big gap on sportlines?
Old Jun 10, 2003 | 05:06 PM
FBP Si 2000's Avatar
Default big gap on sportlines?
So me and my friend just swapped his cheap coils for eibach sportlines....and it's a huge gap? springs are used so they should already be settled? what's going on? we made sure the springs are correct..front to front, rear to rear....wierd? The rear looks good, but the front is lookin' funny...here are some pics...
Thanks for any help since I don't know what's going on here. If it doesn't settle or anything, I guess we can pull the suspension and re-check it to see if anything is wrong.
Old Jun 10, 2003 | 05:12 PM
spankey167's Avatar
Default Re: big gap on sportlines? (FBP Si 2000)
Well Sportlines are suppose to only drop 1.7 front and 1.5 in the back, if ive heard correctly. Looks like a sport spring drop to me...
Old Jun 10, 2003 | 05:16 PM
Default Re: big gap on sportlines? ([167]spankey)
Yeah, I know the drop shouldn't be low...but the front is like way higher than the rear...looks funny.
Old Jun 10, 2003 | 05:21 PM
JonGP4's Avatar
check ur HS post, what is ur tire size?
spankey167's Avatar
thats kinda odd... oh yea... did u guys cut the front and rear bump stops? that could be the reason too... check the bump stops
Old Jun 10, 2003 | 05:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [167 &raquo;</TD></TR><TR><TD CLASS="quote">spankey]thats kinda odd... oh yea... did u guys cut the front and rear bump stops? that could be the reason too... check the bump stops </TD></TR></TABLE>
Yep, they are cut in half.
Old Jun 10, 2003 | 05:27 PM
spankey167's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FBP Si 2000 &raquo;</TD></TR><TR><TD CLASS="quote">
Yep, they are cut in half. </TD></TR></TABLE>
Hmm... drive around for a bit... they should settle... give it a day... if the height doesnt change, i say jack that **** up and see if they sat correctly
Old Jun 10, 2003 | 05:29 PM
Yeah, we'll find out in a few days.
Old Jun 10, 2003 | 05:32 PM
JonGP4's Avatar
the bump stops hardly get touched it has nothing to do with how the car sits. My friend's car is lower and has stock bump stops untouched and his car sits lower then urs. Bump stops are exactly that. They prevent the shock from blowing when u hit a bump they stop the suspension travel.
Old Jun 10, 2003 | 05:33 PM
iam7head's Avatar
the picture looks right.
it's called the boat effect, happen to most of the spring kit
Old Jun 10, 2003 | 05:39 PM
spankey167's Avatar
Default Re: big gap on sportlines? (JonGP4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JonGP4 &raquo;</TD></TR><TR><TD CLASS="quote">the bump stops hardly get touched it has nothing to do with how the car sits. My friend's car is lower and has stock bump stops untouched and his car sits lower then urs. Bump stops are exactly that. They prevent the shock from blowing when u hit a bump they stop the suspension travel.</TD></TR></TABLE>
Wrong bro... it does make a difference... yea you are right about that they prevent the shock from blowing... but if not cut... the springs will sit on the bumpstops... making the ride higher... had first hand experience with my car... when i had progress springs installed the first time... my friend that helped me install them forgot to cut them, then i got shocks and then i found out they werent cut, and had them cut... before the cut my front would fit 2 fingers but after the cut only one finger. Although only a finger... it made a difference in ride quality
Old Jun 10, 2003 | 06:06 PM
iam7head's Avatar
yeah..need to cut the bump stop according to the height of your springs
Old Jun 10, 2003 | 09:26 PM
MVLZ's Avatar
thats as low as it gets...and thats why swapped into H&R race
Old Jun 10, 2003 | 09:59 PM
fastaccord94lx's Avatar
I don't see how the bumpstops would interefere with anything unless the strut piston washer was resting on them? Maybe they might make your car ride crappy if they aren't cut and the strut hits the bumpstop prematurely. I know my car doesn't rest on the bumpstops, I cut them in half, and it's lowered about 3 inches all together. But even if I hadn't I couldn't imagine it resting on the bump stops. Yikes!
I don't want to sound like an ***, but are you sure you put the front springs on the front? ETC? I've seen many sportline drops, it's usually pretty clean, but yah you got a huge fender gap up front. Getting the springs reversed would most likely do that
Old Jun 10, 2003 | 10:02 PM
Default Re: big gap on sportlines? (weneklek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weneklek &raquo;</TD></TR><TR><TD CLASS="quote">thats as low as it gets...and thats why swapped into H&R race</TD></TR></TABLE>
Ahh I just now read this. After I looked at the picture again it started looking more normal to me. The fender gap in the front isn't that much bigger than the back, maybe quarter of an inch. But if you look at stock suspension its the same way, bigger gap up front. I think it looks pretty decent to be honest. Maybe nothing is wrong?
Old Jun 11, 2003 | 05:44 AM
Frankie324's Avatar
something is wrong. if you told me that it was a prokit then yeah that would sound right but not a prokit. have someone else look at it, sometimes someone else can see something that you missed. it happens all the time.
715ek9
Jun 6, 2013 09:52 AM
ishnathan
Jul 3, 2009 07:08 PM
MRolo74
Apr 25, 2009 10:42 PM
BadEH2
Mar 19, 2005 06:10 PM
IntegraLs94Cam
Mar 14, 2004 06:09 PM
