d series tranny on a b series motor adaptor plate
ive looked and looked does anyone make a adaptor plate to put a b motor on a d tranny i know they make one to put and h series on a b tranny well i have a b18a1 and b trannys are very hard to find and very expesive in my area plus i am cureently running and d series si tranny and i love the gear ratio of it so anyone with some input on a adaptor plate let me know and anyhting i need to go with it
Re: d series tranny on a b series motor adaptor plate (necxoner)
Just a thought. When i am picturing an adapter plate, I am thinking it would space out the tranny away from the block further than stock. Wouldn't that mean you would have to get some sort of aftermarket input shaft made so that it reaches all the way into the clutch disk? Or am i picturing it all wrong?
Re: d series tranny on a b series motor adaptor plate (mattssi)
they aready make these kits for hseries motor to bseries trannys so i figure no u wouldnt need to get a tranyy built
Re: d series tranny on a b series motor adaptor plate (CRXhf_89)
No.
Because the D-series flywheel will not mate to the B-series crank. D-series use a 6 bolt pattern, B-series an 8. The B-series flywheel will not fit inside the D-series casing without some exstensive work.
SHG_Claudio
12-28-2007 07:19 PM
dc5mikeydc5
18
09-26-2005 11:34 AM
Maddox
216
05-14-2004 05:07 AM
ShortbusEK
04-23-2002 03:21 PM
