B16a2 swap into eg4 (5th gen) 1st time swapper.......
Hi,
whilst i'm sure someone will post that i should have done my research, i have done some and am a little overwhelmed. I intend to swap a B16a2 from a 94 vti into my Eg4 hatch. (i had wanted to boost the original lump but the crankshaft is shot to pieces! ce la).
After researching as best I can, here's the list of parts i think i requre (please correct me if i'm wrong) :
OBD1 ECU + harness (for a b16a2)
Engine and transmission mounts.
Transmission
Driveshafts / axles
Here's where i need assistance.
the Ecu is going to be replaced with a fully mappable unit so no worries there, any recomendations?
What engine and transmission mounts do i need to replace? and with which? (anyone know of a fulll kit?)
Will any B series transmission mount straight up? or are there only specific ones that will fit?
What driveshafts/axles to use? is this the same as the tranny where (i assume) any b series will fit? or do i need a specific set?
Like i said, i have tried to do my research but cant find any direct answers.
thanks,
AH
Transmission
Driveshafts / axles
thanks,
AH
Re: B16a2 swap into eg4 (5th gen) 1st time swapper....... (ShogunHutch)
as for the mounts, i will plug for hasport again. go to http://www.hasport.com they make the best swap mounts on the planet.
