View Full Version : Honda Accord (1990 - 2002)
- 95 Accord hood
- tire pressure recommendations
- ECU Loction for 6gen Accord (Already searched)
- Koni Shocks + Neuspeed Springs for $514 sound like a good deal on ebay?
- 916 help
- Upper Ball Joints - How to check for damage/How to replace the boots?
- Just notifying you..
- wtf is going on?
- Need help with brakes and rotors purchases!!!
- Accord Swap Question
- Question about bent lower control arm for 94 Accord and where I can buy one.....
- 2001 accord f23 capable of 170whp? HELP!!!!!!
- f22b dohc swap people? 5g accord
- your opinion for my car
- r there n e dowel pins on a 98 accord 4 cylinder water pump??
- h22 in my friends accord
- 99 accord main relay
- Is his recommendation right on?
- jdm h22a alternator question
- My new exhaust!
- Check Engine light...
- 91 Accord Problem
- what fuses/relays are associated with brake system/brakelight
- Electronic Hell (Read if you dare)
- idle hunting
- my piece of shit car wont start
- Accord DX / EX intake
- 1999 accord problems
- Turning off the Maintenece Requied light in a 99 Accord already search thanks
- 6th gen auto tranny problem- won't park!
- CL-S cam swap
- How do you remove the fuse box in a 98 accord?
- 94 accord trouble
- PCV valve location
- Battery Trouble??? My car is dead & a jump didn't help...
- creaking suspension on a '96 LX sedan
- auto trans help again.
- anyone know where i can get just 1 camber ?
- universal oxygen sensor
- Stock '99 Stereo details help
- I need help diagnosing this problem
- OEM Shocks/Struts quote!!!!!
- 00 Accord Special Edition Breaking down?? HELP!!
- Antifreeze
- problem with brake
- Snow in Houston?
- shaving weight on a 97 accord
- 96 LX......need some answers
- e-brake getting tense
- throttle cable bracket and clutch pedal questions
- Battery might be bad, but less than a year old
- engine help
- Accord RHD????
- What kind of engine?
- JDM Sidemarkers, Corners, Et Al
- ECU P30
- Need F22a block ASAP
- 3rd Gen 1988 Accord Lxi - Front hub
- 2002 Accord Radio changes stations on its own!
- Stock Accord Cat
- 95 honda accord 2.0 iLS Gear shift problems
- DIY Blue clock
- How much does it cost to change the clutch in '95 Accord LX??
- My Accord broke off...
- does a h22 manifold fit a f22 head ?
- Had a small last night....I think I bent my tie-rod.....
- Intrax or Tein Springs
- prelude SH traction control????
- headlight issue.....think i'm screwed....
- 95LX Front-right caliper bolt....
- Need clarification on forum ABS topics
- How Hard to swap headlights? AV6
- F20B 98 Accord EX
- is it ok to run...
- converting OBD-2 engine to OBD-1
- just lowered car, alignment question
- How to setup turbo , what do u need?
- Where to start where to start......
- bad valve gasket mimics bad rings?? (oil on plug wire)
- 19 tires on my "new" 95 Accord in the last 3 years?
- 92 accord - engine bogging down at 40mph???
- Terrible newbie question, but needs to be asked
- '99 Black Honda Accord (4cyl)....Stalling HELP!!!!!!!!!
- Swap auto to manual
- TDC Sensor error code 8
- CLUTCH PROBLEM
- Dual Pump Fluid
- How soon do 225/40 ZR18 tires wear out?
- H22a tops out at 115!?!
- Light behind clock burnt out
- 94 Accord EX shifts harshly
- Turbo Muffler?
- question for anyone who lowered a 98 accord
- Post your Dyno Results
- 98-02 accord staring problem, main relay
- ATTS?
- 96lx - got 93 jdm h22a ... need harness help
- Good price for timing belt?
- Is it safe to go to a higher octane gas in my car?
- Can I use???
- Please tell me if this is a manual or
- Need some help with 89 accord
- Replacement PCV Valve
- Cold Weather = Horn randomly going off, like WTF?
- whats the difference between a f22a1 and a f22b engine ?
- Problem starting
- Snow in MA. Accident. Hit the curb with front right wheel.
- ACCORD FUEL PUMP VS. PRELUDE FUEL PUMP
- Broken timing belt ????
- Ques concerning wheel sizes and opinions for what I should do.
- help finding intake control solenoid on 1994 accord LX coupe
- 2000 Accord side airbag light on???
- Please HELP! Need Advice Quick!
- Ebay: Bomz air intakes: $25 - AEM intakes: $180!! What's the difference?!? Quiet intake..
- hood release cable
- HELP! Something is wrong!
- F22A4 Blocks
- b18 swap into 3rd gen
- cant find parts anywhere..
- boosting on stock motor with high mileage
- Why would moonroof shatter?
- I have no heat and its cold.
- '90 Accord Help....
- Where/which is the fuel fuse relay...
- Car wont start please help!!!!
