best frankenstein engine
Old Oct 29, 2006 | 09:49 PM
ekblack9's Avatar
Default best frankenstein engine
i was wondering what the best combo engine would be, cause im planning to make a b20 and putting the ctr head on it what do you guys think
Old Oct 29, 2006 | 10:07 PM
hondalover91crx's Avatar
Default Re: best frankenstein engine (ekblack9)
what about a stroked b20 with ctr head ? 2.4liter with ported head would be pretty nasty
i know b20 with ported non ctr head and ITB's makes 246 whp, seen it in a DA drove it too....madd ***** and really snappy response
Modified by hondalover91crx at 7:49 PM 10/30/2006
Old Oct 29, 2006 | 11:44 PM
fmrprojects's Avatar
Default Re: best frankenstein engine (hondalover91crx)
there are so many differnet engines that you can swap. just search around.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondalover91crx &raquo;</TD></TR><TR><TD CLASS="quote">what about a stroked b20 with btr head ? 2.4liter with ported head would be pretty nasty
i know b20 with ported non ctr head and ITB's makes 246 whp, seen it in a DA drove it too....madd ***** and really snappy response</TD></TR></TABLE>
what the hell is a non ported ctr head
Old Oct 29, 2006 | 11:54 PM
HonDelso's Avatar
my guess would be a B16a head &gt;.&lt;
Old Oct 30, 2006 | 12:34 AM
spork motorsports's Avatar
* B A N N E D *
Default Re: (HonDelso)
best frankeinstein motor, k24 bottom end, k20a head
for your block? b16a or type-r head
Old Oct 30, 2006 | 01:36 AM
pythoner's Avatar
K24+K20a2 head &gt;*
Old Oct 30, 2006 | 01:47 AM
* B A N N E D *
Default Re: (pythoner)
k20a as in jdm dc5 type-arrr
Old Oct 30, 2006 | 05:01 AM
tEKnics's Avatar
Default Re: (spork motorsports)
I have a b16 head with a bad valve (which im fixing). I was thinking of using it a frankenstein swap. My question is whats a better bottom end to use... B18B or B20? Pros and Cons of each?
Sorry if Im jacking the thread
Old Oct 30, 2006 | 05:27 AM
Syndacate's Avatar
Default Re: (tEKnics)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tEKnics &raquo;</TD></TR><TR><TD CLASS="quote">I have a b16 head with a bad valve (which im fixing). I was thinking of using it a frankenstein swap. My question is whats a better bottom end to use... B18B or B20? Pros and Cons of each?
Sorry if Im jacking the thread</TD></TR></TABLE>
Same ******* block except the B20's bored more (1/5 of liter more)
Old Oct 30, 2006 | 09:02 AM
* B A N N E D *
Default Re: (Syndacate)
its also stroked a bit and correct me if im wrong but i think a b20 is closed deck, and the 18b is open????
Old Oct 30, 2006 | 09:30 AM
lodo's Avatar
b18 and b20 blocks are the same besides the bore. thats the only dif. you use the same rods for either engine.
Old Oct 30, 2006 | 10:09 AM
* B A N N E D *
Default Re: (lodo)
my bad
Old Oct 30, 2006 | 10:14 AM
Max Kling's Avatar
And since they are bored a little bit more there is a little less sleeve strenght.
I dislike B20's alot, because people are CRAZY about them when a B18 is way more stable, easier to find, and cheaper.
Old Oct 30, 2006 | 06:47 PM
Default Re: best frankenstein engine (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">what the hell is a non ported ctr head</TD></TR></TABLE>
ported (pause) NON ctr head, meaning the kid had a non ctr head ported by a private company, the ctr heads are ported by honda, thus in the end meaning, i dont know if ctr head would have created more power, but this is what he got when a private company did it. hope that clears it up
Old Oct 31, 2006 | 04:53 AM
manekDC2.'s Avatar
Default Re: (lodo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lodo &raquo;</TD></TR><TR><TD CLASS="quote">b18 and b20 blocks are the same besides the bore. thats the only dif. you use the same rods for either engine.</TD></TR></TABLE>
just to add**
the b20 sleeves are combined together.. other then the sleeves being diff. there similar blocks.
ekblack9
Oct 31, 2006 04:15 PM
ekblack9
18
Oct 26, 2006 08:26 PM
xEnderx
Jul 28, 2005 07:41 AM
Boosteddc2gsr
Jul 14, 2003 07:06 AM
2fastGSR
25
Apr 2, 2002 03:02 PM
