B16 into a 91 CRX HF Axle/GSR Trans question
I used the search function and could not find concise answers to my questions.
So here is my dilemma. I am swapping a B16 from my wrecked 89 Civic DX Hatch into my 91 CRX HF. The Y1 trans in the Civic was whooped so I picked up a like new GSR Hydro Trans from the dealer with 12,000 miles on it. The only thing I had to do was swap the speedometer gear from the Y1 into the GSR Trans and get a hydraulic to cable conversion kit from hasport.
The B16 was in a 89 Civic DX Hatch with a Y1 trans, I *think* it had 93 Integra axles and the intermediate shaft has SK7 stamped on it.
Now I want to swap the B16 into my 91 CRX HF using a 94 GSR Trans with a Quaife LSD. I bought the Hasport EFB2 Hydro to Cable Conversion kit, 93 Integra axles. Will this combination work?
So my questions are:
1. Will a 94 GSR Hydro Trans work with 93 Acura Integra axles in a 91 CRX HF?
2. Will the speedometer drive gear in the Y1 swap into the GSR trans?
3. Will the SK7 intermediate shaft work with this combination or do I need a different intermediate shaft?
Any Help would be greatly appreciated.
1 Post
Re: B16 into a 91 CRX HF Axle/GSR Trans question (CRXB16T)
yes everything you posted will work fine , axles, intmed shaft, and speedo gear are fine, you will need to put your dx spindles on or si or da ones to make the axles fit into the hub
Gasoline Fumes
43
07-06-2012 01:07 PM
RACING INTEGRATION
03-03-2006 08:09 PM
crix180
06-29-2003 12:55 PM
hybridrexsir
04-10-2003 02:46 PM
