Which Pistons/Rods fit this hybrid?
b18b1 block and b16 head, both with stock components. ITR pistons will fit right in no problem right? can I get ITR or CTR pistons on eagle rods made for the stock b18b1 crank? thanks
Re: Which Pistons/Rods fit this hybrid? (Jubba)
Any B16/17/18 piston will fit, but you need to buy rods to match your B18B crank/block. just remember, the B16 head will yield a higher static c/r on whatever piston is in there than the LS head would.
I don't think so, because I tried the same thing and the shop told me that the eagle rods would only accept pistons with a "floating pin" type. See the vtec pistons are pressed on type pistons, the only way that you could use ITR pistons is if you used the stock rods.
Re: Which Pistons/Rods fit this hybrid? (Teg15)
but stock what rods? vtec rods won't fit the crank will they? and if they do, then will the itr pistons fit on the rods i have now? tell me what i actually can do
The ITR pistons fit stock b18a/b rods, but will require little modification. As far as for the eagle rods you could buy some aftermarket pistons, like SRP, JE or the like that use a "floating pin". I personally have Eagle rods with SRP pistons.
New User
I would go with JDM ITR's and crower rods.
Oh and yes you can use Vtec rods on a non Vtec crank ie B18a
[Modified by EVOCELICA, 9:30 PM 5/6/2002]
paulzy
09-20-2001 09:12 AM
