anyone had problems with crvtec?
Old May 8, 2002 | 09:46 PM
OEMJDM's Avatar
Default anyone had problems with crvtec?
some guy told me that this engine is really easy to **** up when u miss a gear cause of its power. Is this true? and what are some common problems with a crvtec?
Old May 8, 2002 | 10:01 PM
slammed_93_hatch's Avatar
Default Re: anyone had problems with crvtec? (b20b4me)
people rev up to 8200 or 8500 and the rod ratio on a LS or CRV block is not good for reving this high. it will cause problems if you contenuosly rev that high so basicly if you leave the bottom end stock for a long time and drive alot your gona have trouble
Old May 8, 2002 | 10:10 PM
OEMJDM's Avatar
Default Re: anyone had problems with crvtec? (slammed_93_hatch)
if i was to get one of these engines? what would be a good way to modify the bottom end out of the crvtec? what mods would be good?
Old May 8, 2002 | 10:29 PM
Trickturn's Avatar
My Con:
It's too damn fast... w/ Honda parts!!!
Balance the bottomend... that should help w/ your worries. Get new bearings while you're at it & throw on a block girdle.
Pete
Old May 8, 2002 | 11:58 PM
Maximus's Avatar
Default Re: anyone had problems with crvtec? (pest)
I am getting arias pistons and probe ultra lightweight rods bored to 84.5mm balanced and everything with brand new bearings. I believe my motor should last pretty long even if I do mess up sometimes.
Old May 9, 2002 | 06:30 AM
RCSIVTEC's Avatar
so what should you run the rev limit to is 8 gran good but not past 8200 but with a blueprinted andbalanced bottom end.
Old May 9, 2002 | 02:40 PM
dohcsideSi's Avatar
Default Re: anyone had problems with crvtec? (RCSIVTEC)
it depends on the setup w/ a set of a/m lightweight pistons, rods, balanced w/ a crank gridle you should be safe up to 10,000.
doood
10
Jul 3, 2005 06:21 PM
getgot2
Nov 26, 2003 08:03 PM
Westrock2000
25
Jun 12, 2003 06:00 PM
H23 Power
Apr 3, 2002 09:51 PM
