F22A1 w/F22B1 head swap: complete. (fizzbob7)
sweet! first time i've seen someone do this. good job
Old Jun 8, 2003 | 08:50 PM
Accord94DX's Avatar
**** now you gotz da vtekhk. Nice swap!! Post a write up soon maing!
Old Jun 8, 2003 | 11:45 PM
Default Re: F22A1 w/F22B1 head swap: complete. (Accord94DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Accord94DX &raquo;</TD></TR><TR><TD CLASS="quote">**** now you gotz da vtekhk. Nice swap!! Post a write up soon maing!</TD></TR></TABLE>
w3rd up... watch my vtec cuz y0 when j00 hear the intake note change u kn0w its all 0ver!
anyway.. ya i'll work on typing it up tomorrow. It seems pretty straight forward ( and it is!) but there are some annoyances for 4th gen owners anyway.
Old Jun 9, 2003 | 08:53 AM
KTeller8's Avatar
nice clean valve cover
where you get that from?
Old Jun 9, 2003 | 09:05 AM
rage237's Avatar
nice
do you have more pics from install?
seems like a good swap
Old Jun 9, 2003 | 09:46 AM
Default Re: (KTeller8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KTeller8 &raquo;</TD></TR><TR><TD CLASS="quote">nice clean valve cover
where you get that from?</TD></TR></TABLE>
That cover actually came from "coupe" on AD (sorry i dont know his real name).
My digital camera went haywire right in the last day of swap.. but here are some (caution my cable modem is slow.. so be patient):
This is the water tube talked about earlier.. a 94+ is on the bottom. As I was putting it back together the thermostat housing wouldnt reach the tube!!! So I had to quickly find a 94+ tube. This will all be in the write up. As you can see the 94+ is about 2-3cm longer to accomodate the higher head.
Old Jun 9, 2003 | 11:30 AM
RotaryBzzzz's Avatar
AAAAAhhhhhhh......Grassroots cleverness.
I like! Good job mang!
Old Jun 9, 2003 | 12:20 PM
xtremecivichb's Avatar
Default Re: F22A1 w/F22B1 head swap: complete. (RotaryBzzzz)
very nice
Old Jun 10, 2003 | 01:39 PM
Default Re: F22A1 w/F22B1 head swap: complete. (xtremecivichb)
This is a BETA version of my howto without illustrations, but enjoy. As I finish it up and get the pictures in order I'll update this and post a final version.
In the quest for more power for my Accord I came to the conclusion that a turbo was the only thing that was going to make me happy. I toyed with the idea of the Eclipse manifold rig job or having something made. After seeing impressive dyno results of the SOHC VTEC engines with boost I decided that I must have this feature. I didn't really want to pull out my bottom end though. Knowing that the F series is MOSTLY identical to eachother (save the F23's which have different sleeves etc) I figured I could just plop a F22B1 head on the car. Another
factor in this decision is the abundance of off the shelf turbo kits for the 94+ Accords. Having a manifold fabricated is a cool idea, but I just rather have an off the shelf kit. Whats really great about doing this is
the price. Most swap-shops are trying to GIVE away F series engines...
Well what better way to start off this how-to but with a parts list. My parts list assumes you have a 4th gen Accord. If you're a 5th gen owner you wont need the intake manifold, so just use your head on the rest. I'll also list the places and prices I paid:
1.) F22B1 head; (eBay - $100.00) You'll need a valve cover too... which I got off a forum member for $30.00.
2.) F22B1 or B2 Intake manifold & throttle body THIS INCLUDES THE THERMOSTAT HOUSING!!!; (Forum Member - $50.00)
3.) 94+ water intake hardpipe (water pump to the thermostat housing); (Forum Member - $5.00)
4.) Timing belt (the 94+ EX are specific due to the head being slightly taller!); (AutoZone - $45.00)
4.) P0A ECU; (Forum Member - $35.00)
6.) All associated seals & gaskets (Depends, but figure $100-120 if you're being smart and replacing old seals);
7.) Exhaust manifold that'll fit a 94+; (Forum Member - Free)
8.) 94+ Throttle Cable; (AutoZone - $22.00)
9.) Proper spark plug wires. (AutoZone - $45.00)
Tools what will make this job a lot easier or you flat out need:
1.) Brass scraper (dont *** up your aluminum block & head scraping on it... be smart and use a brass scraper).
