View Full Version : Honda Accord (1990 - 2002)
- 5g auto to manual swap
- prelude to accord swap
- 96 accord swapped with a 92 h22 -- How do I check the CEL ?
- headlight trouble..
- What's the problem?
- h22 swap for 6th gen coupe
- something up with the car
- Right Turn Signal Problem
- My wifes 03 Accord
- 96' Temp. Gauge
- 93 idle problem
- how do you remove side mouldings with 92 accord?
- 94 ACCRD Engine starts, runs briefly then dies no cel
- why so much turbo stuff an no nitrous?
- any good timing belt and other things done at the same time HOWTO's?
- who says the accords can have good brakes
- What brand name shock?
- would GSR blade rims fit on my 97 accord with stock specs of 195/60/15?
- Turn Signal Flasher Location
- Power Steering Removal Kit?
- how much loss?
- Coilovers
- Another Exhaust Question
- noise in head after t-belt change, can someone help
- springs for my 88 accord
- Finished my suspension today
- vtec vs nonvtec timing belt
- Do throttle body spacers help horsepower?
- My 1996 Accord CD/Radio Unit
- H22a Swap complete....BUT!!!!
- CRV Power Train into H22 swapped and boosted Gen 6 accord
- eiback springs question
- Torque specs on 97 2.2
- What is the fastest Accord available right now (stock)...
- H22 timing belt help!?!?
- 1990 LX auto Coupe S light stays on
- 1999 Honda Accord 4 Cylinder - Auto to 5-Speed Question
- blown motor, suggestions........
- Suspension Question
- Overheating w/AC on @ idle?
- Transmission problem with 94 accord
- Accord 90 i need quick help!!!!
- h22 swap problems
- Which spark plugs & wires would be best
- Cold Air Intake Question
- how to stop the dc header rattle in 94-97 accord
- another turbo question
- 2000 accord headlights
- Tranny Rebuilt?
- Accord 1990 - Stop/horn fuse blows when horn is used
- Accord part number?
- F23a1 Accord 2 Wire IACV Conversion
- Invidia\Skunk2 Silencer
- my car stalls when im parked.
- Need help on deciding on a wheel for my 03 sedan.
- What kind of bulbs does the Accord LX 2005 take?
- 2000 accord oil change timing belt
- turbo accord question
- Accord Coupe CG4 Front Brake Pads Replace
- automatic mirrors/seatbelts not working on 90 accord
- Any idea what this sound could be?
- h22 for sale
- 99 av6 sedan exhaust
- Bolts (How To Get Them out)
- h22 in a 2000 accord ex
- Is there only one fuse panel for the 90-93 accords?
- Difference between 94/95 and 96/97 Tail lights?
- Cat. Converter bolt ?
- turn off car noise?
- (90-93) HID Retrofitting question....
- indiglo gauges problem
- no 4 ways or speaker sounds??????
- Maplamp DIY on a Gen5 2door
- Question about glow gauges (install)?
- noise from rear backin up??
- 03 ACCORD LOWERING HELP!
- F22a1: White Smoke???
- h23 in a 94 LX
- 98 Accord Lx
- heat shield
- Looking for a Valve cover Front short bolt 98 accord 2.3L
- changing the serpentine belt??
- 2003 Oxygen Sensor
- How much boost can I apply to a stock 97 accord sohc vtec motor aka f22b2, HELP!!!!
- OBD1 H22 into 96 Accord EX -- Distributor wiring woes!
- Disk brake question
- Who knows how to build and get the most horses out of an F23 series?
- 91' Auto tranny problems
- replacing factory steering wheel w/ airbag
- 6gen auto to 5spd in progress.. have questions at hand..
- 93 accord chime
- 2005 ex help
- Changing brake pads (ABS)
- any one with an 90-93 5 speed accord fom minnisota 4 sale
- Does a 96-97 stock front lip fit on a 94-95 accord?
- Check engine light........
- Got suppercgarger???
- F22A1...what nitrous shot??
- F22B2 Turbo powerband
- stock hubs?
- squeaking spring
- windshield wiper issues
- accord 93 spark plug order
- Hologram in NightHawk Black paint?
- 99 Accord Problem
- what are the best coilovers for a '01 accord with 17" chromes?
- removing abs unit, cruise control and A/C
- camber kit help
- Tuning a F23A w/ a wideband
- water temp needle all the way down
- 1990 LX AUTO, Reverse Gear Grinds 'Sometimes'
- 94 accord revs up and down when started , also running very rich
- Door handle conversion
- Brake Caliper Torque Spec
- h22 in accord.. knock sensor ????
- Dyno
- Flashing 'S' on my Gauge Cluster?
- Acura seats in a 5th Gen Accord...Help please
- how do u turn off the maintance light on an accord lx 1998??
- nasty suspension Lean - bad struts?/ springs? HELP
- Transmission Question
- accord rear struts on civic?
