View Full Version : Honda Accord (1990 - 2002)
- Overheating 92 Honda Accord...Please Help
- 7th gen Accord rear sway bar
- oil on spark plugs.
- more fun shifting
- Intake for 6th gen. 4cyl Accord ... extra component?
- timing belt and waterpump install for 93 accord
- 1982 Brake trouble
- 94 Accord - No fast Idle
- 96 seat removal (tried searching)
- need help for a friend...will 94 accord shocks fit...
- Will a K20 fit in 97 Accord??????
- headers?
- Security system problem after new alternator
- searched already. QUestion about EX manifold....
- projecter lights please help
- Need a cheap aftermarket steering wheel!
- Fouled spark plug, what's the cause?
- How can I find out shipping costs for a bumper?
- 02 Accord shakes at Idle -- engine light comes on
- any 90-97 people runnin illuminas with eibach sportlines?
- door ajar light comes on when brakes pressed
- My Accord
- HFP Body Package
- Help on Web sights for 96-97 ex coupes. Read on ->
- H22a harness needed for 1990 Accord?
- obd 11
- screetching belt at low rpm?
- Turbo Accord EX V6?(j30a1)
- What will This Neuspeed Strut Bar fit????
- should i get these rims for 7th gen ???
- can anyone help me out on this turbo info
- Blown Head Gasket on 1991 Accord
- NEED HELP! H22 swap (what is this solenoid, where does it go?)!!!!!!!!!!!!!!!
- is this fixable?
- Timing belt and bent valves?
- more power
- SRS light flicker
- Body Repair Question
- 93 accord - error 41 take 3
- Stock Speedometer Installation
- In need of JDM downpipe!!!!!!!!!*HELP*
- Odometer & LED blue bulbs
- Gen4 wagon luggage rack removal (?)
- need specs
- Race ready Parts?
- Lower Ball Joint Question
- Need A/C Hose
- anyone selling any kind or air/fuel controller or v-tec controller
- accord vs prelude weight comparison?
- question about h22 swap into 90 accord. what belts and stuff do you use?
- Help me with a 2.2 timing belt.
- 5th gen turbo talk
- 86 Accord has lost its idle
- what woul my 1\4 mile time be
- ecu type please help
- 97 Accord Auto
- My car won't start in the sun, wtf?
- 4th gen h22 swap question (tried searching)
- projector lights problems
- broken needle
- unheard of electrical problem
- main relay location? 94 coupe
- OIL LIGHT AT IDLE!!HELP
- 94-94 Accord EX vs. LX exhaust??
- exhaust but no header?
- 97 Accord Big Brake Kit
- Stock Radio Codes?
- Help... No Running Lights
- Idles roughly in park and neutral
- eibach sportline
- Everyone that did the h22a swap into 4th gen accord go here!!!
- 2003 K20 JDM ITR vs 2003 K24
- which shafts should i use
- accord-h22 swap axle help..PLEASE
- Accord euro steering wheel
- A/C gets warm at idle
- URGENT, need some advice on a few moves I'm making on my Accord!
- O2 simulator connection
- vtec
- Accord vs Integra
- Stock lights help
- Hey can someone help me out with my issue it's the one I posted below today!
- Turning Rotors question
- I have a stock Accord and thinking of adding an Injen Short Ram Intake and Eibach Pro-Kit just for l
- Ahh crap, where's the main relay?
- where can i get a vtec controler
- engine needed help
- Weird low pitched "groaning" noise, also, overfilled trans
- would vtec work if!!!!!
- Where do I hook can of R12 to recharge on 90 EX?
- H22 down pipe???????
- H22 Magic
- Do performance chips really work? ie. Mugen
- how many turns on accord factory rotors?
- 94 EX Spedometer / Odometer Prob.
- Question: 95 Accord 5 spd Conversion
- What size belt on H22???????
- Free OBX exhaust!
- Oil Soaked Plugs, Now My Car Won't Start
- witch is better vetc head swap or port and polish head
- New User! ~ 6th Gen 4cyl Drivers w/ UR Pulleys installed?
- h22 motor mounts??????
- air/fule ratio gauge
- 1993 Accord supercharger or turbo
- 96 accord start button
- 90 accord issues (h22 4 sale)
- oem 2001 accord fog lights
- Fuel Pump
- Restarting old Accord After 4 years in garage....
- nonvtec head to vtec head please help
- Transmision 91 4dr se
- Codes 1 and Code 43.....what now?
- High RPM ?s and Cat-Converter ?s
- Good Springs?
- D4 light out?
- Accord v-6
- engine check problem
- reseting ecu?
- H22 transmission mounting issues. Please help!
- turbo kit
- How to remove factory radio from 97 Sedan?
- DIY anyone?
- exhaust help
- Balance shaft timing on 2000 Accord F23A1
- Valve Cover Gasket
- o2 tank experiment
- Fuel definition help pls...
- built f22
- hybrid 91 accord ex
- coilovers
- h22a swap in my 6th gen accord (big problems)
- how do i post pics....
