need help with swap
Old Oct 27, 2006 | 02:46 PM
motrayEG6's Avatar
Default need help with swap
i have a b20 block i need to know if i have everything i need to swap i have a 92 civic hatch CX
here are the parts i have:
gsr head
obd 2 p72 ecu
00 si distributor
shift linkage for a ls tranny i am looking for a ls tranny still
94-97 integ motor mounts
gsr intake manifold
do i need waterpumps or different altenator or axels what ever let me know and i also know about the page with all the swap questions and **** but i would love to have someone that has done this or knows what i need to get my motor swapped thanks
Old Oct 27, 2006 | 03:53 PM
slamedcivic's Avatar
Default Re: need help with swap (motrayEG6)
ls axles will work
and inter. shaft
Old Oct 28, 2006 | 07:33 AM
motrayEG6's Avatar
is that it though someone let me know
Old Oct 28, 2006 | 07:48 AM
f20bej1's Avatar
first the car is obd1 the ecu and distributer is obd2 it would be better to go all obd 1 with a p28 ecu on what year your car is there is wiring digrams on ff-squad.com to convert to all obd1. what you need is obd1 ecu this is quite complicated go on ff squad its has lot answers for you
Old Oct 28, 2006 | 08:30 AM
motrayEG6's Avatar
everyone i talked to about my ecu said it did not matter i could go with either obd 1 or 2
Old Oct 28, 2006 | 09:39 AM
f20bej1's Avatar
yes you could make it work but a lot of work. your car is oringnally obd1 so it would be easier to do with obd1 but yes jumper harness and few other things it will work but obd2 has 2 o2 sensors and lot extra things .make it easier and quick with obd1 also check if hondata like working with obd2 ecu's i could be wrong but when getting advice with tuner in dallas they say p28 is the best to work with
Old Oct 29, 2006 | 09:41 AM
motrayEG6's Avatar
pm'd u
heeltoehonda
Nov 23, 2009 06:32 AM
heeltoehonda
Engine Management and Tuning
Nov 19, 2009 11:41 AM
Frankenstein
Sep 10, 2003 05:35 PM
GDM Z28
Apr 4, 2003 11:02 AM
