B20vtec CODE 10(IAT)
Old Nov 5, 2006 | 04:16 PM
SpoonEk253's Avatar
Default B20vtec CODE 10(IAT)
This is the only code i cant get rid of....i've replaced the old sensor because it was like burnt. now i just installed a new IAT, but the code still shows up...i've even reset my ecu no luck....any idea's? If this helps im using a 98ex harness w/ a gsr head and jdm p30 ecu. (OTHER POSSIBLITIES OF THAT I HAVENT DONE TO GET RID OF THIS CODE?) THANKS IN ADVANCE
Old Nov 6, 2006 | 06:58 PM
SpoonEk253's Avatar
Default Re: B20vtec CODE 10(IAT) (SpoonEk253)
anyone?
Old Nov 7, 2006 | 08:32 PM
:Andrew's Avatar
check to make sure the sensor is getting voltage.
Old Nov 8, 2006 | 07:17 PM
punkracer's Avatar
drive it for a bit it might have to see the sensor corect after a few drive cycles,
Old Nov 8, 2006 | 07:32 PM
igotthaspirit's Avatar
Default Re: (punkracer)
do a continuity test from the ecu pinout for the IAT and Ground to the actual sensor harness plug. You may have a open somewhere in one of the wires.
Old Nov 8, 2006 | 08:12 PM
SpoonEk253's Avatar
Default Re: (igotthaspirit)
i'll do all the above and keep you guys posted thanks!
lscrxhf
Jul 4, 2006 08:08 AM
SpoolnByYou
15
Mar 26, 2006 08:43 AM
USDM 4G VTEC
11
Jul 15, 2003 11:05 AM
.brad
Feb 26, 2002 03:30 AM