- pics of neuspeed strut bar on a 5gen??
- How do you think I'm d oing?
- Suspension Question
- anyone familiar with these projectorsm lights?
- immobilizer
- H23 trans on a F22 engine will it fit?
- stock car audio specs?
- Is modding my accord a waste?
- Skunk2 Acoord coil-over kit applications?
- AEM short ram
- Quick Question - Bolt pattern for 01 Accord EX V6 Coupe
- 97 lx with funky rotors
- 03 accord LX coupe
- performance
- Windshield washer circuit info needed
- Accord 1990 Check Engine and Cruise Control does not work
- Speedometer problem
- 2000 accord auto transmission
- 04 Accord Parts ??
- gear ratio question/tranny swap
- msd back to stock?!
- prospeed h22a civic header in an h22a accord??? anyone put any civic h22a header on their h22 accord
- MSD ignition 5A vs 6A???!!
- stripped bolt
- engine light is on, what now?
- Front Driver's Side Wheel Noise
- 95 Accord exhaust
- price for f22 turbo
- deck where speakers are
- camber kit
- Feeler: NEW 86-89 Accord Spyder kit
- smelly 03 accord
- wtb: anyone wiht a v6 valve cover for sale
- 91 Accord Transmission problems
- 03 EX alloy wheels
- f22 non-vtec heads, are they the same.
- HELP Please!
- Breaker Bar Size for 2001 Accord ATF Change?
- Best aftermarket header for 4cyl Accord
- Best shift point?
- 98 4dr oem fogs ?
- Odometer isn't working, But Speedometer works fine
- changing coolant before long trip?
- 1993 accord Lx coupe-->thermostat on the lower rad hose??WTF??
- Cold air or Short ram on 96 ex accord?
- FS: H22 with lsd tranny SOCAL CHEAP FAST
- SRS light wont go off help!
- Compression test fuse ... f-series
- I got a Question about Factory Wheels .
- momo wheel
- How do i know my VTEC is working?
- photoshop help
- Oil covered spark plugs
- My H22 in my Accord died on me this past weekend. HEEEEEELP!!
- HHHHHHHHHEEEELLLPPPP!! Engine Shakes when I hit 65mph and above!! HEEELLLLPPPP!!!
- Lug Nut Screwed
- Rough engine miss during easy acceleration!
- 1998 Accord LX Problems!! Dealer won't help
- intake manifold for F22?
- Intermittent stumbling start - give it gas!!
- Skunk2 coilover problem??
- ? for those of you who have sold body kits
- '92 piece or get something else...
- Accord Type R ( H22a ) UK Spec
- Help! anti-theft code for adio system...
- Anyone know the 1/4 mile times on a stock 2003-2004 Inline-4 Accord Coupe?
- changing a 92 auto too a standard
- 2001 Accord V6 Coupe or 2001 Prelude SH
- how do I make a ule-vtec engine fast?
- wtb:h22a tranny
- Cool site with car maintenance and info:
- Pspec tuning short shifter
- Accord brake question....
- 92 Acoord door lock problem
- Engine Light Is On! What do I do to find the codes?
- Basic Books for Hondas ?
- will civic bags fit and a accord??
- Remiving from rotors 96 honda accord
- where to buy lip kit?
- Yet another f*cking problem with the accord (brakes)
- finally got my clutch installed.
- World fastest all-motor accord wagon (daily driven)
- Weird plug wire problem
- Buying a 1994 Accord LX Sedan
- 6 Gen Wheel Specification
- Which shocks to buy?! Help please!
- Question on wiring harness for tranny swap.
- battery keeps dieing!!
- Searched f22 h22 compatiblity
- F22 / F23, Using Prelude Piston. ( bore , h22 , 87mm , H23 <- for search purposes)
- need help with 91 EX coupe
- fogged headlight
- will 4cyl springs fit 6 cyl???
- More problems
- Sum INfo for 96 accorD please?
- 94 accord Laggy in power up to 5k rpm Plz help (car runs like crap)
- short shifter
- blower issues
- let there be light
- Help timing after rebuilt head - 82 Accord EK1.
- knocking noise...
- 4th gen. H22 ??
- Catbacks for 04 Accord?
- Are there rivets in the metal inside the rear bumper?
- 96 SRS dashboard light reset
- I need a stock catback exhaust.
- PROBELM WITH HEAT FUSE AND TEMP GAUGE ON 91 ACCORD
- 7gen suspension questions
- oil in sparkplug hole
- Engine thrashes randomly at low rpm - What gives?
- 1999 Honda Accord Coupe LX for sale
- 1990 Accord weird problem..need help
- 97 accord 4dr :: Rear Window Removal :: Help!!!
- Want to change my engine from f20b3 to vtec engine
- Hot Honda
- Best place to purchase an EGR Valve?
- RPM gauge goes from 3, 5 to 1.
- Windshield wiper tension question and welcoming myself to the forum.