2.) Crank pulley tool (I don't know how I ever survived without this)
3.) Of course you'll need varying levels of torque wrenches, don't even attempt this without proper torque wrenches.
Abbreviations:
MAP = Manifold Absolute Pressure sensor;
IM = Intake Manifold
TB = Throttle body
VTS = VTEC spool solenoid
VTP = VTEC pressure sensor
IAC = Intake Air Control (called EACV on older hondas... what I'm used to)
EM = Exhaust manifold
IAB = Intake Air Bypass solenoid
Taking it apart:
I'm not going to dwell on this too much. If you're going to attempt this you damn well better have a service manual! Basically keep taking things off until you have a bare head in front of you. My engine was leaking oil pretty bad from the oil pan and front main seal. Since you'll be up there to replace the timing belt anyway why not change all those too? I also took this time to really degrease and clean my engine, transmission and compartment. So, in review heres everything I replaced/freshened up:
1.) I removed the oil pump housing and made sure the oil pump rotors were within service limits.
2.) Replaced all orings, front main seal, and balance shaft seals.
3.) througly cleaned and scraped the oilpan and oilpan mating surfaces & replaced the gasket.
Assuming you're a 4th gen owner, go ahead and pull out the water intake hardpipe on the back of the block use it to launch a bottlerocket or something. Install the 94+ pipe and call it good.
Prepping the head/block & others:
In todays world of multiple-layer metal head gaskets, head/block trueness & cleanliness are of utmost importance ...if you want a head gasket that wont pop on you in 20 miles. Throughly scrape the head and block with a brass
scraper. Caution must still be taken even with a brass scraper to not nick or gouge the delicate aluminum surfaces. Hopefully you took the time to clean the engine compartment, block & head before reassembly as well! Also take care that pieces of old gasket & muck dont fall into the oil gallery drains or water jackets by using rags.
On the bench go ahead and bolt the intake manifold to the head if it isnt already. Its just way easier on the bench.
Finally for us 4th gen owners... there is a bit of business we need to do on our heads. In 1994 Honda redesigned the F series a bit on the front middle head bolt region. They added a little ledge that covers/seals a water casting hole from when the head is molded. They use those to sand cast the aluminum. Why is that a problem you ask, well as I found out (the hardway I might add) without that ledge it LEAKS water (pours is more accurate). Therefore it MUST BE SEALED. I used a crapload of JBweld (I love this stuff!). Feel free to seal it however you please, but do it or enjoy no cooling system. Once again this only applys to 4th gen owners. I assure you this hole is only a sand casting drain and on the 5th gens is totally sealed by the headgasket against the ledge.
Prepping the wiring harness:
For the most part this will remain unchanged, but a couple things do need to be added and one item moved ...if you have a 4th gen.. You'll be adding 3 wires:
1.) VTEC solenoid trigger
2.) VTEC pressure sender
3.) ground wire for VTEC pressure sender
Add these 3 wires to the thermostat housing/EGR area of the wiring harness and we'll discuss ECU pinouts later in the how-to.
Now the item that needs to be moved is the IAC / EACV (whatever you wanna call it) plug & wires [2]. You'll find this plug on the plastic injector wiring bar. Open the plastic injector wiring bar and pull out as much of it as you can from there. Cut the connector off and untape the harness enough to get the 2 wires heading toward the TPS sensor connector. You're going to have to solder about 12-14" of wire to make it reach. I just loomed the TPS & IAC together and made a Y so they could reach their respective recepticals. As I said earlier this is the OPTIMAL time to totally retape & loom the wiring harness if yours looks bad like mine did. Once again only 4th gen owners need to move the IAC connector.
Finally you're going to have to make a choice on the MAP sensor. You can either A.) find a connector in the junkyard that will fit the MAP on the TB or B.) reuse your MAP sensor and just run a long piece of vacuum hose over to the drivers side of the IM. I chose option B for right now. If you're a 5th gen owner this doesnt apply to you.
