PDA
View Full Version : Honda Accord (1990 - 2002)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 [304] 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372
  1. '90 Accord EX 5spd, 151k miles - CEL
  2. Suspension is eating tires??????
  3. Changing the H4 bulb in Depo BlackHousing Headlights?
  4. Rubber glue compound on headlights
  5. Engire error Code?
  6. Repainting rear bumper?
  7. 4th gen startig REALLy bad in the mornings
  8. Honda Accord Transmission
  9. what do u guys think of dc 4-2-1 2-piece ceramic headers
  10. 6th gen CEL
  11. Race prep
  12. Need help locking the axle back into the intermediate shaft
  13. Nitrous: Pointless?
  14. changing rear disc brakes?
  15. JDM Projector LIGHTS
  16. What gen/name would I call this stock accord rim?
  17. teflon tape
  18. No signal to coil HELP!!!!!
  19. 93 Accord problem(maybe)
  20. f22b1 or f22a6?
  21. Engine side of rotation!?
  22. 92 accord question
  23. How do you remove/install bumper lenses on a 95 Accord?
  24. HOW DO I FREAKING TAKE OUT 94 accord front bumper? please help
  25. HID installation help
  26. Need help diagnosing a noise...
  27. Clutch problem. Please help. I'm stranded
  28. (94-94)cd5 dc lower stut bar on (90-93) cb7
  29. Anyone have carfax to check history?
  30. OBD II Codes P0170,P0171 & P0420
  31. wipers not working right
  32. Need A Part Sourced...
  33. Do I need to loose or remove the motor mount for a TB water pump job
  34. 1999 Coupe: How to change the directional bulb???
  35. use Accord VSS on Prelude ?
  36. Audio Code for 1998 Honda Accord EX 6Cyl
  37. strange sound from engine?
  38. Just picked up a new accord last night (4G.)
  39. 94 accord tranny swap
  40. 96 Accord EX Alarm question
  41. Q: HONDA SST Mrfs and Discount Parts Sellers - Anyone have a list?
  42. why is my f22b1 so slow
  43. Anybody use this spring/strut combo?
  44. h22 swap
  45. Problems w/ my vafc
  46. help please!
  47. new to Honda accords, need info
  48. CAN I SWAP IN A 2003 V-6 AND AUTOMATIC TRANNY INTO A 2002 I-4 ACCORD
  49. suspension ??
  50. gutted cat
  51. accord trouble
  52. Automatic to Manual Conversion....help
  53. 90 Accord AT ex wont shift
  54. GSR rims on a 2000 Accord Coupe 4 cyl?
  55. Accord Troubles
  56. cat-back & ECU HELP! 2004 Accord coupe
  57. Converting Auto to Stick.......
  58. i have oil in my anti freeze resivor tank
  59. Trunk Width - anyone know it
  60. 91 Accord with 247k miles....long road trip worthy?
  61. Help with starter
  62. catalytic converter 6th gen 1998 honda accord dx
  63. air conditioning help for 1990 EX..only cold on passenger side
  64. 4th gen jdm headlight cutoff
  65. First time Honda owner - car needs some work- got Q's:
  66. How do you know if you need new coilovers?
  67. Differential question
  68. What next on a 6th gen
  69. 94-97 Projector Headlight Installation
  70. I have an 87 lxi hb what kits will fit on it?
  71. F23A1 Camshaft
  72. 4th gen CAI
  73. I need some engine flushing ideas.....
  74. big decision
  75. removing accord sign
  76. 91 Accord EX with a scattered engine, please help
  77. emissions parts between engines
  78. DIY Homemade Rear Upper Strut Bar (Questions)
  79. any info on an SRS cable reel?
  80. question what would u guys do
  81. Accord Question
  82. can i swap a f22a4 head for a f22b1 head?
  83. Swap resell questions
  84. can i swap a f22b1 head for a f22a4 head?
  85. any other 6th gens with this problem?
  86. gas gauge is out
  87. Cleaning interior
  88. 6th gen. accord. short shifter??
  89. key stuck in ignition - manual
  90. Newbi form tha other side!!!!!!
  91. H23 vtec
  92. About stock headers on 94 Accord EX ????????
  93. Intake Squealing, any suggestions?
  94. Car drives better on a near empty fuel tank?
  95. f22b1 cam
  96. 6th Gen V6 PCV
  97. 90 accord power window, wont role back up
  98. HELP!!Bolt-ons for 95 av6
  99. Intermediate (jack) shaft
  100. Oil Level
  101. Need sugestion on clutches for a 98' accord????
  102. 1990 Accord
  103. dsm turbo manifold
  104. Stock radio/tape deck removal of 92 Accord
  105. cold air intake help
  106. brake issues help!
