6th generation civic swap ????
i have a 97 ek and have a b16a2 fom a si but i have da complete swap can i jus use the 99 wire harness and ecu ....if not is there a way to wire it up to 99..
1 Post
Re: 6th generation civic swap ???? (JoHn CoNrOe)
don't use the harness or the ecu.
My suggestion:
1. 96-98 Civic Ex harness
2. Reprogrammed P28 ecu (92-95 Si/Ex)
3. OBD 2.1 - OBD 1 harness.
That will be the easiest way to do it.
My suggestion:
You will have to use your 97 harness. Also, to use the 99 ECU you will either have to rewire all the ECU connector pins, or make an adaptor.
Oh, BTW, complete sentences do help.
ITR#465
05-02-2003 06:21 PM
6th, 6thgenerationcivic, 6thgenerationciviccom, civic, complete, conroe, drive, ecu, gen, generation, john, swap, swapped, swaps, train