Prepping the ECU:
This was really easy for me. While I do have brand new pushpins (hey I used to do a lot of motorswaps) I reused what WAS my automatic rear motormount solenoid (this is also the IAB on 90-93 EX models or anything else that was equiped
with IAB) and powersteering (I removed mine) pressure sender pins. If you didn't already know Honda was really nice and you can snap open the connectors on the ECU side and move pins around. No matter WHAT way you decide to do this you need to add two pins: D6 (VTP) and A4 (VTS) [See wiring harness pinout chart I've included]. The VTP ground... well just ground it anywhere. It doesnt matter, its just a simple on/off pressure switch.
NOW for 4th gen owners we get to do a little more work/make a choice. In 1994 Honda decided to swap pins A11 and A6 (EGR & 02 Heater respectivly). To my knowledge this is the only OBDI car Honda did this on. ANYWAY your choices are
as following:
1.) Swap pins A11 & A6 while you have connector "A" apart adding VTP.
2.) Open up the P0A ECU and cut A11 & A6 and reverse them via internal modification (IE: wires crossing them... see attached picture).
I chose option 2 because I do a lot of ECU testing and changing my harnesses pinout for one lousy ECU isnt in the cards.
Anyway thats it for wiring. Go ahead and put the wiring harness back on the car as its much easier to do with the head off.
Reassembly of head to block:
Once again we wont dwell here too much, its pretty self explainitory with a manual. Just remember to make sure your head bolt holes are clean and the head bolts are clean * oiled with fresh engine oil. Three or 4 stage them down to 78 ft. lbs using the proper tightening sequence. Make sure the bottomend & head were set to TDC properly!!! You dont wanna bang pistons on valves rotating stuff around! I guess the only real advice I have here is make sure that your
mating surfaces on the block & head are CLEAN and DIRT FREE.
Intake manifold & fuel lines:
If you have a 94+ just ignore what I'm about to write about fuel feed & return lines. 90-93 the fuel feed is on the passenger side of the fuel rail, 94+ its on the drivers side. The 94+ uses the same size fuel feed banjo as a 90-93. So all I did was cut & extend my fuelhose (MAKE SURE YOU USE REAL FUEL HOSE) using clamps and bits of stainless tube. Ya, this is a big rig... but my ultimate goal is to get some braided lines made for the car anyway. The fuel return hardline is a little smaller than the 4th gen one, but with clamps it snugs right up too.
Some other little things will need to be lengthened (read: replace the hose) here and there like the brake booster vacuum hose. Theres just a couple little things like this and will all be very obvious as you're putting the car back together. Also make sure you cap off any unused vacuum lines on the drivers side of the IM... you don't want a goofy idle!
Timing belt and related:
94+ EX models use a slightly longer timing belt due to the cam being higher (the head is quite a bit larger physically). So don't even waste time, just go choke up the money for a new belt. This is also an optimal time to replace the waterpump & timing belt tensioner if its been awhile! Slip on the new timing belt and tension it
properly according to the published Honda methods. I chose NOT to replace the balancer shaft belt on my engine. People think its risky and maybe it is, but I wanted to see if it would give me a couple ponies... and I think it has. I also used this opportunity to make home-made solid motor mounts for my car (since to properly do the timing belt you pretty much need to remove the front, rear and side motor mounts anyway). Go ahead and check your valve clearances and then button up the cover! As always I reccomend spinning the crank around a few times by hand to ensure it stays in time and that you have no mechanical interference.
Exhaust and related:
Pretty self explainitory. I ended up using a 94+ LX header for now because the EX has the O2 bung on the downpipe. With everything else going on with the car I didnt want to add lengthening my O2 wires to the list of **** that could go wrong. Use whatever header you like.. DX/LX ... EX.. or an aftermarket obviously too. The downpipe ended up being like 6" shorter than my old Pacesetter 4-2-1 I had on the car, so I used some flexpipe for now. I'd have something properly welded into place, but why bother when turbo is my goal in the immediate future.
Throttle Cable:
The 94+ throttle cables are a tad longer. While you can (and I DID) rig it temperarily, I reccomend doing it right. Replacing the cable is trivial and in the longrun just plain safe.
