need help with wiring a vx
Old May 10, 2002 | 03:12 PM
hatchBtype_R's Avatar
Default need help with wiring a vx
anyone know how to wire up a LS motor into a vx hatch please need help thanks first time swap also (LOL)
Old May 10, 2002 | 07:27 PM
VTECVillain's Avatar
Default Re: need help with wiring a vx (hatchBtype_R)
What year motor and ecu are you using?
Old May 12, 2002 | 12:20 PM
Default Re: need help with wiring a vx (Hybrid Moments)
its a 90-91 LS motor
Old May 12, 2002 | 12:54 PM
I wouldn't swap in that motor if I were you. Maybe use the block as a starting point for an LSVTEC but I wouldn't swap it in as is. Here's the bad points: The 90-91 were non-OBD, cable tranny, mounts are different, etc. If you want an LS go with a 94+ B18B1 with hydro tranny - direct fit and hardly any wiring involved if you use a 94-95 LS ecu.
Old May 12, 2002 | 05:46 PM
ok if i havent an other option, can this swap still be done thanks
Old May 12, 2002 | 06:11 PM
You'll need a HASport mount kit and hydro to cable conversion kit. Then you'll have a lot of wiring to do or convert the motor and accesories to OBDI and use a 94-95 OBDI ecu. I think it is way to much $ to invest for what little return you will get out of the setup. If you have it, sell it to someone with an 88-91 Civic/CRX and get yourself a 94+ LS setup.
Old May 18, 2002 | 02:32 PM
Default Re: need help with wiring a vx (VTECVillain)
ok thanks dude really appreciate the info im a sell it PEACE
4doorcivic16
Mar 11, 2006 04:06 PM
sLoWrAcEr
Mar 2, 2005 05:21 PM
Gentryjracer
Jun 30, 2003 12:54 AM
ProJectCvic
Feb 23, 2003 06:15 PM
CRexcellence
Aug 11, 2002 11:58 AM