- Fuel Filter Problems
- 87 Accord Carb Stalling
- indiglos problem
- Fuel Injection Air (FIA) Control Solenoid Valve F22B1 OBD1 HELP! PICS
- FogLights
- 00 accord 1.8
- 94 f22 conversion to 92 accord
- Whats the most economical swap for a 90-93 with decent power output
- 86 accord will not start!!!
- Is there an aftermarket AC system for a 86 Accord?
- Greddy EVO 2
- Price to fix?
- replaced driver side axle, works great, but ABS light is on -wierd story-
- Need help Please?????
- new guages
- Car dies, Will not start......exhausted efforts...
- rear mounted turbo on accord?
- 2005 Manual Transmission Problems
- Spark Plug Housing Stuck...How To Get It Out?
- Coolant leaking onto ground like half a cup then stops. 92 EX rad problems help
- 91 accord acceleration problems
- Power door lock actuator? (Searched)
- F20B - H22 Motor Swap - 1994 Accord LX
- Mix N Match
- 96 Accord CEL Code ?'s
- shocks for my 94 accord?
- Exhaust for 6th Gen
- Alignment
- 96 accord jdm h22a wiring problems
- I cant get my car to start
- Hole in my B pipe
- 250-300 whp with f22 turbo setup?
- knocking noise in engine compartment
- F22A1: SPECS
- The "Tornado" thing-a-majig
- 1998 Accord EX : Motor ticking/knocking sounds
- v-tech help
- Looking for Corner light for honda accord
- Inexpensive places for OEM Accord parts?
- Need Help!!! Changed Oil now car wont start?!?!
- 2003 AV6 brake pads?
- Finally getting my 2005 Accord Coupe EX
- 04 Accord EX 2.4L Cold Air induction question
- timing belt change
- Oil in intake
- h22a1 / f22b2 swap block question
- My brother has an accord 05 what to do
- JDM F22B into a 93 Accord...what else do i need.
- NEED 99 Accord Center Console
- Looking for fog lights... Help Please!!!!
- how do i take out the master switch for the lights
- where to get....
- 01 Accord A/C wont work
- 88 lxi, new rubber valve cover garments still leak
- What other year accord hoods fit a '95 LX?
- T25 Caliper Bracket?
- 98 Accord - Can't read CEL code with OBD-II reader
- 97 4DR Accord Part #
- '94 Accord clicking noise when making left turns
- shifting problems in a 90 accord
- Block Repair if possible..?
- igot myself the h22
- 91 Accord- Cooling fan problems
- motor swap help needed!!!
- need a new clutch
- Why does my stereo not work and how to fix
- F23 F22 slight of hand (interchangability)
- JDM Question
- Quarter Panel Rust
- 92 Factory Alarm problem
- H22a wiring problems
- 1990 Accord LX Overheats
- Driver's Window help!!
- KYB AGX what adjustment setting?
- 91 accord LX, gas problems/mileage
- Broken wheel stud/Drum Brakes
- 86 accord swap question?
- my RPM chokes when im idling..
- Flushing Abs brakes
- Emergency Brake Stick Replace..... Need some sights
- pulling engine
- kyb struts
- f22b sleeves
- accord transmission swap, step by step?
- "exhaust" question
- i need help, trying to make my 97 accord a 5 lug pattern
- 98 Honda Accord V6 Gas Fumes
- 1992 accord ex problem.....any advice?
- P/s pump
- I Need a SPARK!!!!
- Will 94 Accord Coupe doors fit a 96/97 Accord?
- Anyone buy a mugen lip off ebay ?
- Alphawerks Header
- 94' accord engine stall in summer
- Recharging A/C question.
- Tanabe looking a few Accords
- how to flush radiator fluid.
- Engine ?
- A "how do you..." question, please help.
- Oil light on old accord at idle...
- Gaskets
- Help me Plz..............................................
- Still no short shifter for 2000 Accord?
- 1990 Honda Accord CEL
- How to switch transmission on V6 2K Accord ?
- washer camber trick? 90' ex 4 door
- h22a swapped into 95 accord lx electrical problems!! please help
- Intake Pipes?
- Vtec Question?
- Caliper Help please!
- springs for my accord
- 2002 honda accord clock light question.
- squeaking/rubbing sound after new axle install
- Honda Accord SUCKS gas
- 97 AUTO Accord ECU adapter Harness Question
- 93 accord transsmison prob
- auto to 5 sped conversion questions
- Help!! Horrible Noise!!
- how to remove 5th gen cluster
- ST front sway won't line up.
- Ticking noise
- 97 accord ex will an afc 2 work with it?
- ADR GT-Sports
- 95lx - rattling under engine head
- Halfshaft replacement on 1997 Accord
- where is the BRAKE wire on a 94?
- just picked up a new accord
