Cable Clutch Pedal swap into a EG?
Anyone know if the clutch pedal assembly from a DA bolt into a EG? Im doing a B17 swap into a EG and I would like to simplify everything and just conver the hydro system over to cable.
Re: Cable Clutch Pedal swap into a EG? (GReatEDDY)
Hey, I wouldn't do that its a lot of work man. Best bet is to get yourself a Cable to Hydraulic mount kit. What the titles you to do is that you'll be able to use your existing hydro pedals with a cabel tranny. Hope this will save you some troubles.
we sell just the tranny mount kit. It includes the tranny mount that you need and all necessary hardware.
I already have the mount. I found one used on Ebay. I would need the rest of hardware. The gentleman I bought the mount from sold the hardware seperately.
What would be the advantage of buying a hydro tranny? The cost doesnt seem worth it. The ys1 tranny I have has an incredible gear ratio. Besides the odd mount and the cable conversion the swap seems like a ton of performance for the money. Drop in a diff and run the hell out it it.
Re: (GReatEDDY)
the DA will not fit, 88-91 civics/crxs & 90-93 integras have three pedal set-up, unlike the anything with a hydo tranny that has a seperate clutch pedal and a brake&gas pedal set-up. So no you can't use a DA and it would be easier to use a hydo tranny or the conversion which i think costs almost as much as a hydo tranny.
vtec25
17
10-03-2006 06:57 PM
inline4
09-05-2005 06:39 PM
