plx install having cel prob
Old Sep 1, 2005 | 03:57 PM
5thGenFanatic's Avatar
Default plx install having cel prob
hi i just installed the plx air/fuel monitor... the 300... iin my 4 door civic with b swap... ran power and ground, installed the sensor and wired the narrowband gray wire to d14... my check engine light keeps coming on does anyone know the color wire of d14 so i can make sure i got the right one..or has anyone had this happen before?
Old Sep 3, 2005 | 08:29 AM
85mm LS VTEC's Avatar
Default Re: plx install having cel prob (jdmspecb18)
Did you wire up some resistors to act like a heater wire for the ecu?
Old Sep 4, 2005 | 08:06 AM
Default Re: plx install having cel prob (85mm LS VTEC)
its cool now i just reconnected the stock o2 to the stock connector and ziptied it to the firewall...works fine now...thanks
5thGenFanatic
Nov 18, 2005 09:32 PM
5thGenFanatic
Sep 2, 2005 06:14 AM
5thGenFanatic
Sep 1, 2005 07:19 PM
5thGenFanatic
Sep 1, 2005 04:24 PM
Aaron M
Jun 7, 2005 06:24 PM
