View Full Version : Honda Accord (1990 - 2002)
- Steering jerks side to side....(94 accord)
- 94 Accord Auto Transmission Problem
- Do you have bodyflex (and cracking noises..) on your 6th gen accord?
- K20A head for a K24A4!
- My Fuel gauge isn't reading right?
- Halarious!!!!!
- Kind of poor gas mileage
- lights on console don't light up..what to do?
- Help! 93 accord brake lights wont turn off!!
- the ending topic for boosted h22 accords
- Ripped off?
- Is DEA engine mount a stock mount?
- suspension and wheel size
- 1992 Accord Electrical problem
- f22 question
- 3rd Gen. Accord parts?
- '90 Accord 3rd brake light question
- MAX 5th gen Accord Tire Size
- OEM colors for accord paint??
- removing ignition switch
- i need help with my h22 in my civic hatch
- Clutch sticks...new master cylinder?
- Where to find NX jets online?
- is this an auto or 5spd
- car overheats.
- what does your GReddy sound like
- passenger vent
- 04 Accord Windows Roll Downs by itself?
- Sedan vs Wagon rear bumper question?
- Fuel problem ???? please help
- Problem with AC
- 1999 just stops running for no reason
- car is shaking
- Anyone know how to tell if my speedo is right
- PLEASE HELP
- Good Place For Engine Parts
- Catz HID(passenger side headlight) shuts off after 1 minute - blue tint - help!
- shift knob!!!!
- Interior Light Bulb Replacement
- Accord damage. Need suggestions
- OT: Midwest accord guys
- 9005 to 9006 conversion.. will it melt wire harness and how long will it last?
- Need service manual!
- interior lights don't light up, what fuses to look at?
- Nitrous on F22B1...Advice
- 1990 Accord LX Air pressure in crank case
- tat-ing sound while accelerating
- Headlight bulb question..
- cost of f22a1
- Trigger wire for aftermarket driving lights for my 00 Accord
- strange sound...
- crank sensor code/ car shutting off on left turns
- accord 5 lug conversions
- 96 accord lx advice
- All gauge needles not illuminating at night!?!?!?!
- Question about the MY03+ Accord V6
- help! something funky with my electrical system
- Maintenance records for used car
- Cracked the timing cover, 96 Accord why?
- drivetrain shudder????
- CEL code 45...
- EGR Manifold Cleaning
- new starter...but it makes a scrapping sound??
- Suspension set up on 6th gen
- Sub with factory stereo?
- antenna
- Choosing Calipers
- main relay question
- XEON Headlight bulbs
- H22 Swap: DETAILED instructions on shaving Prelude driver's side mount to fit?
- Importing cars from Japan to U.S.
- 2003 rsx seats in a 94 accord coupe???
- Car won't start after installing a new Radiator!
- does vafc work for accord?
- 88 accord parts
- I need help!!!
- 94 Accord EX Puts Real Hard, What Could Be The Problem?
- sunroof drain holes
- bypass valve?
- Need help with O2 sensor replacement for 98 Accord
- Torque Converter Clutch Circuit Malfunction
- 91 accord lx 4dr problems
- cold air intake help!!!
- JDM headlights (Black) For 94 accord
- dyno day and boost controler would not work
- 2004 Accord V6 6-speed, 13.97 @ 99mph...
- 92-96 prelude short throw shift adapters for a 90 accord?
- 1999 V-6 Coupe: Odometer Lamp went out
- zex bottle hearter not that hot??
- F20B swap
- diet for a '91 EX?
- h22 swap on a 98 accord
- Accord Automatic Transmission---Junkyard Help
- Heater Fan Question,
- Accord F22B2 Turbo How-to
- Oil pump question.
- Where to get CLEAR jdm headlights?
- clutch problem HELP!
- Timing belt replacement list of parts?
- springs
- New book on the shelves everyone here should read...
- Checking heating core on 94 accord
- Windshield washer problem
- WHAT ALL NEEDS TO BE DONE TO SWAP A F22B DOHC OBD1 ENGINE INTO A 97 OBDII Equipped accord
- effects of changing an engine.
- HELP~!!! So many light was ON in the panel when i were driving~!!!!
- H22 Accords and AN-R header.
- '01 LX have factory painted moldings?
- major problem with starting!
- Shaking at idle
- Catalytic Converter
- Rev Limiter
- starting problems and more
- dsdfsd
- Fuel Pump Relay...
- help on lowering car with springs
- Accord 98 V-6 Auto Tranmission Dip Stick Reading, please help
- Wheel Stud Length
- Top half of h23 intake manifold on f22a6
- quick question, f22b2 block, obd2 obd1
- Hybrid Setup Questions
- Accord repair info on DVD & VHS
- opinions needed about improving street performance
- need help on zex bottle heater
- Exhuast
- need help plz
- Lowering my accord
- Wanting to do a suspension upgrade...
