b16 swap auto to manual conversion transmission mount
i have a b16 outa a del sol vtec i need a place racing or hassport transmission mount correct? because its definatly not sitting correctly
Re: b16 swap auto to manual conversion transmission mount (cstay)
Depending on what car you have. Im assuming its a 92-95 civic. The steel frame mount on the tranny side must be cut out and a 5 speed metal bracket must be welded in. Ek is a simple change of trans brackets that mount on the trannies.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cstay »</TD></TR><TR><TD CLASS="quote">can i cut off the and reuse the stock piec rewelded in? </TD></TR></TABLE>
No the stock metal bracket sits about 1 inch two high thus the reason your motor is crooked. Notice the bolt holes sit point up in direction. The 5 speed bracket is ALMOST 90 DEGREES TO THE FRAME. I hate to tell you but you must drop the trans,cut the mount off and weld in the new factory bracket.
Re: b16 swap auto to manual conversion transmission mount (IMALLSLO)
i have no problem doing that as i can weld and fabricate well but i was wondering if somone like hassport made a mount so i didnt need to
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cstay »</TD></TR><TR><TD CLASS="quote">http://hasport.com/catalog/pro...5fb19
what about that"?</TD></TR></TABLE>
Should work considering the chasis are the same. Call and double check before ordering. Id say its a go though.
aneybody know if that is what i need for sure? or should i just reweld the old one in a new spot
Ive done about 20 auto to manual swaps. I know the old one will not work because
1:when you cut it off it is pretty haggard
2:there is no way to position the old haggard mount to line up for a proper fit. Your options are buy the Hasport mount or a factory weld on bracket.
Makdaddynuge
06-24-2005 10:15 AM
spooncivicsi
Welding / Fabrication
05-06-2005 06:28 AM
