transmissions
Old Oct 18, 2006 | 08:34 PM
o0Jash0o's Avatar
Default transmissions
what will happen if i put a tranny from a vtech engine on a non vtech?
also do clutches, swap between series just like the trannys
onyly asking cuz i might need to replace mine soon and will go with whats most available at the moment
Modified by o0Jash0o at 1:20 AM 10/19/2006
Old Oct 18, 2006 | 10:47 PM
boost'd_crx's Avatar
Default Re: transmissions (o0Jash0o)
vtec and non-vtec trannys will fit no with problem, same casing different gearing. all hydro trannys for the b series use the same size clutch.
Old Oct 19, 2006 | 10:11 PM
o0Jash0o's Avatar
Default Re: transmissions (boost'd_crx)
what would be the ideal tranny for a sohc if looking to make it quiker and have more midrange than top end
and how do i identify the tranny i currently have if different from the original from that engine
Modified by o0Jash0o at 2:22 AM 10/21/2006
Old Oct 22, 2006 | 10:59 AM
Bense's Avatar
ex tranny is ideal for everything except gas mileage.
if you make so much power that you can't put traction down in 4th gear then it's a different story.
any 92-00 d-series trans will work on any 92-00 d-series engine.
ideal is an ex trans, if not any of them will work.
Old Oct 22, 2006 | 01:13 PM
o0Jash0o's Avatar
Default Re: transmissions (Bense)
ex tranny will work on the d15b7 then?
Old Oct 27, 2006 | 12:42 AM
Bense's Avatar
yes
Old Oct 27, 2006 | 08:49 AM
Timberland237's Avatar
i have some d series parts, i even have an ex tranny in really good shape. pm if interested or email me
Old Oct 28, 2006 | 11:28 AM
o0Jash0o's Avatar
sk8board{Pete}
Jul 30, 2008 09:39 PM
92EGK20
Nov 12, 2007 07:49 AM
93sihatchy
May 18, 2007 03:47 PM
Burke
Apr 24, 2004 02:46 AM
JDMlyfestyle
18
Jun 17, 2003 10:21 PM
