View Full Version : Honda Accord (1990 - 2002)
- how to get jack out
- new rotors, need new pads?
- Suspension Techniques Lowering Springs
- maintainence required light on..
- APEX WS COILOVERS for ACCORD 98-02
- 1994 Honda Accord LX with non-working dash and tail lamp lights
- inner headlights, do they ever turn on?
- Exhaust
- F20B Parts.
- Need Timing belt change in Seattle, WA area
- 92 accord
- need some struts for a less bumpy ride
- question on sprk plugs
- wtb f22 turbo kit or setup
- What kind of shocks.
- AT drain plug
- if i was looking for a head how much??
- 93 accord
- H22 swap with p72 pinouts
- maintenance schedule for 2003 Accord LX
- How many qrts. of engine oil?
- all H & F series tranny fit F23a4 engine?
- PULLY BOLT BROKE IN CAMSHAFT
- 91' Accord DX Fuse Locations
- Honda Accord Coupe 2000 - need help on purchase of H&R sports springs
- 92 accord battery trouble
- Ignition Coil Connector
- Need Help Installing New Rotors
- Help! Need Brake Caliper Advice - 97 Accord
- Foglights
- Timing Belt Replacement Necessary?
- 94-97 Manual Tranny.
- code 5
- H22a tapping the tranny question
- 1996 Accord with H22A
- Horn Voume - Arming Alarm (Wiring Issue?)
- Brake Service Lights Comes on Sporadically
- blower motor resistor
- Powerslot Rotors
- Tire size
- Body Kit, Exhaust, Headlight, and Door Pannel/Vent questions
- 93 accord pros and cons
- Whats going on with my cooling system?
- I need help H22 Accord needs boost
- How do you run TCU Diagnostics?
- throw out bearing
- 5th Gen Accord Shocks interchangeable w/ 4th Gen Prelude
- Auto shift knob?
- White smoke
- Honda Accord EX 2000 6 cyl - No light for the clock?
- 96 Accord EX 5spd gear ratios
- VTEC Exhaust on a Non-VTEC?
- 1997 Honda Accord Stereo Problem
- Brake work recommendation
- Difference between Greddy sp2 and evo2?
- 86 Accord conversion to a 89 Integra Motor
- 96 Accord throwing EGR Code.......
- Timing Question on 1992 Accord
- Looking for A/C...
- Oil in Sparkplugs
- Q: '98 Accord LX - what is needed to upgrade to EX engine
- Q: Recommendation on online Honda parts store
- Still doesnt work
- Recommended Brakes?
- question about cooling fan switch... searched.
- Will p28 run an H22a
- Clutch pedal clicks as I put it in...teach me to fix this please. I want to learn
- will obd2 h22 injectors work in and obd2 f23?
- newb coming up, wing doors bumper replacmnt
- about my dash board and tail lights
- Im new, and just wanted to say hello
- difference between CL tranny and Accord
- Low speed hesitation
- Cams for 2004 V6 Accord
- CYP sensor
- Suspension noise
- where's a good online site for ordering header gasket and
- Ignition switch and power door-locks conflict
- dropped 03 accord
- F23A Manifold bolt pattern match a F22B?
- cheap place for axles???
- projector lights
- 2004 v6 accord poor gas mileage
- Engine Temp problems 4th gen
- '91 Accord EX Wagon factory fog lights?
- prelude tranny and LSD into a 5th gen
- Buying an Accord: help
- turbo manifold for 92 accord?
- Are there any benfits of projector headlights?
- Help with remote lock/unlock on '95 Accord?
- New (to me) Accord
- H22 SWAP HELP??
- Air Conditioning Idle Vacuum Adjustment (Location?)
- 1998+ Accord buying advice needed
- My 98' accord shuts off while im driving.
- recalls?
- Urgent help needed
- What is it called??? Someone...
- CA smog failed at honda dealer please help!!
- Starting Problem and not main Relay
- f22 turbo mainfold
- Question about 1994 Honda Accord Vtec computer
- 92 accord HELP need power
- '99 V6 Coupe EX Auto vs. 4 cyl. Coupe EX Mannual
- AC please help~~~
- !!!!PLEASE HELP!!!!
- emission station in NJ
- Lights are popping up on my DASH and Brack Question
- 2 questions, im new (97 accord LX)
- Help is needed on finding certain OEM rim!!
- Adjustment bolt
- Accord 2004 EX V6 Fog with parking lights
- Floor Mats.
- h22 timing and fuel pressure
- mugen or type r lip?
- more accord hot weather starting problems!
- Unstable Idle +- 100rpms
- What size t3 on a 94 LX?
- h22 swap into a 6th gen accord
- HELP! axle wont go into tranny!
- muffler
- Ok... I could use some help... Koni Red v. Yellow
- Accord vs. WS6... uh oh...
- Is there a tech write up on valve cover and plug seal replacement?
- getting a "head"?
