View Full Version : Honda Accord (1990 - 2002)
- Accord tire question
- New Fellow Accorder's HELP
- question for dropped car owners (not another one of these!!!)
- 2000 V6 Headlamps Burns Out @ Once A Month
- V6 engine in 93 Accord?
- How many miles...
- Loud engine
- Needed: pinout for 98 Accord LX F23 Vtec
- agx bolt
- Leak in EVAP control system
- smoking oil ...
- f22b1 into a 4th gen(nothing in search)
- Stock Spring Rates
- does anyone know were i can get a 1999 accord computer?
- problems getting my password to my email.
- Need Really Detailed pic of 89,90,or 91 Accord inake
- What else can i do
- mounting tweeters in a 97
- need REF info for h22 in cali
- Car wont start?
- good deal on F22B1 head?
- OBD2 2nd O2 what wires do what?
- Rumor check... wait before ignition???
- help me figure out what is wrong...
- Car shudder at low RPM
- vss 97 accord
- Lights Dimming
- what engine is this?
- Problem with Keyless Ignition
- Short Shifter?
- Question on an Ebay Accord item
- 2001 accord coupe rear disc brake?
- need h23, f22a downpipe/b-pipe ASAP
- Did search! Need ideas. Poor Gas Mileage on 94 ex auto
- Interior lights
- Accord buying!
- 90-93 accords...???
- how much hp dose a stock accord ex have ?
- is this an auto or manual?
- h22 HELP needed!!
- Any CD/MP3 head units in ~100-150$ range??
- 90 accord intake
- looking for a 90 accord ex computer
- 95 V6 Accord Engine using oil
- P-Spec Shifter
- Videos of Turbo'd F22 Accords?
- 90 Accord 'correct' temperature gauge position?? pic included
- remote engine starting system
- Are kyb agx shocks adjustable as far as ride height or dampening on the car or both?
- What are some good aftermarket brake pads simaler to oem ???
- projector retro-fitting help
- My Accord stalls and runs rough when decelling
- New pads & rotors last week - pulsing severely at 65-70mph when braking
- What year did Accords start coming with saturated injectors?
- PAINTING AND POLISHING RIMS
- Has anyone changed the color of gauges?
- 97 Accord SE Shift Lock
- tire suggestions for 90 EX?
- Need some tips on what I need to do to my 2000 accord V6
- Seafoam before or after changing oil?
- EGR OR CATALITIC
- Cold air intake vs. Ram intake difference in performace?
- Installing a H22A tranny in a 94 Accord LX F22B2
- 1990 accord
- Accord rough idle HELP !
- Clutch Stuck
- known problems with 92 - 97 accords?
- cryo treatment to get around sleeving?
- 93 ex accord HUMMING
- '98 Accord engine swap
- one ,knBrakes
- Car died after changing battery.
- Wheel Size
- mint prelude si rims for sale
- Seriously freaked out when I looked at my spark plugs! (pictures)
- Indash lightz...
- Found a DIY Short Shifter install page for 94-97 accords
- Short Shifter help! Please! hehe
- 95 lx --> inside temp control dial
- problem getting spark
- Performence\Racing Chips?!
- Turboz in the accordz
- Oil In Spark PLug Wires
- 91 Accord auto trans trouble
- Help choosing the best engine!!
- H22a Coming Soon!!!
- just swaped a F22B2 in my 92 accord but having problems
- 87 brake job question....
- ST rear sway bar?
- O2 sensor question
- Hand me down
- HOW DIFFICULT IS TIMING BELT WORK?
- seat question
- Possible 5 lug conversion on a 93.
- transmission question
- how do i change it????
- What octane?
- Buzzing Noise
- 94 Accord EX Rear Lower Control Arm Bushing?
- caber adjustment
- valve adjustments on a 93 accord ex...
- gear ration for a 5spd f22a1 tranny
- Accord rough idle
- Replace green back light behind LED Clock on Dashboard?
- One REally Weird Problem/93 EX
- ABS light problem
- HELP! Rear Toe-in Problem
- Me Vs Camaro SS@California Speedway (VIDEO)
- Mad squeaking from Suspension
- P13 Mugen ECU?
- 94 Accord EX Turbo ?
- Rims and tires for '95 accord EX 5 spd
- Need ASAP... wiring and ecu for 94-95 f22b1 vtec motor
- 95 Accord headlights upgrade. Opinions, suggestions?
- Any tunning tips for VAFC on V6 J30A1
- TCM CODES
- Vibrating Noise?! 94 accord ex
- Which pulley kit for a 6th gen 4 cyl accord?
- need hlep asap
- problem with alarm
- decisions on leather seat upgrade
- F22 block with H22 rods?
- steering wheel behaving weird...
- help my car isnt running
- 87 accord, weird idle drop......
- Tuning A S-AFC
- What do these simptoms describe....
