confused on rear mount setup for LS swap into EG hatch
at the jetties fishin'
for the rear mount portion of an LS swap do I only need the T-bracket or only the subframe rubber mount??
or do I need both portions of it?
Re: confused on rear mount setup for LS swap into EG hatch (stackz)
You will only need the T-Bracket of a 94-01 Integra 5-speed you can use the exist. mount thats connected to the rear subframe
Re: confused on rear mount setup for LS swap into EG hatch (DarkSol97)
ok, that clears it up then. I was about to buy both the t-bracket and the rubber mount. that would have irritated me, thanks man