Wrapping up:
Reconnect all of the wiring to the head etc. Your original distributor will fit, so just put it back on! Fill the sucker with water and oil and look around for obvious leaks. Before putting spark plugs in the head I'd crank it over a few times with the starter to put some oil up into the head ... make life a little easier on the cam bearing
and all that jazz. Also be SURE that your fuel lines arent leaking. Furthermore I'd have a fire supressor and/or hose around just in case!
Put in your spark plugs, wire them up... and she'll fire up with any luck! Thankfully when I turned the key on mine I got no CEL's and good oil pressure. Mine popped in about 2 seconds of cranking, I was truly impressed. Obviously let it run for a bit and check for oil & water leaks. While you're waiting for that to happen, nows a good time to check your ignition timing... its GOING to be off since the distributor was off the car!
If alls well, hop in and go for a ride! Congradulations.
Modified by GimpyAccord at 7:56 PM 6/11/2003
Old Jun 10, 2003 | 02:27 PM
StimpyBoy's Avatar
Just a quick "excellent job" post, that looks great. I'll eagerly await future boost posts
Time to go run a 94+ Accord off the road, excuse me, jk :D
Old Jun 10, 2003 | 03:22 PM
ArchAngel Sabastian's Avatar
New User
gimp i have a EX header i need to get rid of you can have, and theres no O2 bung on the downpipe. if you want it.
Old Jun 10, 2003 | 06:14 PM
Default Re: F22A1 w/F22B1 head swap: complete. (ArchAngel Sabastian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ArchAngel Sabastian &raquo;</TD></TR><TR><TD CLASS="quote">gimp i have a EX header i need to get rid of you can have, and theres no O2 bung on the downpipe. if you want it.</TD></TR></TABLE>
the O2 is on the primaries?
Old Jun 10, 2003 | 06:28 PM
Mike813's Avatar
i was thinking about doing the same swap on my 94 lx, PM'ed you about some stuff.
Old Jun 10, 2003 | 06:45 PM
sauceman's Avatar
Wow, awesome how-to post. That should help a few.
Are you the one who's gonna dare try the h22a head swap to the f22 block to prove us all wrong?
Old Jun 10, 2003 | 07:15 PM
KTeller8's Avatar
Default Re: F22A1 w/F22B1 head swap: complete. (Mike813)
i got a lx intake manifold: complete if someone needs it
Old Jun 10, 2003 | 07:45 PM
vierth's Avatar
Great Write-up! Unfortunately I am thinking that to do this on a 97 lx would be a bitch because of wiring, it being OBD II and whatnot. If I am wrong about this let me know, cause I would be tempted to give it a shot .
Old Jun 10, 2003 | 08:53 PM
KTeller8's Avatar
Default Re: F22A1 w/F22B1 head swap: complete. (vierth)
for 150 bucks you could go with an obd2-1 harness and be ok
Old Jun 10, 2003 | 09:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vierth &raquo;</TD></TR><TR><TD CLASS="quote">Great Write-up! Unfortunately I am thinking that to do this on a 97 lx would be a bitch because of wiring, it being OBD II and whatnot. If I am wrong about this let me know, cause I would be tempted to give it a shot .</TD></TR></TABLE>
It would be the same dude, I don't know the pin numbers though for OBDII. Obviously you'd need to score a OBDII P0A ECU or as MKteller posted convert to OBDI is optimal.
Old Jun 10, 2003 | 09:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sauceman &raquo;</TD></TR><TR><TD CLASS="quote"> Wow, awesome how-to post. That should help a few.
Are you the one who's gonna dare try the h22a head swap to the f22 block to prove us all wrong? </TD></TR></TABLE>
Oh thats cake dude, I've even mocked H22A head (i have one in the basement) up to a block. Only thing you really gotta do is close up the outboard drivers side oil gallery drains as F series only have the inboard pair. Problem is the RPM needed to really take advantage of that head isnt really safe to spin on the F series with the long stroke.
Old Jun 10, 2003 | 09:52 PM
fastaccord94lx's Avatar
Damn Gimpy, once again you have amazed me, like the other guy, I have a 94 LX and wanting to do this swap very badly. I am looking forward to the complete how-to with pictures and all. The only thing I may need your help on is setting the head and block TDC (Don't know howto) and the ECU stuff. Although the ECU stuff should be pretty straight forward.
And may I say excellent job, you are awesome! You give hope to the F series engine to everyone!
