JDM confusion
JDM confusion
Aight, here's the deal - friend's dropping a 95 JDM B18C1 into a 98 CX hatch. He's using a P72 USDM ECU, and an OBDII to OBDI conversion harness. Now, everything I've read says that the easiest thing to do, and some people say what he has to do, is use a 96-98 EX harness. Since the engine is OBDI, however, and the ECU will be running in OBDI with the converter, wouldn't it be easier to just use an OBDI harness, or a JDM harness, and lengthen the wires to adapt for left hand drive? It just doesn't make any sense to me why if both ends are OBDI, why the middle should be OBDII. If I'm right, which harness would be the easiest to use? Also, will his distributor, injectors, and plugs work with the 96-98 harness, or an OBDI harness, JDM harness? Thanks.
Re: JDM confusion (cmk804)
ok this is why....
You can't use a OBD1 engine harness in a 96+ civic, because it's a 2 piece harness design. All 96+ civics use a 1 piece harness, and what I mean by '1 piece harness' is that the whole engine harness goes all the way down to the ecu, unlike a 2 piece harness where it breaks off at the main harness connectors on the passengerside shock pillar, seen here:
..also, you don't wanna use a JDM harness. It's made for a RHD car (duh) and the battery terminals are on the wrong side along w/a couple other important plugs.
hope this helps you understand.
Global Moderator
JDM B18C1
All 1.8L DOHC VTEC JDM motors are stamped "B18C", be it GSR or ITR.
Reid, who hates to think that some thieves out there probably are selling "JDM" B18C5's...
Re: JDM confusion (VTECivic2K)
What about the injectors and distributor? Do they need to be changed to OBDII?
jaelynrei
13
09-15-2014 10:53 AM
