93 accord w/ h22 timing belt change
anyone else have problems with the lower timing belt cover, is there any way to get it back in there without removing the driver axle or the radius rod???
Re: (v4lu3s)
seriously there is no way to get it in there without scrapping and tearing the crap out of the plastic unless i remove the radius rod or axle which i really dont want to do, i am planning on just cutting it in half below the two upper bolts, so i basically will have a middle cover, upper lower cover, and lower lower cover, and then just running a bead of hondabond horizontally across where i cut in in half, anyone see anything negative about that before i do it...???
are you trying to do the timing belt with the car on its wheels on the ground?
i have done that timing belt job many times, with the wheel off, that corner of the car off the ground, and a jack under the engine to raise and lower it. i havent yet had to damage or cut up the lower timing cover.
michaellong
08-20-2018 04:05 PM
my00SI
05-18-2009 11:54 AM