- Help with my 1998 Accord
- How do I reset ABS.
- Sir Foglight Bulbs?
- '86 door handles??
- Good Manual?
- Check engine light came on while driving?
- swapping seats
- p72 or p13 on h22
- break lamp light is on???
- Brake Fluid bleeding questions for 6gen
- door regulator ? 90 -91
- Cruise Control/Horn Wiring Diagram
- Vehicle speed sensor
- just bought 86 accord, need little help
- would 99 accord lowering springs fit an a 94 prelude?
- cam machining
- URGENT: NEED FRONT BUMPER
- boosted LX's
- 2001 accord 2dr coupe v6 3.0 vtec
- Changing the Oil Pan Gasket on 97 Accord
- AC Pulley HELLISH SQUEAL
- 92 accord problem
- 93 Accord
- extended warranty for tranny on '01 accord from honda-check it out
- accord 01 brake warning light pops on . When it is cold outside
- How much can we bore out on the F23, 2.3 to ?
- H23 difficulty
- A Question of Lug Nuts for a 1998 Honda Accord LX
- changing timing belt for a friend.. should i replace seals too?
- Anyone know which one of these magnaflow universal converters will properly fit my car?
- a differnt sort of intake question
- Need advice on suspension setup!!!
- factory alarm wont turn off-97SE URGENT
- Is it a Wheel bearing?Should my lights dim with air con
- 37820-P0B-A70?Already did a search
- gude head package??
- exhuast...
- Poor gas mileage at an average of 300 miles to the tank on a 17 gallon tank....
- Anybody have a under hood fuse box diagram...
- What is a combination switch?
- Using up oil!
- 98-01 accord transmission information (IMPORTANT)
- 98 Accord speedometer
- Please help.. loud rubbing noise
- Starting Hesitation
- Will 225/45/18 work on 6th gen accord coupe ? need quick response
- New axle making noises ! ? ! ?
- CHECK ENGINE sign..
- Cracks on manual transmission housing!?
- 98 Accord coupe EX cat converter ??
- help with squeaky suspension...
- 5th Gen DIY...Connecting front turn signals to parking lights???
- i need sway bar suggestions
- Coolant
- are they swappable?
- Review: Neuspeed SofSport springs -- 96 Accord
- 99 accord lx turbonetics turbo kit
- Car vibrates
- What are the signs of clogged - Bad radiotor
- 94-97 Accord Parts
- Timing ? for all you expierenced mechanics Help
- Car pushing RPM's and not accelerating
- DIY blue clock
- 90-93 ECU diagram help!!!
- power steering flush
- How to take out a/c? 1990 Honda Accord
- 2003 Accord EX Factory Alarm
- I need to make donations for Juliana
- Question, about a few parts.
- Whats teh chassis code for 94
- touch-up wheel cover paint
- h22 wiring question
- gas mileage vs oil
- ABS Light 94 EX
- puttering....99 accord ex coupe
- Hood scoops , what happens when you use them
- accord help plees???
- Bolts underneath oil valve cover. Pupose?
- 1990 is acting up again....help me out
- 1999 accord sedan front bmp fit on 2001
- manual conversion wiring for obd2 5th gen
- 7th gen accord owners...
- 9012 bulbs?
- Help with muffler!!!
- FOR SALE: CHIPPED P75 ECU WITH UBERDATA FOR F22A TURBO SETUP
- replacing water pump
- ecu code 3 ?????
- 2001 Accord Front Wheel Stud
- ABS light/buzzing sound on a '94 Accord EX
- My inner fender inside my front right wheel well broke. Where can I find a new one and for how much?
- steering wheel.
- sun visors
- need help on egr switch wires for h22a jdm in a cd-5 obd1 1994 accord lx
- Instrument lighting question
- engine bay layout
- 2000 LX- Factory keyless entry?
- Accord "95 antenna problem. It wouldnt go all the way up, makes grinding noise.
- auto trans help
- help
- 98 Accord 6th Gen ----> Moisture -----> What to do
- H22 swap
- 1998 honda accord braking noises
- Rotational Squeak
- WHAT KIND OF STRUTS/SHOCKS SHOULD I GET?
- Remote Start. What should I get?
- F22 Selling Suggestions
- oil leak!!!!! need help immediately
- have i finally figured out what my rattle is?
- gsr vs h22 in a accord
- Heater not getting hot anymore....What do I need to repair???
- '97 F22B2 idle is low
- 1988 Honda Accord LX; Waterpump? Fans? Over-heating...
- 92 Accord Running Cold
- '97 F22B2 idle is to low
- light on sunvisor
- Puzzling Auto tranny question
- Taillights,markers,cluster not working!!
- dizzy not working
- Clicking from the front wheels / axle?
- installed some H&R sport springs, and now.....WTF
- Evap Valve/Canister...easy fix?
- Problem starting 94' Accord Please help!
- Constant squeaking sound coming from all four wheel wells
- Where the heck is the service connector?'94 Accord
- Should I...?
