what should i get???
Old May 9, 2002 | 05:57 PM
justanotherslowcivic's Avatar
Default what should i get???
i have 5000 to do a motor swap which motor should i go with? i wanting to get something that will ryn in the 12's
Old May 9, 2002 | 07:39 PM
Jared's Avatar
Default Re: what should i get??? (tjtice)
no basic swap will run 12s unless you're stripping the car completely, on slicks, and a great driver. you're gonna have to do some work first. i would suggest starting with a b18c1 base.
Old May 9, 2002 | 10:27 PM
InfamousRS's Avatar
Default Re: what should i get??? (Jared)
B18B block
87mm Goldedn eagle sleeves
95mm Eagle cranke
Decked block(to make perfect rod/storke ratio)
JE 12.5:1 pistons
Custom Crower rods
P & P b16 head
Crower Stage 3 Race core cams
Crower Valve train
and a bunch of other stuff
Im pretty sure it will cost more then 5k, but it would get you into the 12's.
b20beast83
Jan 16, 2009 07:42 AM
GOIN V8 HUNTIN
Nov 8, 2005 06:13 PM
hatchattak
Nov 25, 2003 06:43 AM
Alaskan98ITR406
12
Jun 26, 2003 04:36 PM
batman_22
Dec 12, 2002 11:58 AM