- problem with accord plz help!!
- chipping
- O2 Sensor
- price quote
- brake lights help
- 2004 Accord V6 Alignment
- Electric super?
- Need Help with 98 Accord Transmission
- 99 Acura CL spings/shocks on 97 Honda Accord
- Rear wheel bearing question
- Drivers side drive shaft wont lock into place
- 105000 miles
- VeTeck question
- H22 Swap Smog Question....(CA)
- any difference between suspension in 94-97 4cyl vs V6 accord???
- having problem with 97 accord
- are they accord 00+ lemons?
- 94 EX Door Locks
- Vtech Question?
- Sound system for a 95 accord
- Anyone know where to find a 6th gen wagon
- Vibration!!!!
- Sunroof
- idle vibration. Engine mounts?
- Difference in Tails 2Dr and 4dr
- selling the h22 out of my accord
- 2005 Accord stockradio/CD/XM inquiry
- 94 honda accord will not start
- Honda OEM Radio Install?
- 1998 EX V6 Factory Alarm Woes
- 91 Accord burns oil very weird.....
- Interior power outlet, wires though the firewall?
- idle speed
- Cruise control light bulb
- 5th generation accord question
- best way to store the car
- Brake Light
- Looking for stock springs for 98-01 accord v6
- Advise on A/C Compressor Clutch
- Fluctuating Idle
- Wedding Ring fell into the gap where e-brake is.
- Moroso Crank Pulley Tool work with the '96 Accord LX?
- Is installing timing belt hard??
- do i need to jack up the car to install front strut bar?
- Tailight helP
- Should I get a 98-02 4cyl 5spd. accord or a V6cyl automatic ? What is better ?
- what generation is my accord??
- installation on new distributor
- 98 Accord front brakes
- honest to god answers to putting 20" rims on my 2004 accord V6 sedan
- antenna installation
- bad starter?
- whats the bolt pattern for 01 accord 4cyl (for wheels)
- Engine Swap Into 3rd Gen 'Cord
- Quality OEM fit 04 Accord man shift knobs?
- Does anyone have an H22 LSD tranny for sale?
- anyone here decked an accord? clearance question
- Whats engine code HA
- Honda Radio CODE?
- i am in need of some stock sideskirts for my 95 accord sedan(clean aftermarket,or stock)
- is there a nice flush mount rear spoiler for a 1994-95 accord sedan??
- ARE HEADERS ON A V-6 WORTH THE TROUBLE AND PRICE ?
- greddy e-manage on 2000 accord problem
- Looking for *** 89 accord carburator
- 98 accord battery drain
- cam gears and pulleys for 95 accord
- Possible Clutch Problems?
- f22 cam gear adjustment
- 17" wheels for 1995 honda accord ?question? need help bad!!!!!!!
- another 92 question (brakes?)
- 92 accord jdm headlight ?
- starter is turning slower than usual..wats happenin?!!!!!
- drill new speaker holes in door...how do i do that?
- Best way to remove OEM pedal covers
- Car Air filter
- newbie ATX to MTX conversion question
- How do you fill the Automatic Transmission with fuid?
- help!?!
- Speed sensor for auto to man. convertion.
- oil in radiator but not in oil
- latest model year swappable motor?
- Looking for some mirror bras......where to buy?
- newbie with question on speaker installation and starter
- Check Engine Light 70, Transmission Light 47 : What does all this mean?
- Spring Install gone bad plz helpI just did my first DIY spring install....it didnt go very well. The
- Need help/advice...im stuck.
- Clutch pedal vibration...
- Car got stolen, recoveredm need new ignition lock now.
- Code P1382
- fuel management advice
- Brakes not working , please help
- 99 ACCORD faded paint
- tv's in a 94-97
- Full Suspension Installation?
- Quick Question...
- Accord guages
- Headers & Pulleys for '04 Accord
- Lowering springs
- transmission swapps
- 2002 Accord Radio Not working
- Change back over to stock:)
- master cylinder question
- Rear brake pads
- brake pads
- Which Brake Pads?
- 03 Accord Broken Rear Stablizer Link
- ENGINE "SHAKE" WHEN ENGAGING CLUTCH ON 93 ACCORD
- 1995 Accord.. Air cylinders and 18s or 19s.. Question?
- Copper washer(s) on rear brake lines?
- where can i get OEM parts cheaper than the dealer??
- honda accord 93 18 inch rims any Mods?
- Tenzo products
- 7th gen accord problem.
- obd II to obd I conversion question
- 94' Accord Problems
- Weird Squaking/sratching noise
- Maintenance Req'd??... what's this mean??
- 98 - EX 4 cyl Accord brake job.. HELP! Just changed rotors and pads?
- New Member w/ some questions
- wats rpm u guys runnig in a H22a accord?
- How much for a decent paint job?
