Do they make aftermarket ECU's for 2.2 non-vtec 94 accords?
searching for aftermarket ECU for my new project, 94 non-vtec LX accord, does anyone make one? the reason i want it is so i can eliminate the speed governor and maybe get better fuel management, i am in the process of creating a non-vtec 2.2 to see if it can go head to head with its twin with the H22...haha, i am weird.
yes, its more of "chipping" not a new ecu
several places out there will dot his for a decent rate:
email me or look around online, there are some good guys here on HT that do it:
Mkteller8@aol.com
Mkteller8@aol.com
obd1:
ecu's are easy to come by:
Ecu's are easier to chip or if you plan to use Hondata' you have to use an obd1 ecu:
with obd1 you dont have to mess with two O2 sensor's and a lot of other "nonsense" that comes with being obd2:
If you are doing a swap: obd1 motors a hell of a lot cheaper: same with finding the matching ecu;
plus many other things:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KTeller8 »</TD></TR><TR><TD CLASS="quote">obd1:
plus many other things: </TD></TR></TABLE>
Can't pass smog check in Cali if you got the conversion done tho'
