B18B/B18A alternator question
Will a 1998 B18B ALTERNATOR bolt up to a B18A?
My friend is currently building a 98 hatch but he is having trouble with the alternator. he has a B18A from his old integra and a DRAG3 kit on it. he is using the 98 Civic harness and the alternator plug has 4 wires. the B18A alt has 3 wires with a totally different looking plug.
TIA
TIA
Re: B18B/B18A alternator question (B_Cruz)
I'm pretty sure there are two grounds and you can get rid of one I forget which one I had the same problem when I swapped my b18b into my 96 civic ex. hope this gives ya some more info to help ya out
Re: B18B/B18A alternator question (OneSunkCivic)
i think a b18a from a 92-93 integra (OBD-1)will have the same alternator as a b18b
[Modified by erniecars, 7:41 PM 5/7/2002]
Re: B18B/B18A alternator question (erniecars)
car: 1998 DX hatch
motor: B18A
engine harness(motor to shock tower): 1998 Civic harness
so my friend can bolt up a OBD2 B18B alternater to the motor? i told him to use the 98 B18B alternater so the wiring plugs would match up. then i told him to use a OBD2-OBD1 jumper harness so he can use a OBD1 LS ecu. am I giving the right advice?
motor: B18A
AdrenalineAngel
Engine Management and Tuning
10-17-2012 11:43 PM
asocallocal
03-07-2008 09:23 PM
boosted96coupe
03-10-2007 11:21 AM
