Throttle cable
Old Oct 16, 2006 | 12:24 PM
Spoolind16's Avatar
Default B Series Swap Into an EG What will I need?
I'm going to be putting a 92 integra ls motor (b18a1 OBDI) into my 95 EG civic.
1.Will I need the integra throttle cable or can I use the EG cable?
2. Can I use stock civic mounts with a 94+ integra rear bracket? (I've heard this can be done but some ppl say the motor wont sit right).
Thanks
Alex Z
Modified by Spoolind16 at 2:08 PM 10/16/2006
Modified by Spoolind16 at 2:09 PM 10/16/2006
Old Oct 16, 2006 | 12:27 PM
2fast4u831's Avatar
I'm really 2slow
Default Re: Throttle cable (Spoolind16)
integra cable
Old Oct 16, 2006 | 12:36 PM
Spoolind16's Avatar
Will any b series cable work? And while I'm at it what else will I need to make this swap work?
Old Oct 16, 2006 | 01:14 PM
2fast4u831's Avatar
I'm really 2slow
shift linkage from a 94+ integra, axles, 94+integra rear bracket, tranny mount is the same if 5 speed, you can use your civic rear mount, motor mount driver side might be the same..? ecu of course, integra header, I might be missing some things.
AJxr
Nov 20, 2006 10:53 AM
import_racer_ky
Apr 10, 2004 01:26 AM
g_man80
Jan 31, 2003 08:29 PM
Dancing is Forbidden
Jan 29, 2003 03:53 AM
DOHCTOR
Jul 31, 2001 08:54 AM