- Starting Problem
- is it needed to reset the ecu after installing intake
- Jdm headlights for 90 accord???
- Smog failed Please help!
- michellin tires. Are they good?
- 91 Accord - Loud noise 45 to 60 MPH
- Honda Lingo........
- H22 problems
- Why does the automatic H22a have 180hp and not 200hp?
- Make my decision...
- is it bad for my engine if vtec kicks in at 2.5 rpm
- H23 and F22 tranny gears interchangable?
- Little black button by coin tray
- Need to ID motor Year model
- NOO B: 96 Honda Accord EX........ODBII......HOW TO READ CODES?
- Bay Area, Need Shop Manula to replace Water pump/timing belt on 1992 Accord
- Specs for Automatic H22a JDM
- UK Accord Type R
- 92 accord need power HOW?
- Where can I find K+N typhoon air intake for 95 Accord?
- 2000 Accord Coupe V6 EX lighting diagram
- 91 Accord won't start
- 5spd conversion
- black tailights
- accord 00 model
- How to: recharge your R12 a/c system
- Racer Design???
- 2004 Accord wanna have some power
- Brake Noises
- need help with SRS light on 02 cord
- 94 Accord ex Automatic tranny q's
- chrome trimming around windows...
- F22 ECU with an H22 Engine
- can anyone post some picture for me
- Accord trim
- help! header bolt broke off!!!
- Best place to buy a cat converter for 98 accord lx 4cyl.
- CEL... Got Code
- Forged wheels?
- Rough idle at 650 rpm to 1k rpm with vibration feedback
- ECU Discussion
- What needs to be done @ 100k miles?
- Turbo F22 Accord *non-VTEC boosting 8psi with essentials?
- pistons
- 92 accord LX overheating fans turning on late problem
- 94 Accord EX radio problem...
- DIY black headlights and tailights?
- Stearing Problem
- H22A
- Need to get light flywheel, clutch, pulleys and cam gears for 03 v6 coupe m/t
- A/C not working.
- 1999 4cyl Accord Tranny
- Serious Problema!!
- Engine swap help/info from you accord guys....
- How low?????
- 3rd gen swap?
- 1982 CVCC engine trouble.
- Coilover Decisions/Questions....
- Cost for engine swap?
- Too people without a cat.
- V6 2000 with 160k
- My frustrating experience with Hollywood Honda and check engine light OBD P1382
- what motor should i get for my 91 honda accord???
- Ok to use Royal Purple Max ATF?
- Window Regulator
- Building My Block
- where does the tranny fluid go in a 95 automatic accord???
- ULEV Accord Catalytic Converter - PLEASE HELP
- one or two?
- Can I put 6th gen 4 cyl. wheels on a 5th GEN 6cyl.?
- 90 Accord keeps stalling
- Changing out a distributor
- What is the correct timing on a 1991 accord?
- Oilpan?
- would a 94-95 lip fit on my 92 accord
- clutch problem
- Jumping RPM
- 95 honda accord..... is the front rotors held on with screws??? or the dam bolts
- 1995 honda accord lx, whats the chassis code??????help
- what do you think?
- headlight issues
- Shift Kit for a 00 Accord?
- auto > manual swap
- Best OEM replacement struts to buy?
- im new to this suspension thing, please explain
- Blown up 91 Accord Engine - how far can one run without oil in the engine?
- Hand-brake light problem
- resonator? haha
- 97 accord ex knuckle into 93 accord lx
- exhaust systems for 2004 accord?
- 94 accord ex (canadian model) gas gauge doesn't work
- would a cam sprocket for a 92 accord head work on a 95 accord head
- prelude exhaust?
- Problem with acceleratoin - feels like I'm running out of gas
- simple header question
- Stereo Removal
- b16a on 93??
- ECM on 92 DX 2.2 Location & Part number
- Question about cig lighter
- possible to install headers on 95 accord without removing engine block?
- catback or muffler
- audio error code
- Power door lock weirdness
- 98 Accord V6- Dealer dumbfounded
- A quick fix to my Main Realy problem?
- ABS Accumulator leak
- F20B Engine Swap
- Weirdest of all things: i can't pass inspection in PA for an Accord 1999..Please read (code is P0420
- Rain X
- AC help, pls.
- is $430 shipped for 94-97 JDM black headlights a good price?
- Need Torque and Sequence for Rocker Arm - 1992 accord (2.2)
- Brake Bleeding Kit
- no ac which belt
- esttech opinions wanted
- hard braking = shaking
- 1993 Accord Radiator install?
- dip in idle while moving, engine shaking bad
- odd rma
- FYI: for all those with speedometer problems
- 94-95 taillights on 96 accord?
- Found some cheap Accord rims on eBay. (5th gen I believe)
- CODE 12........Help locate please!!!!!!!!!!!!!!!!!
- websites for honda accord??
- 1995 Accord Wagon bodykit question
