Question hasport mounts Ek
i bought a hasport Ek mount but didnt come with the drivers side bracket . i called hasport they dont sell the bracket alone . Do youll know if i can just buy an integra bracket instead and use the mount on it ? heres a pic
Re: Question hasport mounts Ek (purpleEJ6)
The mount off a teg doesn't come off your probaly need to get a new driver side motor mount from hasport... Hope that helps
The Hasport EKLH mount kit uses a 99-2000 Civic Si Left Hand Engine Bracket. Hasport sells this, their part # is EKLHB. Just call Rob or Joe and ask for the EK Left hand engine bracket. They will be more than happy to sell it to you. The GSR left hand motor bracket will not work with that mount.
It will definetly fit any 96-00 Civic, if you have everything in the picture above and the EKLHB on your B-Series motor.
Actually, I must have misunderstood you, that bracket is available separately for $75, call Hasport and ask for Joe..
Thanks..
Thanks..
Re: Question hasport mounts Ek (BoostedJeff)
thanks guys i called hasport they said $65 for the bracket . weird cause i called the day before and they said they didnt sell it alone
trooper0641
10-12-2009 02:54 PM
BokudenNYC
04-28-2009 09:02 AM
