Another Noob OBD Conversion Question
Old Oct 25, 2006 | 12:10 PM
SlowSOHC-T's Avatar
Default Another Noob OBD Conversion Question
Ok first off I've searched my a$$ off trying to find some direct info on this, but have come up empty handed. Im about to do a OBD1 GSR Swap into my OBD2 ek hatch. My question is what all is included in the OBD conversion besides the harness? I have the entire swap, since I bought a wrecked 95 Integra GSR (in the rear)....Please help me so the winter project can begin.
Old Oct 25, 2006 | 03:35 PM
SlowSOHC-T's Avatar
Nobody?
Old Oct 25, 2006 | 04:38 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: Another Noob OBD Conversion Question (IWANTAHB)
just use your harness in the civic and make or buy a subharness to connect all the sensors from the GSR that are needed (VTEC solenoid, VTEC pressure switch, Knock sensor, IAB, convert your 3 wire IACV to two wire). You'll also need to swap over the plugs from the GSR injectors to your harness and do the same with the distributor plugs to be able to use the GSR's injectors and distributor
Old Oct 26, 2006 | 05:09 AM
SlowSOHC-T's Avatar
Default Re: Another Noob OBD Conversion Question (HondaPartsHero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaPartsHero &raquo;</TD></TR><TR><TD CLASS="quote">just use your harness in the civic and make or buy a subharness to connect all the sensors from the GSR that are needed (VTEC solenoid, VTEC pressure switch, Knock sensor, IAB, convert your 3 wire IACV to two wire). You'll also need to swap over the plugs from the GSR injectors to your harness and do the same with the distributor plugs to be able to use the GSR's injectors and distributor</TD></TR></TABLE>
OK so basically just buy a subharness (from you (lol) for all the vtec stuff, and than just swap over the injector clips to the civic harness, as well as the distributor plug. Correct? Than do i run a OBD2 to OBD1 jumper harness to the ECU and use the GSR ECU? If so than i just buy a conversion harness for a 96-98 (mines a 97)..CORRECT? Or did I miss something?
Old Oct 26, 2006 | 04:36 PM
SlowSOHC-T's Avatar
TTT
Old Oct 26, 2006 | 05:51 PM
Technical Hero
Yes use the GSR ECU. Use an OBD2 to OBD1 ECU adaptor. You'll have to swap over plugs on the alternator too as they are different between OBD1 and 2.
sumoneEK
24
Jul 30, 2010 05:09 AM
ej6tjs
Jun 21, 2010 06:05 PM
DA9_GSR
Nov 24, 2007 08:36 PM
integrag
Sep 10, 2007 06:06 AM
4GE4YA
Aug 9, 2007 11:17 AM
