EGR wiring Harness
Old 10-16-2006, 04:17 PM
turtleman321's Avatar
Default EGR wiring Harness
Ok guys i just bought an h22a4 swapped ek hatch. the car is from maryland so im not sure on hoe the emissions and inspection work over there. I live in pennsylvania. my problem is i dont think i will pass PA emissions. my car is scheldules for next tuesday. the car is running a p72 ecu. im guessing its chipped because there is no plug connected to the EGR valve and im not throwing any codes.
so if anyone can help me find where the wiring plug is so i can atleast plug it in to try and pass visual inspection on my car.
i will get a picture in a minute
Old 10-16-2006, 04:28 PM
Default Re: EGR wiring Harness (turtleman321)
Old 10-16-2006, 06:14 PM
ttt
Old 10-16-2006, 08:00 PM
Braco11's Avatar
Default Re: (turtleman321)
unless they used the h22 wiring harness (doubtful), the plug won't be on the wiring harness since ek's didn't have egr
Old 10-17-2006, 03:18 AM
so do you think i should just get a block off plate for it? im not throwing codes and it drives fine without it hooked up
Old 10-17-2006, 07:56 AM
Braco11's Avatar
probably not throwing a code cuz the ecu isn't looking for it. if you're concerned about passing smog, i'd get a pretest done first to see what your numbers look like then block it off if you're passing.
GrimLude
05-13-2014 11:24 AM
B_Swapped93
03-07-2014 04:54 PM
MidnightWarrior
02-11-2014 11:37 PM
goliathishere
03-13-2011 02:33 PM
Project_SOHC_EX
07-04-2006 04:57 PM
Quick Reply: EGR wiring Harness
