b16 swap problems
Old Oct 24, 2006 | 07:03 AM
onefastx's Avatar
Default b16 swap problems
i got a 93 del sol 1.5 im doing a jdm b16 swap the map sensor on the del sol is on the intake manifold its supposed to be on the firewall on the b16 and some of the harnesses are not matching up has anyone ran into any of these problems before please help
Old Oct 24, 2006 | 02:26 PM
JasonST's Avatar
Default Re: b16 swap problems (onefastx)
Just plug some vacuum hoses on it and attach it to the correct plugs on the throttle body, should be pretty simple.
Old Oct 25, 2006 | 04:09 AM
onefastx's Avatar
Default Re: b16 swap problems (JasonST)
figured it out the guy who is doing it owns a shop but he never did a swap before only factory stuff basicly he needed to extend the map sensor wires because the factory 1.5 they run through the main engine harness and the car that the b series came from had a seperate harness ran for the map sensor quick fix but one more thing if i dont wire up the knock sensor and run 93 octane is it gonna kill my motor or will i be safe
sol of a honda
Sep 29, 2009 10:22 AM
Metalluthier
13
Oct 28, 2006 09:26 AM
onefastx
Oct 25, 2006 04:11 AM
Brian Hinson
13
Jun 24, 2006 04:05 PM
hatchdrvr
Feb 19, 2003 01:36 PM
