ecu & wire harness???
Old Nov 13, 2006 | 05:38 PM
gsr336's Avatar
Default ecu & wire harness???
i have a b18c1 97 obdII swapping it into a 96 hatch dx is the wire harness from the integra the same? vtec and non???? and what ecu is best to use?
Old Nov 13, 2006 | 05:45 PM
Pnoyej6's Avatar
* B A N N E D *
Default Re: ecu & wire harness??? (gsr336)
i have 97 b18c1 in my 96 ek cx hatch and im running the obd 1 p72 ecu and it pulls hard. Just use the dx harness and
Old Nov 13, 2006 | 05:51 PM
gsr336's Avatar
and...??? would it be any check engine light if i use the obd1?
Old Nov 13, 2006 | 06:05 PM
lightcrx's Avatar
and.... extend the wires duh
if you go obd1 you need a jumper harness, as long as all the sensors are hooked up it wont throw a code
Old Nov 13, 2006 | 09:02 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: (lightcrx)
just use the DX harness and add VTEC solenoid, VTEC pressure switch, Knock sensor, IAB, and IACV conversion from 3 wire to two, let me know if you need any help
Old Nov 14, 2006 | 04:34 AM
gsr336's Avatar
GreddyCivic7
Feb 10, 2007 03:35 PM
Slava.
Mar 23, 2006 03:07 PM
LiL JoN
Mar 4, 2005 08:39 PM
turbo sol
Dec 9, 2004 04:19 PM
91civicmoneypit
Dec 3, 2003 02:17 AM
