VTEC quit on dyno?
Old Nov 2, 2006 | 10:42 AM
calhoun's Avatar
Default VTEC quit on dyno?
was having the car tuned and vtec was coming on and off. now it wont come back at all. checked oil level is fine, wiring seems to be fine, and the vtec sensor is working when hooked up manually.
what could be causing the drop in pressure? oil pump is my guess but thought i would ask if anyone else has had similar experience.
new motor has less then 1000 miles
thanks, calhoun
Old Nov 2, 2006 | 11:34 AM
JasonST's Avatar
Default Re: VTEC quit on dyno? (calhoun)
Any cel's? Any other problems other than vtec not workin?
Old Nov 2, 2006 | 12:01 PM
locash's Avatar
Let me guess, LS/VTEC with the oil feed coming from the oil pressure idiot light port on the back of the block?
Old Nov 2, 2006 | 12:29 PM
calhoun's Avatar
no built gsr and currently no other codes being thrwn.
Old Nov 2, 2006 | 02:39 PM
JasonST's Avatar
Default Re: (calhoun)
No other codes? U haven't said that there's any codes, are u saying the vtec pressure switch code? Also what year of engine and ecu are u running?
Old Nov 2, 2006 | 05:49 PM
v4lu3s's Avatar
RTFM
you checked oil pressure to the head yet?
94wip
12
Jun 20, 2024 07:23 PM
HONDRETTI
11
Jan 26, 2009 02:40 PM
bigmacks
Aug 11, 2005 12:48 PM
mister2racer
Jun 26, 2005 07:13 PM
theEGkid
Apr 20, 2005 07:56 AM