- idle again
- is this good deal?
- 87 honda, replaced brakes but think i just made it worse!! help!!
- Where to get a reasonably priced O2 sensor
- Can someone please tell me what rim can fit on a 1999 accord?
- Clutch question...
- bleeding the cluthch on 93 accord
- New to site, own a 92lx coupe with h22 transplant underway now in Moncton N.B.
- 98+ v6 accords, how many miles per gallon do you get?
- Can someone post Pic of a 98-02 Accord coupe on Eibach Prokit....
- 97 Accord Door leak
- Steering wheel noise?
- Pics of my 99 accord
- steering problem
- 96 lx brake removal problems
- 87 accord, rear brake drum key????
- radio issues
- help, tranny problem?? engine problem?? ignition problem
- 1990 Accord EX AT trans problem
- HOw TOO DOO?
- Really really really bad shaking
- 1989 accord engine swap
- What would you do?
- Aftermarket sites
- 91 model / Transmission Control Module (TCM)
- Put in gear,rpm drop??
- Pnt Job in So Cal
- Timing question about dizzy position
- S2000 Steering Wheel...
- help. seatbelts..! plz read.
- Dashboard lights
- 94-97 DIY: Prothane front sway bar bushings and endlinks
- Preamp outputs on an 01' accord 2dr factory cd/tape/radio....Yes or No?
- Hit curb 03 accord
- o2 sensor 1 wire to 4 wire
- Help with Windshield wipers
- 94 Accord, Weird Idle HELP
- accord GT3's...
- 6th gen accord engine swap or tranny swap?
- Honda Accord 2004 VIN code question
- TENZO R RIMS WONT COME OFF ACCORD HELP!
- K20A (R)
- 91 accord/ can I replace the tranny w/ a OEM 92 Acura Integra tranny?
- Nitrous Dry setup
- '94 Accord EX running problem
- frankenstein f22 q's?
- Anyone know of LOWEST PRICE ON FALKEN ZIEX ZE-512 TIRES
- BAD, REAL BAD vibration, did many of things.........
- HELP: accord getting bad gas mileage
- 94 Automatic Transmission Problem
- Oil overfill or underfill????
- EGR valve or what? Please do help!
- '91 Accord
- spark timming
- jdm engine parts
- 5 lug conversion
- i want to post in the classisfieds
- engine for sale
- newly installed brembo blanks and hawk pads
- 1999 Accord problem
- flywheel question?
- Boosting with stock internals
- us and jdm p13
- F22B1 Build Up. NuBe needing help...
- Features in 2000 Honda Accord SE
- Car Trouble
- 6th Gen Accord Disc Brake
- Will 43mm offset work on 2005 Accord EX
- How I passed smog in Calif OBD2 P0420 write up Accord Catalytic Converter 1998
- Few questions on 94 lx 2dr
- MESSED UP ACCORD
- quick question
- stock wheel size??
- side molding
- question about a swapped 90 dx h22a accord
- Draft: 2004 radio / climate wiring diagram
- 97 V6 LX or 98 V6 EX, what would you want?
- Any cheap deal for a turbo on 02 accord?
- F22A Turbo accord with Dyno Sheet
- Bolt patern
- 03 v6
- H22a/Type S
- Help lowering 94 accord
- Brake pedal oddity on 97 Accord.
- Stats on a Honda....
- Headlight upgrade for 2003 Accord (7th gen)?
- Heater fogging up window, making wierd spots.. WTF?
- navi 04 accord
- 1994 front wheel bearing howling
- Changing Gears Hard
- Accord Omni-Power USA Full Coilovers STREET -- need to pay for ticket :(
- boat looking!!!
- calling all F-series gurus us/jdm/edm
- Hard to get into Gears
- engine problems, i need help!
- 1992 Accord RPM's Dropping!
- Anyone know where to get Rims / Tires for cheap?
- HELP! i've got tranny problems!
- 94 accord ex 4dr, front door panel speaker install
- will a f22a1 intake manifold fit on a f22b2 head?
- help 1989 directionals
- question about my 90 accord
- accord underdrive pulley
- f22 swap questions info needed ASAP!
- question about "jdm" high mount brakelight
- 02 Accord V6 (Brake Pads)
- Thermostat location / Rotor / distributor replacement...Difficulty ???
- 94 accord wheel studs
- info plees
- Will it be bad for my engine to leave my cold air intake on during the winter season?
- '94 Transmission burning smell?
- I want to get this question answered once and for all
- how to disconnect abs???
- 90-91 Accord Door Wiring Harness Question
- Lowering springs\coilovers 94 accord ex sedan
- slight ticking noise
- 1992 Accord Ex - Need Help
- transmission problem(5-speed)
- Check engine light on Accord 2000 EX
- Relpacement rear speaker enclosures for a 93 accord
- Emission coil help.
- 94 Accord Gauges - where to buy
