99-00 Civic With B18B OBD2B Integra ECU - Immobilzer?
Former Moderator
<FONT SIZE="7">I Posted This in The Hybrid Forum for a Reason - It's a HYBRID Question!!!</FONT>
I don't know why this was moved to All-motor!!!
My friend has a 2000 civic DX and will soon be dropping a B18B engine in it and due to GA emissions he is keeping it OBD2, which means he will be trying to locate an OBD2B ECU to plug into his car. My question:
Will an OBD2B Integra P75 non-VTEC ECU require the immobilizer bullshit?
Also since the immobilizer uses that special key I'm sure he'd need to buy one and have it cut to his ignition, but will the immobilizer system even work in his 2000 Civic DX hatch?
I can't believe I've never encountered this problem/question before.
Secondly is there an alternative besides getting an OBD2A and a jumper harness, or are all OBD2B Integras equipped with immobilizer *****?
Thanks in advance.
Modified by B18C5-EH2 at 8:51 AM 10/18/2006
Thanks in advance.
Re: 99-00 Civic With B18B OBD2B Integra ECU - Immobilzer? (B18C5-EH2)
no, 2001 is the first year i think they started the imob. i think all you will need is a cat. and a stock ecu, hope that helps
Re: 99-00 Civic With B18B OBD2B Integra ECU - Immobilzer? (siblueg)
actually, its 00-01 Integras that have the IMMobilizer in them. 96-99 didnt have it
<------ref'd a 99 EX with a 99 LS motor
Former Moderator
Re: 99-00 Civic With B18B OBD2B Integra ECU - Immobilzer? (Superdragr45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Superdragr45 »</TD></TR><TR><TD CLASS="quote">actually, its 00-01 Integras that have the IMMobilizer in them. 96-99 didnt have it
<------ref'd a 99 EX with a 99 LS motor</TD></TR></TABLE>
Okay having said that was the 99 Integra ECU that you used an OBD2 A or B plug type then?
I have been told on a few occasions that the 99 Integra still carried the older OBD2A plug type unlike it's Civic counterparts that went to OBD2B plugs in 1999.
What's the deal?
What's the deal?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">
What's the deal?</TD></TR></TABLE>
He would have had to got a jumper harness.
You can try the civic ECU, I have never tried it to pass emissions, it may work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">I have been told on a few occasions that the 99 Integra still carried the older OBD2A plug type unlike it's Civic counterparts that went to OBD2B plugs in 1999.</TD></TR></TABLE>
You were told right.
Re: 99-00 Civic With B18B OBD2B Integra ECU - Immobilzer? (EE_Chris)
http://www.doctronic.at/eng/pr...g.htm
IF you want to use the LS ECU without a jumper harness
Order form: http://www.doctronic.at/eng/menu_eng.htm#
