What axels in a b16 a rex
i went and got axels i could have sworn they were 90-93 integra axels with out ABS but when i got it home it was like 1/4 inch to long. im i supposed to use del sol axels or what? thanks guys
Re: What axels in a b16 a rex (EVOCELICA)
they will work if your using the 90-93 intermedieate shaft. If you have the SIR intermedieate shaft, then you will need to build some sir axles. Read the real info on axles on haspoorts site
http://www.hasport.com
hth,
Monty
http://www.norcalcrx.org
hth,
Monty
Re: What axels in a b16 a rex (Monty)
so if your swap comes with the intermediate shaft from and SIR and you get the Axles from an SIR then you don't have to build any..
Re: What axels in a b16 a rex (puffinrice)
Make you own set of CRX SiR axles like they came with in Japan-
90-93 Integra Intermediate shaft
90-93 Integra Inner joints (correct one for each side)
86-89 Integra middle shafts and outer joints (they are the same on either side)
Perfect factory fit.
Every time.
Ben
Every time.
Ben
philkehn
18
05-28-2007 08:24 AM
ricodemus
12-04-2002 06:28 AM