  107. Drop the JDM v6 engine in 5th gen Accord
  108. Indiglo gauges on 94-95 accord
  109. Need a new engine for a 92 LX 4 Door Accord?
  110. 2000 Honda Accord MAIN REQD
  111. F23a1 Rev Limit...
  112. HELP A FELLOW H-T MEMBER
  113. Query: Confirm 91 Accord Valve Clearance? Haynes says .010 and .012.
  114. F22B Rods/Pistons
  115. F22a1 timing marks
  116. Primary oxygen sensor heater
  117. 96 accord with tenzo rs-5
  118. gauge cluster went out
  119. SO MANY LIGHTS!!??
  120. turbonator
  121. Do these works necessary?
  122. buying tranny????? help
  123. turbo kits for 90-93 accords
  124. swap
  125. piston firing problems
  126. Shocks?
  127. will 16" rota c8 fit on 94-95 accord
  128. Want trubo for 94 Accord EX
  129. 94 - 97 Honda Accord aftermarket parts
  130. EGR Valve Cleaning
  131. 100 bucks reasonable for spring installation
  132. Autocross Accords
  133. bumper fitment
  134. Shifter Question
  135. Cheep power
  136. oil pan stuck?
  137. Removing the rear Speaker covers.
  138. How much do these wheels cost brand new?
  139. Can i use an accord mount on my prelude
  140. USDM versus EDM - Exhaust diffrences?
  141. please help. right turn signal wont turn off
  142. temp control wire diagram
  143. just a question
  144. H22a question
  145. 98 accord cloth seats for sale
  146. Getting scratches outta rims?
  147. p13 ecu auto vs. manual??
  148. anyone have a list of top speeds of honda cars ?
  149. h22a swap axel question
  150. how do you remove 4th gen center console??
  151. Please help... TIMING PROBLEMS
  152. 92 wagon-radio won't turn off
  153. Horn stopped working when SRS light came on. Any info.
  154. what causes bubbles in ur tire?
  155. Alert: 17' Konig Traffik for sale !
  156. Is it worth it?
  157. accord headers
  158. How about DIY?
  159. Another simple H22a question
  160. took the accord on a trip
  161. 92 Honda Accord won't stay on
  162. front bumper for 01 coupe
  163. IGNITION QUESTION?? H22 SWAP?
  164. 5th Gen: JDM stock White rim or SlipStream ?
  165. shaved door handles kit
  166. CAI vs. Short Ram II
  167. How illegal is it....
  168. antennae help pls.
  169. rev limit on h22 6250, need help.
  170. 4th gen, Ignition control (ICM) problems? Car just cuts off
  171. this is an odd problem
  172. H22 in a 93 Accord
  173. Automatic-Manual Tranny Swap
  174. 95 power windows
  175. did search.. cant find dizzy plug order
  176. The Best type of Cam?
  177. 88 LXi Accord - Mods?
  178. what is the best ECU for H22a?
  179. bolt pattern
  180. 1996 Accord Power Window
  181. Oxygen Sensor and SRS troubles
  182. is it gone????
  183. 4th Gen. tail lights?
  184. Parting out 90 accord 4dr EX
  185. Amsoil 25k mile oil changes
  186. help from an expert?
  187. Just got my 2004 accord, need to know about sound systems!
  188. help
  189. Tire air pressure
  190. i/h/e question
  191. vss sensor
  192. changin struts with coilovers?
  193. 96 accord god help me
  194. 2 questions 4th gen
  195. What is the name of this part?
  196. 91 Accord EX Timing Belt Broke...HELP!!
  197. need help
  198. Accord parts on Prelude ?
  199. **HELP** H22 jdm vs usdm. How can they be told apart by looking
  200. 4th gen antenna assembly stuck! diagram? tips?
  201. Disabling annoying seatbelt beeping
  202. 1993 Accord Help
  203. My 90 ex accord is idleing very high @3000 rpm
  204. exhaust for 99' 4 cyl sedan
  205. 6th generation swap worth it?
  206. Lower Ball Joints on Accord
  207. 5th Gen Handling Problem
  208. ecu fuse keeps on blowing
  209. Timing Belt Please all look!
  210. Safe Mode question on h22
  211. ( newbi ) Accord 00 H22a swap ???
  212. 99 honda accord won't start.
  213. Info needed to fix code errors..........
  214. bad fuel economy? 19 mpg for 4cyl accord
  215. do they make a front bumper like this ?
  216. which motor mount will fit
  217. timing issues with swap. please help
  218. Sticking Throttle Plate
  219. ECU diff in 94-95 96-97 accord ex's?
  220. No pressure in fuel lines
  221. FYI - 4th gen weight
  222. Mugen Grill Question
  223. O2 sensor for accord 02 headers
  224. lugs and wheels
  225. shocks for H&R RACE springs
  226. Wrecked 94 EX
  227. 91 Accord EX Timing Belt
  228. Throw bearing noise
  229. how long do i wait between spring installation and alignment
  230. Temperator meter and check engine light on
  231. Quick question about the 98 + Accord 2 door.
  232. 96 automatic transmission into a 90 accord
  233. Turbocharging 91 Accord
  234. Hesitation in acceleration
  235. Cooling Fans
  236. 4th gen JDM corner light modification
  237. h22 in 90-92accord
  238. Wheels for 94 accord ex 2dr
  239. Clutch Problem
  240. need help 97 accord
  241. Side mirror control not working
  242. h23 into 98 accord, never done before?
  243. No brake lights, and car is stuck in park???????
  244. 40 Offset
  245. Help:5th Gen Accord with Brembo 12.9" Brakes
  246. Headers For My 94 Honda Accord
  247. What are you supposed to do on your 180k mile tuneup?
  248. getting new clutch
  249. changing the auto trans
  250. 4th gen brake issues (should I buy new rotors?)
